I am trying to mix 2 usb audio sources ( inputs taken from using alsasrc) to a single source and sink them through HDMI of jetson nano using alsasink.
alsasrc device=“hw:4,0” ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=48000” ! tee name=a1 !
alsasrc device=“hw:4,1” ! queue ! audio/x-raw ! queue ! audioresample ! “audio/x-raw,rate=48000” ! tee name=a2 !
liveadder name=mix ! queue ! audioconvert ! alsasink device=“hw:0,3” a1. ! queue ! mix.sink_0 a2. ! queue ! mix.sink_1
Is there a method to encode and sink to alsasink device?
Do you mean you have single alsa source, and would like to simultaneously encode to a file and send to alsasink for audio playback? If it is the case, you can try to use tee plugin.
I have 2 different alsa sources, my requirement is to aac encode the 2 alsasources mix them and sink them to the alsasink device (HDMI of jetson nano)
below will only mix and sink the 2 audio sources without encoding to aac
Please try this plugin: audiomixer
We don’t have much experience about this but the plugin seems to be designed for this. Please give it a try.
Thank you @DaneLLL .
I have tried this the mixing is working. The additional part is to mix encode to aac and sink
I was able to acheive
mix → sink (alsasink)
below is the method
audiomixer name=mix ! queue ! audioconvert ! alsasink device=“hw:0,3” a1. ! queue ! mix.sink_0 a2. ! queue ! mix.sink_1
I want to acheive
mix → encode → sink (alsasink)
I am able encode using the voaacenc plugin and mix the audio to a file and save. My problem is a method to encode and playback from the HDMI
system
Closed
February 9, 2022, 5:52am
8
