I found out how to reproduce and trigger the GPU-Utilization 0% bug.
System: Ubuntu 16.04
Driver: 367.27
GPU: GTX 1080
First, see the following nvidia-smi output.
My GPU is idle and the GPU-Utilization shows 0%.
So far so good.
root@ht:~# nvidia-smi
Sat Jun 18 14:52:08 2016
| NVIDIA-SMI 367.27 Driver Version: 367.27 |
| 0 GeForce GTX 1080 Off | 0000:01:00.0 On | N/A |
| 40% 53C P0 35W / 180W | 10MiB / 8112MiB | 0% E. Process |
Now on some other terminal I’ll run some compute intense task.
This task causes the GPU to run at 100%.
It’s expected the GPU-Utiliazion to show 100%.
As you can see, it’s doing that, which is exactly how it should be.
Sat Jun 18 14:57:31 2016
| 27% 62C P2 189W / 217W | 1027MiB / 8112MiB | 100% E. Process |
Now how to trigger the bug. I’ll change the following line in my xorg.conf:
Original:
Option "RegistryDwords" "PerfLevelSrc=0x2222"
New:
Option "RegistryDwords" "PowerMizerEnable=0x1; PerfLevelSrc=0x2222"
So all I do here is to enable PowerMizer.
After the change in xorg.conf I have to restart both X11 and my compute intense.
The bug now occurs.
The GPU-Utilization will be shown as 0% even if it running at 100% in real:
Sat Jun 18 15:06:30 2016
| 69% 62C P2 196W / 217W | 1027MiB / 8112MiB | 0% E. Process |
As a proof that my compute intense task is running see reported power consumption.
Note that I was unable to trigger the bug by setting PowerMizer via nvidia-settings.
Using nvidia-settings I can enable PowerMizer without triggering the bug.
It needs to be done via xorg.conf.
atom
