Hi
I tried to combine both audio and video using a single gstreamer pipeline .But I am getting a warning as shown below
GST_ARGUS: PowerService: requested_clock_Hz=25804800
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
WARNING: from element /GstPipeline:pipeline0/GstAlsaSrc:alsasrc0: Can’t record audio fast enough
Additional debug info:
gstaudiobasesrc.c(849): gst_audio_base_src_create (): /GstPipeline:pipeline0/GstAlsaSrc:alsasrc0:
Dropped 1210 samples. This is most likely because downstream can’t keep up and is consuming samples too slowly.
Dropped 8030 samples. This is most likely because downstream can’t keep up and is consuming samples too slowly.
The pipeline used is
gst-launch-1.0 -e nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)3840, height=(int)1920, format=(string)NV12,framerate=(fraction)16/1’ ! queue ! omxh264enc profile=8 bitrate=10000000 ! mux. alsasrc ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! queue ! audioconvert ! audioresample ! voaacenc ! aacparse ! flvmux name=mux ! filesink location=test.mp4 sync=false
please help…
thanks in advance…
