Link two gstreamer rtspsrcs
Hello everyone! I have two ip-devices (camera for video stream and coder for audio stream). I want to connect two streams and in the end receive file (and stream it to rtspclientsink in future). How can I do it? I used to try a lot of combinations of gst-elements (yes, I checked pads, they match). Camera and coder are defenitely in working condition. Please help me ^_^
Here is one of pipelines I’ve tried:
gst-launch-1.0 -e rtspsrc location=‘<camera_ip>’ name=src
src. ! rtph264depay ! h264parse ! avdec_h264 ! queue ! mux.
rtspsrc location=‘<coder_ip>’ ! rtpssrcdemux name=dmx
dmx.audio_0_01e2 ! aacparse ! mux.
matroskamux name=mux ! filesink location=video.mp4
and errors I’ve got:
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Redistribute latency…
0:00:02.880824886 27077 0x7f70008770 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop: error: Internal data stream error.
0:00:02.880894939 27077 0x7f70008770 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop: error: streaming stopped, reason not-linked (-1)
0:00:02.882575644 27077 0x7f70008720 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop: error: Internal data stream error.
0:00:02.882608613 27077 0x7f70008720 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop: error: streaming stopped, reason not-linked (-1)
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc1/GstUDPSrc:udpsrc5: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc1/GstUDPSrc:udpsrc5:
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
We suggest break down the pipeline to audio and video only and check if both video and audio sources are good first:
gst-launch-1.0 -e rtspsrc location=‘<camera_ip>’ name=src src. ! rtph264depay ! h264parse ! avdec_h264 ! queue ! mux. matroskamux name=mux ! filesink location=video.mp4
gst-launch-1.0 -e rtspsrc location=‘<coder_ip>’ ! rtpssrcdemux name=dmx dmx.audio_0_01e2 ! aacparse ! mux. matroskamux name=mux ! filesink location=audio.mp4
Hi! both of pipelines you gave do not work, but this one do : gst-launch-1.0 -e rtspsrc location='<cam or coder ip>' ! rtph264depay ! h264parse ! avdec_h264 ! queue ! mux. matroskamux name=mux ! filesink location=only_video.mkv
Unfortunately, it give me only video stream. Btw, I use jetson nano. Is there any workable pipeline for sound?
Looks like audio source cannot be received and decoded. Suggest you work out a working pipeline for audio decoding first. And then combine the audio and video pipelines.
