Gstreamer encoder memory leak
We detect a memory leak when using encoder on TX2
We use Jetpack version 28.2.1
Gstreamer version 1.8.3
When we run the following command line we get a memory leak of 1.8Mb per hour
We are using free command line to detect memory leak (free memory).
gst-launch-1.0 v4l2src device=“/dev/video0” ! video/x-raw,width=1920,height=1080 ! videoconvert ! video/x-raw,format=I420 ! omxh264enc control-rate=2 bitrate=5000000 ! mpegtsmux padding=true alignment=7 ! udpsink host=10.10.10.55 port=30120 sync=false async=false
  1. Can you reproduce the memory leak?
  2. Do you have any solution to this problem?
We would suggest upgrade to latest release for TX2, which is Jetpack 4.6.3.
Please note omx plugins are deprecated on Jetpack 4. And please use nvv4l2h264enc plugin.
