I’m working on a GStreamer pipeline on Jetson Xavier NX where I need to process grayscale images in GRAY16 format (16 bits per pixel). However, I noticed that the nvvidconv plugin does not seem to accept GRAY16 as a valid input format.
I tried to push video/x-raw, format=GRAY16 buffers to nvvidconv, but it fails with a caps negotiation error. The plugin only seems to accept formats like GRAY8, NV12, RGBA, I420, etc.
Does nvvidconv support GRAY16, GRAY16_LE, or any other 16-bit per pixel formats?
Would support for 16-bit formats be available in future versions of nvvidconv?
I’m using DeepStream SDK 6.3, and I’ve encountered an issue where setting a custom buffer size in NvBufSurfaceCreateParams::size
(specifically surfaceList[0].dataSize) has no effect during NvBufSurfaceCreate. I’m using NVBUF_MEM_SURFACE_ARRAY memtype. It is using width , height and color format for allocating memory. Please help me to allocate custom memory size in NVBUF_MEM_SURFACE_ARRAY surface.
