GPU Utility Problem
Hi All,
I encounter a dramatic slow down of the performance in a gpu node. When I submit job in the node through a queue, the job initially run well. Output of nvidia-smi shows high GPU utility.
| NVIDIA-SMI 5.319.37 Driver Version: 319.37 |
| 0 Tesla M2090 Off | 0000:0A:00.0 Off | 0 |
| N/A N/A P0 81W / N/A | 159MB / 5375MB | 65% Default |
| 1 Tesla M2090 Off | 0000:0D:00.0 Off | 0 |
| N/A N/A P0 106W / N/A | 159MB / 5375MB | 70% Default |
| 2 Tesla M2090 Off | 0000:2B:00.0 Off | 0 |
| N/A N/A P0 90W / N/A | 158MB / 5375MB | 65% Default |
| 3 Tesla M2090 Off | 0000:30:00.0 Off | 0 |
| N/A N/A P0 112W / N/A | 158MB / 5375MB | 67% Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 5531 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 71MB |
| 0 5527 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 71MB |
| 1 5530 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 72MB |
| 1 5526 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 71MB |
| 2 5532 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 71MB |
| 2 5528 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 71MB |
| 3 5533 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 72MB |
| 3 5529 …/NAMD_2.8_Source/Linux-x86_64-g++.cudanet/namd2 71MB |
But after 10-15 minutes the job slows down dramatically and the nvidia-smi shows 0 GPU utility.
| N/A N/A P0 78W / N/A | 159MB / 5375MB | 0% Default |
| N/A N/A P0 81W / N/A | 158MB / 5375MB | 0% Default |
Any suggestions.
Are you running 2 MPI ranks per GPU?
Does this job ever recover?
What happens if you only run 1 MPI rank per GPU?
Same things happens.
