I would like to report a consistent and reproducible issue with GPU scaling behavior in NVIDIA Control Panel when using a mixed multi-monitor setup.
System
OS: Windows 11 (up to date)
GPU: NVIDIA GeForce RTX (Founders Edition)
Driver: Latest available
Primary display: MSI 271QR QD-OLED X50 (2560×1440, 500 Hz, DisplayPort)
Secondary display: LG UltraGear (1920×1080, 240 Hz, DisplayPort)
Issue When both monitors are enabled:
The option “Perform scaling on: GPU” is NOT available for the QD-OLED display.
The QD-OLED is forced to Display scaling.
The GPU scaling option is only available for the 1080p monitor.
When the 1080p monitor is disabled:
The GPU scaling option immediately becomes available again for the QD-OLED.
Behavior is fully normal.
This issue is 100% reproducible and does not depend on Windows display order (Display 1 / 2).
Impact In modern setups with a high-end gaming display and a secondary lower-resolution monitor, it becomes impossible to use GPU scaling on the primary display while the secondary monitor is active.
Request Please consider:
Allowing GPU scaling to be configured per display, or
Providing an advanced option to force GPU scaling on the primary display, or
Officially documenting this limitation.
Thank you for your time.
Kind regards,
Daniel.
