Using the below cmd, I am able to record the video and audio in same time.
gst-launch-1.0 v4l2src ! ‘video/x-raw, width=1920, height=1080, framerate=30/1, format=UYVY’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=I420’ ! queue ! omxh264enc bitrate=8000000 ! h264parse ! matroskamux name=mux ! filesink location=oct22_1230pm.mkv -e alsasrc ! ‘audio/x-raw, format=(string)S16LE, layout=(string)interleaved, channels=(int)2, channel-mask=(bitmask)0x0000000000000003, rate=(int)48000’ ! queue ! audioconvert ! lamemp3enc ! mux.
But in Audio, I am getting the noise.
The log is:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstAudioSrcClock
Redistribute latency…
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
===== MSENC blits (mode: 1) into tiled surfaces =====
WARNING: from element /GstPipeline:pipeline0/GstAlsaSrc:alsasrc0: Can’t record audio fast enough
Additional debug info:
gstaudiobasesrc.c(869): gst_audio_base_src_create (): /GstPipeline:pipeline0/GstAlsaSrc:alsasrc0:
Dropped 205920 samples. This is most likely because downstream can’t keep up and is consuming samples too slowly.
-Thanks.
