nvidia-smi Volatile GPU-Util 100%, always, reboot operating system can not fix
Dear all,
I have a problem. GPU-Util 100%, I have try following commands, but these are not working.
  1. sudo nvidia-smi -pm 1
  2. sudo nvidia-smi -r
  3. reboot Operating System
How can i fix this problem, here is nvidia-smi output
| NVIDIA-SMI 410.66       Driver Version: 410.66       CUDA Version: 10.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 108...  On   | 00000000:40:00.0 Off |                  N/A |
| 31%   44C    P0    72W / 250W |      0MiB / 11178MiB |    100%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
nvidia-smi -a
Fan Speed                       : 18 %
    Performance State               : P0
    Clocks Throttle Reasons
        Idle                        : Not Active
        Applications Clocks Setting : Not Active
        SW Power Cap                : Not Active
        HW Slowdown                 : Not Active
            HW Thermal Slowdown     : Not Active
            HW Power Brake Slowdown : Not Active
        Sync Boost                  : Not Active
        SW Thermal Slowdown         : Not Active
        Display Clock Setting       : Not Active
    FB Memory Usage
        Total                       : 11178 MiB
        Used                        : 0 MiB
        Free                        : 11178 MiB
    BAR1 Memory Usage
        Total                       : 256 MiB
        Used                        : 2 MiB
        Free                        : 254 MiB
    Compute Mode                    : Default
    Utilization
        Gpu                         : 100 %
        Memory                      : 0 %
        Encoder                     : 0 %
        Decoder                     : 0 %
    Encoder Stats
        Active Sessions             : 0
        Average FPS                 : 0
        Average Latency             : 0
    FBC Stats
        Active Sessions             : 0
        Average FPS                 : 0
        Average Latency             : 0
    Ecc Mode
        Current                     : N/A
        Pending                     : N/A
Thank you for your time.
I have the same problem : GPU seems to be at 100% and no process are running.
Could you please give a piece of advice to find a solution ? because it slows the general GPU activity.
Best regards.
Benoit
It’s possible that the act of running nvidia-smi can report 100% utilization. This will usually only affect 1 GPU in a multi-GPU setup.
Hi, were you able to fix the issue?
I got stuck with the same problem, and trying to find a solution but still not luck :(
HI there!
Did find a solution to the problem?
I got stuck with the same problem :(
anyone resolve the problem? The GPU cannot use anymore. I always need to restart machine when this happen
It might be that a process has hung on the GPU - try this
sudo fuser -k -9 /dev/nvidia0 <-replace 0 with the gpu index
