Thanks for the reply DaneLLL. I am still confused why it is working without nvidconv in previuos releases. An answer could help to avoid future mistakes.
Also, the above pipeline is not able to play .flv files. Without nvvidconv we can play this kind of files.
0:00:00.050241608 10718 0x5574280900 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "filesrc"
0:00:00.053684131 10718 0x5574280900 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "decodebin"
0:00:00.054038253 10718 0x5574280900 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "typefind" named "typefind"
0:00:00.054931397 10718 0x5574280900 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "videoconvert"
0:00:00.057473484 10718 0x5574280900 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "xvimagesink"
0:00:00.057941879 10718 0x5574280900 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "pipeline"
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
0:00:00.107027526 10718 0x557428e990 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "qtdemux"
0:00:00.108493339 10718 0x7f8c079b70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "multiqueue"
0:00:00.111476893 10718 0x7f8c079b70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "h264parse"
0:00:00.112533635 10718 0x7f8c079b70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
nvbuf_utils: Could not get EGL display connection
0:00:00.174326067 10718 0x7f840084f0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvv4l2decoder"
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
WARNING: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0: not negotiated
Additional debug info:
gstbasetransform.c(1415): gst_base_transform_reconfigure (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0:
not negotiated
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0: Internal data stream error.
qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
With Jetpack 4.2 I found the below information with GST_DEBUG with the same command - WORKING
0:00:00.040174646 3395 0x556b4faf00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "filesrc"
0:00:00.043119269 3395 0x556b4faf00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "decodebin"
0:00:00.043377635 3395 0x556b4faf00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "typefind" named "typefind"
0:00:00.044073215 3395 0x556b4faf00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "videoconvert"
0:00:00.046205427 3395 0x556b4faf00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "xvimagesink"
0:00:00.046554897 3395 0x556b4faf00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "pipeline"
0:00:00.130345737 3395 0x556b50d990 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "qtdemux"
0:00:00.131848032 3395 0x7f9c079b70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "multiqueue"
0:00:00.134091123 3395 0x7f9c079b70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "h264parse"
0:00:00.134970862 3395 0x7f9c079b70 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "capsfilter"
0:00:00.186971295 3395 0x7f940084a0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "omxh264dec"
NVMEDIA: Reading sys.display-size : status: 6
Allocating new output: 608x416 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3595: Send OMX_EventPortSettingsChanged: nFrameWidth = 600, nFrameHeight = 404
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:10.000138608
Setting pipeline to READY ...
With Jetpack version change one or the other libraries are being changed and old applications (created for old Jetpacks) are not running. Here for every Jetpack we have to modify the applications to run smoothly. This has become a pain point for an active Jetson developer. Perhaps you should preserve compatibility for old applications as well.
On Jetpack4.2, it selects
omxh264dec has implementation of tranforming video/x-raw(memory:NVMM) to video/x-raw in source pad. It is actually same as what nvvidconv does.
We are deprecating omx plugins, so would like to suggest use nvv4l2decoder and hook nvvidconv in the pipeline. If you would like to keep using omxh264dec, you can get gst-v4l2 source code and lower the rank setting in gstv4l2videodec.c:
