Hi!
I am generating fractals using CUDA
in the kenel I determine the offsets as follows:
int x = blockIdx.x*blockDim.x + threadIdx.x;
int y = blockIdx.y*blockDim.y + threadIdx.y;
int offset = x + y*blockDim.x*gridDim.x; //in bitmap
and I launch the kernel:
const int tpb = 64; //threads per block
dim3 grid(w/tpb,h); //w and h are the dimensions of the fractal
dim3 block(tpb,1);
kernel<<<grid,block>>>(...)
The problem is, that if I divide the h variable too, lets say by 64 (I wanted to do this in the first place!) then i get a whole black picture, instead a beautiful fractal.
On the other hand, if I launch the kernel like stated above (w/tpb, h) then I receive a correct picture.
What is the matter?
Is it, possibly the MAX_THREADS_PER_BLOCK parameter (which in my card is 1024 - and 64x64 is 4096) ?
Regards
