Recently I’ve created some test runs for transcoding given MP4 files using FFmpeg with GPU acceleration.
I’ve noticed a drop in performance testing the recent FFmpeg 5.1 release with a simple full hardware transcode using h264_nvenc in comparison with FFmpeg 4.3/4.4.
Are there any comparable issues? Any hints to diagnose this?
Are benchmark results for GPU encoding/transcoding to compare?
Test
Old FFmpeg v4.4.4 version is called with parameter:
ffmpeg -y -hwaccel cuvid -c:v h264_cuvid -i input.mp4 -c:v h264_nvenc -b:v 2M output.mp4
New FFmpeg v5.1.3 version with is called parameter:
ffmpeg -y -hwaccel cuda -hwaccel_output_format cuda -extra_hw_frames 8 -i input.mp4 -c:v h264_nvenc -b:v 2M output.mp4
Added time ffmpeg -y -benchmark ... to measure the difference.
Results
For FFmpeg 4.4.4:
frame=32782 fps=344 q=19.0 Lsize= 343834kB time=00:21:51.32 bitrate=2148.0kbits/s speed=13.8x
video:322022kB audio:20521kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.377177%
bench: utime=30.184s stime=21.803s rtime=95.442s
bench: maxrss=135840kB
[aac @ 0x5601c60686c0] Qavg: 222.746
real 1m35.543s
user 0m30.184s
sys 0m21.845s
For FFmpeg 5.1.2:
frame=32782 fps=241 q=19.0 Lsize= 343956kB time=00:21:51.34 bitrate=2148.7kbits/s speed=9.63x
video:322022kB audio:20643kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.377043%
bench: utime=66.753s stime=27.008s rtime=136.567s
bench: maxrss=161032kB
[aac @ 0x55d7f93bd3c0] Qavg: 579.972
real 2m16.669s
user 1m6.777s
sys 0m27.032s
Setup
The input.mp4 was a video container a video track with ~ 21 min, H.264 (High@L3.1), 720p, 25 fps, 892 kbps bitrate, yuv420p and audio: AAC, 128 kbps.
Ffmpeg builds created in a docker container using nvidia/cuda:12.0.1-devel-ubuntu22.04 and nvidia/cuda:12.0.1-base-ubuntu22.04 with libnpp-12-0 installed as runtime image.
With headers from this tag: https://github.com/FFmpeg/nv-codec-headers/archive/refs/tags/n12.0.16.0.tar.gz.
FFMPEG was build with following configuration:
RUN cd /tmp/ffmpeg-${FFMPEG_VERSION} && \
./configure \
--prefix=${PREFIX} \
--disable-debug \
--disable-doc \
--disable-ffplay \
--enable-version3 \
--enable-gpl \
--enable-nonfree \
--enable-small \
--enable-libfdk-aac \
--enable-openssl \
--enable-cuda \
--enable-cuvid \
--enable-nvenc \
--enable-libnpp \
--enable-nvenc \
--enable-shared \
--extra-cflags="-I${PREFIX}/include -I${PREFIX}/include/ffnvcodec -I/usr/local/cuda/include/" \
--extra-ldflags="-L${PREFIX}/lib -L/usr/local/cuda/lib64/" \
--extra-libs=-ldl && \
make && \
make install && \
make distclean && \
hash -r
Hardware: NVIDIA GeForce RTX 2080, Driver Version: 536.23, Docker 4.24.1 on Windows 10.
Thanks in advance for your comments and feedback on this issue.
