i am getting audio and video from v4l2src and alsasrc and encode it and share it over shmsink using below Gstreamer pipeline.
gst-launch-1.0 -v v4l2src do-timestamp=true ! video/x-raw,width=640,height=480,format=I420,framerate=30/1 ! tee name=t ! queue ! shmsink socket-path=/tmp/foo sync=true wait-for-connection=false shm-size=10000000 t. ! queue ! x264enc tune=zerolatency key-int-max=30 ! rtph264pay ! shmsink socket-path=/tmp/test shm-size=10000000 wait-for-connection=false alsasrc ! queue ! audioconvert ! lamemp3enc ! rtpmpapay ! shmsink socket-path=/tmp/audio wait-for-connection=false shm-size=1000000
Then i am opening another terminal for streming video and audio using shmsrc and rtspserver with below pipeline:
./test-launch “( shmsrc socket-path=/tmp/test do-timestamp=true ! application/x-rtp,clock-rate=90000 ! rtph264depay ! rtph264pay name=pay0 pt=96 ! shmsrc socket-path=/tmp/audio do-timestamp=true ! application/x-rtp,media=audio,clock-rate=90000,encoding-name=MPA ! rtpmpadepay ! rtpmpapay name=pay1 pt=97 )”
i am getting video on VLC player but i am not getting audio on vlc player.
i am getting below log on first pipeline when i closed the second pipeline:
WARNING: from element /GstPipeline:pipeline0/GstAlsaSrc:alsasrc0: Can’t record audio fast enough
Additional debug info:
gstaudiobasesrc.c(869): gst_audio_base_src_create (): /GstPipeline:pipeline0/GstAlsaSrc:alsasrc0:
Dropped 142884 samples. This is most likely because downstream can’t keep up and is consuming samples too slowly.
what can i change in that pipeline to achieve audio/video streaming with sync.
