I’ve followed the following guides
System Info
- Titan RTX
- Windows 10 1909 Build 18363.1049
wsl -l -v
NAME STATE VERSION
Ubuntu Running 2
wsl cat /proc/version
Linux version 4.19.121-microsoft-standard (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Fri Jun 19 21:06:10 UTC 2020
uname -a (in ubuntu)
Linux MINERVA 4.19.121-microsoft-standard #1 SMP Fri Jun 19 21:06:10 UTC 2020 x86_64 x86_64 x86_64
GNU/Linux
nvidia-smi (in windows)
NVIDIA-SMI 455.41 Driver Version: 455.41 CUDA Version: 11.1
ls /usr/lib/wsl/lib
ls: cannot access ‘/usr/lib/wsl/lib’: No such file or directory
cd /dev/dxg
docker version
19.03.12
nvidia-container-cli -k -d /dev/tty info
I0821 16:21:57.950311 5686 nvc.c:282] initializing library context (version=1.3.0, build=af0220ff5c503d9ac6a1b5a491918229edbb37a4)
I0821 16:21:57.950354 5686 nvc.c:256] using root /
I0821 16:21:57.950358 5686 nvc.c:257] using ldcache /etc/ld.so.cache
I0821 16:21:57.950376 5686 nvc.c:258] using unprivileged user 1000:1000
I0821 16:21:57.950389 5686 nvc.c:299] attempting to load dxcore to see if we are running under Windows Subsystem for Linux (WSL)
I0821 16:21:57.950454 5686 nvc.c:301] dxcore initialization failed, continuing assuming a non-WSL environment
W0821 16:21:57.950514 5686 nvc.c:172] failed to detect NVIDIA devices
W0821 16:21:57.950641 5687 nvc.c:187] failed to set inheritable capabilities
W0821 16:21:57.950680 5687 nvc.c:188] skipping kernel modules load due to failure
I0821 16:21:57.950836 5688 driver.c:101] starting driver service
E0821 16:21:57.950966 5688 driver.c:161] could not start driver service: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory
I0821 16:21:57.951083 5686 driver.c:196] driver service terminated successfully
nvidia-container-cli: initialization error: driver error: failed to process request
./deviceQuery
cudaGetDeviceCount returned 35
→ CUDA driver version is insufficient for CUDA runtime version
docker run --gpus all nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 0 caused \"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request\\n\""”: unknown.
ERRO[0000] error waiting for container: context canceled
dir C:\Windows\System32\lxss\lib /d/b
libcuda.so
libcuda.so.1
libcuda.so.1.1
I’ve tried wsl --shutdown and stopping and starting docker service multiple times. With no luck.
sudo dockerd (in a separate WSL2)
prints a bunch of stuff, idle at
INFO[2020-08-24T12:37:22.281116200+01:00] API listen on /var/run/docker.sock
Run sudo docker run --gpus all nvidia/cuda:10.0-base nvidia-smi from another instance
(printed in the first instance)
INFO[2020-08-24T12:37:32.822752100+01:00] shim containerd-shim started address=“/containerd-shim/moby/b3ec723d2f173142de37e4bae69f5c1158af505b5bf4f5739f4a7a87f402891e/shim.sock” debug=false pid=212
INFO[2020-08-24T12:37:32.883190600+01:00] shim reaped id=b3ec723d2f173142de37e4bae69f5c1158af505b5bf4f5739f4a7a87f402891e
ERRO[2020-08-24T12:37:32.893665900+01:00] stream copy error: reading from a closed fifo
ERRO[2020-08-24T12:37:33.069711600+01:00] b3ec723d2f173142de37e4bae69f5c1158af505b5bf4f5739f4a7a87f402891e cleanup: failed to delete container from containerd: no such container
ERRO[2020-08-24T12:37:33.069759000+01:00] Handler for POST /v1.40/containers/b3ec723d2f173142de37e4bae69f5c1158af505b5bf4f5739f4a7a87f402891e/start returned error: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 0 caused \"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request\\n\""”: unknown
