grouping specific loops into a kernel
I want to map the outer most 2 loops (k and j) into 1 single kernel, k loop and j loop will be executed in vector mode, and each thread in this kernel will execute the i loop in sequential manner.
How can I force the PGI compiler to do that using OpenACC directives?
program testbla
      use openacc
        integer :: i, j, k, n
        real, allocatable, dimension(:,:,:) :: a, b, c
      n = 10
      allocate(a(n,n,n), b(n,n,n), c(n,n,n))
      do k = 1, n
        do j = 1, n
          do i = 1, n
            a(i,j,k) = 0.0
            b(i,j,k) = 1.0
          enddo
        enddo
      enddo
      do k = 1, n
        do j = 1, n
          do i = 1, n
            c(i,j,k) =  a(i,j,k) + b(i,j,k)
          enddo
          do i = 1, n
          enddo
        enddo
      enddo
      !print *, c
      end program testbla
Thank you.
A couple of ways. The “collapse(2) gang vector” clause when used with the “kernels” construct will merge the “k” and “j” loops into a 2-D gang and 2-D vector schedule. You would then add a “loop seq” clause around the “i” loops to force them to be run sequentially.
  • Mat
% cat test3.f90
      program testbla
      use openacc
      n = 10
!$acc kernels loop collapse(2) gang vector
      do k = 1, n
        do j = 1, n
!$acc loop seq
          do i = 1, n
            a(i,j,k) = 0.0
            b(i,j,k) = 1.0
          enddo
        enddo
      enddo
!$acc parallel loop gang
      do k = 1, n
!$acc loop vector
        do j = 1, n
!$acc loop seq
          do i = 1, n
          enddo
!$acc loop seq
          do i = 1, n
          enddo
        enddo
      enddo
      ! need to print this out otherwise dead-code
      ! elemination will remove the above loops
      print *, c(1,1,1), c(n,n,n)
      end program testbla
% pgf90 -acc -Minfo=accel test3.f90 -V13.5
testbla:
     10, Generating present_or_copyout(b(1:10,1:10,1:10))
         Generating present_or_copyout(a(1:10,1:10,1:10))
         Generating NVIDIA code
         Generating compute capability 1.0 binary
         Generating compute capability 2.0 binary
         Generating compute capability 3.0 binary
     11, Loop is parallelizable
     12, Loop is parallelizable
     14, Loop is parallelizable
         Accelerator kernel generated
         11, !$acc loop gang, vector(4) ! blockidx%y threadidx%y
         12, !$acc loop gang, vector(32) ! blockidx%x threadidx%x
     21, Accelerator kernel generated
         22, !$acc loop gang ! blockidx%x
         24, !$acc loop vector(256) ! threadidx%x
     21, Generating present_or_copyin(b(1:10,1:10,1:10))
         Generating present_or_copyin(a(1:10,1:10,1:10))
         Generating present_or_copyout(c(1:10,1:10,1:10))
     24, Loop is parallelizable
     26, Loop is parallelizable
     30, Loop is parallelizable
