Hi
I (think I’ve) installed everything correctly - the CUDA samples run (well the BlackScholes one does anyway), and I’m able to run containers like this one:
docker run --gpus all nvcr.io/nvidia/k8s/cuda-sample:nbody nbody -gpu -benchmark
Running nvidia-smi.exe shows:
| NVIDIA-SMI 460.20 Driver Version: 460.20 CUDA Version: 11.2 |
However, nvidia-container-cli info shows:
NVRM version: 460.0
CUDA version: 11.0
Device Index: 0
Device Minor: 0
Model: UNKNOWN
Brand: UNKNOWN
GPU UUID: GPU-00000000-0000-0000-0000-000000000000
Bus Location: 0
Architecture: UNKNOWN
And indeed, when I try to run one of our internal containers which is based on nvidia’s CUDA 11.2 base image, I get:
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 0 caused \\\"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: requirement error: unsatisfied condition: cuda>=11.1, please update your driver to a newer version, or use an earlier cuda container\\\\n\\\"\"": unknown.
Why is nvidia-container-cli reporting a different cuda driver version to nvidia-smi.exe? And am I right in assuming that’s the core issue here?
I’m running Windows 10 build 20251.1.
Dan
