OpenACC Loop Organization
Assume that there is a multiple loop inside a parallel region,
!$ACC PARALLEL LOOP GANG
DO k = …
// Something
DO i = 1, 2
DO j = 1, 4
// Something
ENDDO
ENDDO
// Something
END DO
!$ACC END PARALLEL
If I assign 8 workers to the loop inside, like
DO k = …
// Something
!$ACC LOOP WORKER(8)
DO i = 1, 2
DO j = 1, 4
// Something
ENDDO
ENDDO
// Something
END DO
!$ACC END PARALLEL
How does it behave?
Does it behave like
Worker 1 : i = 1, j = 1
Worker 2 : i = 1, j = 2
Worker 3 : i = 1, j = 3
Worker 4 : i = 1, j = 4
Worker 5 : i = 2, j = 1
Worker 6 : i = 2, j = 2
Worker 7 : i = 2, j = 3
Worker 8 : i = 2, j = 4
or
Worker 1 : i = 1, j = 1, 2, 3, 4
Worker 2 : i = 2, j = 1, 2, 3, 4
Worker 3 to 8 : Not Generated
What about if I make loops like
DO k = …
// Something
!$ACC LOOP WORKER(2)
DO i = 1, 2
!$ACC LOOP WORKER(4)
DO j = 1, 4
// Something
ENDDO
ENDDO
// Something
END DO
!$ACC END PARALLEL
Is this gramatically correct? If so, how does it behave?
Hi CNJ,
It would behave like the second where only two worker are used, unless the compiler automatic adds “vector” to the “j” loop (PGI might does this if it can detect if “j” is independent, but it’s not mandatory)
Nesting “worker” clauses is technically illegal. Instead, either collapse the loops, or use a “vector” clause.
!$ACC LOOP WORKER collapse(2)
 DO i = 1, 2
 DO j = 1, 4
!$ACC LOOP WORKER
 DO i = 1, 2
!$AC LOOP VECTOR
 DO j = 1, 4
  • Mat
DO i = 1, 2
DO j = 1, 4
Does this always guarantee that the compiler launches 8 workers?
If not, by which way can I achieve it?
No. The compiler can choose based upon the target device.
Add the “num_workers(8)” clause to the “parallel” directive.
Or “worker(8)” if you’re using a “kernels” directive.
I would recommend you not explicitly set the number of gangs, workers, or vectors. This way the compiler can decide the best case based upon the target device.
Note that on NVIDIA devices, the minimum number of threads used is 32. So if you set workers to 8 (and have no vector loop), then you’ll have 24 idle threads.
  • Mat
