Nvidia-container-cli error
if I run
sudo nvidia-container-cli -k -d /dev/tty info
I got this error
where is ‘devicesetgpcclkvfoffset’ symbol?
– WARNING, the following logs are for debugging purposes only –
I0509 06:20:58.858216 1009 nvc.c:372] initializing library context (version=1.4.0, build=704a698b7a0ceec07a48e56c37365c741718c2df)
I0509 06:20:58.858281 1009 nvc.c:346] using root /
I0509 06:20:58.858287 1009 nvc.c:347] using ldcache /etc/ld.so.cache
I0509 06:20:58.858293 1009 nvc.c:348] using unprivileged user 65534:65534
I0509 06:20:58.858311 1009 nvc.c:389] attempting to load dxcore to see if we are running under Windows Subsystem for Linux (WSL)
I0509 06:20:58.891385 1009 dxcore.c:226] Creating a new WDDM Adapter for hAdapter:40000000 luid:1e946dc
I0509 06:20:58.917427 1009 dxcore.c:267] Adding new adapter via dxcore hAdapter:40000000 luid:1e946dc wddm version:3000
I0509 06:20:58.917515 1009 dxcore.c:325] dxcore layer initialized successfully
W0509 06:20:58.918854 1009 nvc.c:397] skipping kernel modules load on WSL
I0509 06:20:58.919404 1010 driver.c:101] starting driver service
E0509 06:20:58.950931 1010 driver.c:168] could not start driver service: load library failed: /usr/lib/wsl/drivers/nv_dispi.inf_amd64_43efafcd74b2efc9/libnvidia-ml.so.1: undefined symbol: devicesetgpcclkvfoffset
I0509 06:20:58.951399 1009 driver.c:203] driver service terminated successfully
nvidia-container-cli: initialization error: driver error: failed to process request
I’m currently installing WSL2 Ubuntu 20.04 within Windows 10 Insider Preview Build 21376.1, and faced same issue like below.
# sudo nvidia-container-cli -k -d /dev/tty info
-- WARNING, the following logs are for debugging purposes only --
I0512 07:05:58.485519 5592 nvc.c:372] initializing library context (version=1.4.0, build=704a698b7a0ceec07a48e56c37365c741718c2df)
I0512 07:05:58.485581 5592 nvc.c:346] using root /
I0512 07:05:58.485601 5592 nvc.c:347] using ldcache /etc/ld.so.cache
I0512 07:05:58.485604 5592 nvc.c:348] using unprivileged user 65534:65534
I0512 07:05:58.485659 5592 nvc.c:389] attempting to load dxcore to see if we are running under Windows Subsystem for Linux (WSL)
I0512 07:05:58.502183 5592 dxcore.c:226] Creating a new WDDM Adapter for hAdapter:40000000 luid:185673b
I0512 07:05:58.512924 5592 dxcore.c:267] Adding new adapter via dxcore hAdapter:40000000 luid:185673b wddm version:3000
I0512 07:05:58.512956 5592 dxcore.c:325] dxcore layer initialized successfully
W0512 07:05:58.513266 5592 nvc.c:397] skipping kernel modules load on WSL
I0512 07:05:58.513404 5593 driver.c:101] starting driver service
E0512 07:05:58.521931 5593 driver.c:168] could not start driver service: load library failed: /usr/lib/wsl/drivers/nv_dispi.inf_amd64_43efafcd74b2efc9/libnvidia-ml.so.1: undefined symbol: devicesetgpcclkvfoffset
I0512 07:05:58.522047 5592 driver.c:203] driver service terminated successfully
and I found out that apt-get experimental repository and stable one is mixed out - failing to install WSL2 one (which is available in experimental repository). as stable package is released, experimental(=WSL2) package should be released, but It wasn’t. see apt-cache madison result below.
# apt-cache madison libnvidia-container1
libnvidia-container1 |    1.4.0-1 | https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64  Packages
libnvidia-container1 |    1.3.3-1 | https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64  Packages
libnvidia-container1 | 1.3.3~rc.2-1 | https://nvidia.github.io/libnvidia-container/experimental/ubuntu18.04/amd64  Packages
libnvidia-container1 | 1.3.3~rc.1-1 | https://nvidia.github.io/libnvidia-container/experimental/ubuntu18.04/amd64  Packages
libnvidia-container1 |    1.3.2-1 | https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64  Packages
libnvidia-container1 |    1.3.1-1 | https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64  Packages
The point is, we should install libnvidia-container1=1.3.3~rc.2-1 version rather than libnvidia-container1=1.4.0-1. but normal apt-get install nvidia-docker2 command would install 1.4.0-1 version, and It mostly like to fail in WSL2 environment.
I successfully installed older (WSL2-exclusive) packages via apt-get install command below:
apt-get install \
    libnvidia-container1=1.3.3~rc.2-1 \
    libnvidia-container-tools=1.3.3~rc.2-1 \
    nvidia-container-toolkit=1.4.1-1 \
    nvidia-container-runtime=3.4.1-1 \
    nvidia-docker2=2.5.0-1
Those commands will install older packages, and after sudo service docker stop and sudo service docker start, CUDA will work inside docker.
Installing the new Docker Desktop update led to an “OCI runtime create failed” as above error when starting the container (in my case, via the docker-compose). At the same time, these same containers are launched and work successfully under pure Linux.
I tried everything - I reinstalled the Nvidia driver on Windows, reinstalled the docker, the docker-compose, the nvidia container toolkit - nothing helped.
BUT!
  1. By installing the old version as suggested above:
apt-get install \
  1. Restarting Docker.
  2. By running Docker manually in WSL 2 in ubuntu to create a new context (under the old Docker-Desktop-created does not work until now).
  3. Rebuild container-CUDA-GPU in this new context with reinstalled drivers to the old version (as indicated above) - everything worked!
Dont know what is realy problem - DD or drivers…
I tried the lower version suggested by ji5489.
now I can run ‘sudo nvidia-container-cli -k -d /dev/tty info’ without any problem
and also ‘sudo docker run --gpus all --env NVIDIA_DISABLE_REQUIRE=1 nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark’ command works fine.
By the way ‘nvidia-smi’ problem still remains.
Thanks ji5489.
