WSL2: docker: Error response from daemon:
I am trying to install nvidia gpu drivers on Dell G5 laptop with Gefore RTX2060 graphics card. I follow the instructions on page CUDA on WSL :: CUDA Toolkit Documentation.
I installed everything correctly as per the instructions. However when i am testing the GPU by using the given example - sudo docker run --gpus all nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
I got the following error.
veeru@DESKTOP-RLC204T:~$ sudo docker run --gpus all nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
[sudo] password for veeru:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: requirement error: unsatisfied condition: cuda>=11.2, please update your driver to a newer version, or use an earlier cuda container: unknown.
ERRO[0000] error waiting for container: context canceled
any suggestion? Thank you
further updates: Windows 10 Build 21359.co_release.2100409-1536
dpkg -l | grep nvidia
ii libnvidia-container-tools 1.3.3-1 amd64 NVIDIA container runtime library (command-line tools)
ii libnvidia-container1:amd64 1.3.3-1 amd64 NVIDIA container runtime library
ii nvidia-container-runtime 3.4.2-1 amd64 NVIDIA container runtime
ii nvidia-container-toolkit 1.4.2-1 amd64 NVIDIA container runtime hook
ii nvidia-docker2 2.5.0-1 all nvidia-docker CLI wrapper
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Failed to properly shut down NVML: Driver Not Loaded
It’s a known bug. You can try skipping the cuda requirement like this:
docker run --gpus all --env NVIDIA_DISABLE_REQUIRE=1 nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
Thank you for this solution
This doesn’t seem to work on Windows 21364, Ubuntu 18.04, 470.25 driver, CUDA version 11.4 (CUDA 11.4 toolkit doesn’t seem to be available though). BlackScholes example works.
Same issue
Windows 21370
Ubuntu 20.04
Nvidia Driver 470.14
CUDA 11.2
BlackScholes example works fine but any nvidia-docker container throws an expection on start:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
There is new info about the “driver error”. See 470.14 - WSL with W10 Build 21343 - NVIDIA-SMI error - #15 by onomatopellan
my wsl2 details, that works without issues
  1. uname -a: 5.10.16.3-microsoft-standard-WSL2
  2. Driver Version: 470.14
  3. CUDA Version: 11.3
  4. OS build: 21370.1
