Hello
Could anyone help me with this issue?
I’ve looking into this issue in forum and github. Normally it happens after an error which is the cause, But,the only error I can see is not retrieving any image. What is happening? Hardware: XAVIER AGX
Same issue here. But disabling that option doesn’t solve it
IN CONTAINER:
root@263a942a2f44:~/repos/jetson-utils/build/aarch64/bin# ./video-viewer rtsp://X:X@192.168.121.181 fileideo.mp4 --headless --input-rtsp-latency=2000URI -- missing/invalid IP port from rtsp://X:X@192.168.121.181, default to port 554
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstDecoder -- creating decoder for X
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
[gstreamer] gstDecoder -- discovered video resolution: 3072x1728 (framerate 0.000000 Hz)
[gstreamer] gstDecoder -- discovered video caps: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)5.1, profile=(string)main, pixel-aspect-ratio=(fraction)1/1, width=(int)3072, height=(int)1728, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
[gstreamer] gstDecoder -- pipeline string:
[gstreamer] rtspsrc location=rtsp://X:X@192.168.121.181 latency=2000 ! queue ! rtph264depay ! h264parse ! omxh264dec ! video/x-raw(memory:NVMM) ! appsink name=mysink
[video] created gstDecoder from rtsp://X:X@192.168.121.181
gstDecoder video options:
-- URI: rtsp://X:X@192.168.121.181
- protocol: rtsp
- port: 554
-- deviceType: ip
-- ioType: input
-- codec: h264
-- width: 3072
-- height: 1728
-- frameRate: 0.000000
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] gstEncoder -- codec not specified, defaulting to H.264
[gstreamer] gstEncoder -- pipeline launch string:
[gstreamer] appsrc name=mysource is-live=true do-timestamp=true format=3 ! omxh264enc bitrate=4000000 ! video/x-h264 ! h264parse ! qtmux ! filesink location=fileideo.mp4
[video] created gstEncoder from file:///root/repos/jetson-utils/build/aarch64/bin/fileideo.mp4
gstEncoder video options:
-- URI: file:///root/repos/jetson-utils/build/aarch64/bin/fileideo.mp4
- protocol: file
- extension: mp4
-- deviceType: file
-- ioType: output
-- codec: h264
-- width: 0
-- height: 0
-- frameRate: 30.000000
-- bitRate: 4000000
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[gstreamer] opening gstDecoder for streaming, transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from NULL to READY ==> h264parse1
[gstreamer] gstreamer changed state from NULL to READY ==> rtph264depay1
[gstreamer] gstreamer changed state from NULL to READY ==> queue0
[gstreamer] gstreamer changed state from NULL to READY ==> rtspsrc0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from READY to PAUSED ==> h264parse1
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtph264depay1
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> queue0
[gstreamer] gstreamer message progress ==> rtspsrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtspsrc0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer message new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> omxh264dec-omxh264dec0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> h264parse1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtph264depay1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> queue0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtspsrc0
[gstreamer] gstDecoder -- failed to retrieve next image buffer
video-viewer: failed to capture video frame
(video-viewer:2313): GStreamer-CRITICAL **: 08:33:41.543: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:2313): GStreamer-CRITICAL **: 08:33:41.544: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:2313): GStreamer-CRITICAL **: 08:33:41.545: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:2313): GStreamer-CRITICAL **: 08:33:41.545: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:2313): GStreamer-CRITICAL **: 08:33:41.545: gst_structure_get_string: assertion 'structure != NULL' failed
(video-viewer:2313): GStreamer-CRITICAL **: 08:33:41.545: gst_mini_object_unref: assertion 'mini_object != NULL' failed
Allocating new output: 3072x1728 (x 15), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 3072, nFrameHeight = 1728
But disabling the NVMM doesn’t work. This build2 is with -DENABLE_NVMM=off. :
root@263a942a2f44:~/repos/jetson-utils/build2/aarch64/bin# ./video-viewer rtsp://X:X@192.168.121.181 fileideo.mp4 --headless
[gstreamer] rtspsrc location=rtsp://X:X@192.168.121.181 latency=2000 ! queue ! rtph264depay ! h264parse ! omxh264dec ! video/x-raw ! appsink name=mysink
- protocol: rtsp
- port: 554
-- deviceType: ip
-- ioType: input
-- codec: h264
-- width: 3072
-- height: 1728
-- bitRate: 0
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
[video] created gstEncoder from file:///root/repos/jetson-utils/build2/aarch64/bin/fileideo.mp4
-- URI: file:///root/repos/jetson-utils/build2/aarch64/bin/fileideo.mp4
- protocol: file
- extension: mp4
-- deviceType: file
-- ioType: output
-- codec: h264
-- width: 0
-- height: 0
-- bitRate: 4000000
-- numBuffers: 4
-- zeroCopy: true
-- flipMethod: none
-- loop: 0
-- rtspLatency 2000
(video-viewer:4448): GStreamer-CRITICAL **: 08:53:45.615: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:4448): GStreamer-CRITICAL **: 08:53:45.615: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:4448): GStreamer-CRITICAL **: 08:53:45.615: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:4448): GStreamer-CRITICAL **: 08:53:45.615: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(video-viewer:4448): GStreamer-CRITICAL **: 08:53:45.615: gst_structure_get_string: assertion 'structure != NULL' failed
(video-viewer:4448): GStreamer-CRITICAL **: 08:53:45.616: gst_mini_object_unref: assertion 'mini_object != NULL' failed
^Creceived SIGINT
video-viewer: shutting down...
[gstreamer] gstDecoder -- stopping pipeline, transitioning to GST_STATE_NULL
[gstreamer] gstDecoder -- pipeline stopped
video-viewer: shutdown complete
So,in order to debug I have joined two pipelines into this one adding -vvv
gst-launch-1.0 -evvv rtspsrc location=rtsp://X:X@192.168.121.181 latency=2000 ! queue ! rtph264depay ! h264parse ! omxh264dec ! video/x-raw ! omxh264enc bitrate=4000000 ! video/x-h264 ! h264parse ! qtmux ! filesink location=../../camera-edge/gst.mp4
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://X:X@192.168.121.181
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: rfc7273-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-time-source = NTP time based on realtime clock
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: drop-on-latency = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-rtcp-rtp-time-diff = 1000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-ts-offset-adjustment = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: buffer-mode = Slave receiver to sender clock
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 5000000000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtcp
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad0: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstFunnelPad:funnelpad0: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
Progress: (request) Sent PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0.GstProxyPad:proxypad1: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel1.GstFunnelPad:funnelpad1: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel1.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:sync_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtcp_sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:src_1174459676: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)1727520\,\ packets-received\=\(guint64\)1275\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)22\,\ jitter\=\(uint\)30\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725864130407301\,\ sr-rtptime\=\(uint\)3131669404\,\ sr-octet-count\=\(uint\)150\,\ sr-packet-count\=\(uint\)3\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)4\,\ sent-rb-packetslost\=\(int\)22\,\ sent-rb-exthighestseq\=\(uint\)47553\,\ sent-rb-jitter\=\(uint\)30\,\ sent-rb-lsr\=\(uint\)4033050705\,\ sent-rb-dlsr\=\(uint\)68274\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad2: caps = application/x-rtcp
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_1174459676_35.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_1174459676_35.GstProxyPad:proxypad3: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)35, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)4d4033, sprop-parameter-sets=(string)"Z01AM42NYBgAbNgLcBDQECA\=\,aO44gA\=\=", a-recvonly=(string)"", ssrc=(uint)1174459676, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, pixel-aspect-ratio=(fraction)1/1, width=(int)3072, height=(int)1728, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, level=(string)5.1
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_structure_get_string: assertion 'structure != NULL' failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_mini_object_unref: assertion 'mini_object != NULL' failed
/GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, pixel-aspect-ratio=(fraction)1/1, width=(int)3072, height=(int)1728, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, level=(string)5.1
/GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)3072, height=(int)1728, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)3072, height=(int)1728, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)3072, height=(int)1728, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)0/1
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
/GstPipeline:pipeline0/GstOMXH264Enc-omxh264enc:omxh264enc-omxh264enc0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)3072, height=(int)1728, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)3072, height=(int)1728, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)4019845\,\ packets-received\=\(guint64\)2976\,\ bitrate\=\(guint64\)13439151\,\ packets-lost\=\(int\)56\,\ jitter\=\(uint\)31\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725864130407301\,\ sr-rtptime\=\(uint\)3131669404\,\ sr-octet-count\=\(uint\)150\,\ sr-packet-count\=\(uint\)3\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)4\,\ sent-rb-packetslost\=\(int\)22\,\ sent-rb-exthighestseq\=\(uint\)47553\,\ sent-rb-jitter\=\(uint\)30\,\ sent-rb-lsr\=\(uint\)4033050705\,\ sent-rb-dlsr\=\(uint\)68274\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)4467490\,\ packets-received\=\(guint64\)3311\,\ bitrate\=\(guint64\)13439151\,\ packets-lost\=\(int\)64\,\ jitter\=\(uint\)28\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725864130407301\,\ sr-rtptime\=\(uint\)3131669404\,\ sr-octet-count\=\(uint\)150\,\ sr-packet-count\=\(uint\)3\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)4\,\ sent-rb-packetslost\=\(int\)22\,\ sent-rb-exthighestseq\=\(uint\)47553\,\ sent-rb-jitter\=\(uint\)30\,\ sent-rb-lsr\=\(uint\)4033050705\,\ sent-rb-dlsr\=\(uint\)68274\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)6571734\,\ packets-received\=\(guint64\)4857\,\ bitrate\=\(guint64\)12763050\,\ packets-lost\=\(int\)101\,\ jitter\=\(uint\)24\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725864130407301\,\ sr-rtptime\=\(uint\)3131669404\,\ sr-octet-count\=\(uint\)150\,\ sr-packet-count\=\(uint\)3\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)4\,\ sent-rb-packetslost\=\(int\)22\,\ sent-rb-exthighestseq\=\(uint\)47553\,\ sent-rb-jitter\=\(uint\)30\,\ sent-rb-lsr\=\(uint\)4033050705\,\ sent-rb-dlsr\=\(uint\)68274\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)7130781\,\ packets-received\=\(guint64\)5275\,\ bitrate\=\(guint64\)12763050\,\ packets-lost\=\(int\)108\,\ jitter\=\(uint\)57\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725864130407301\,\ sr-rtptime\=\(uint\)3131669404\,\ sr-octet-count\=\(uint\)150\,\ sr-packet-count\=\(uint\)3\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)5\,\ sent-rb-packetslost\=\(int\)108\,\ sent-rb-exthighestseq\=\(uint\)51639\,\ sent-rb-jitter\=\(uint\)57\,\ sent-rb-lsr\=\(uint\)4033050705\,\ sent-rb-dlsr\=\(uint\)317058\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)10155528\,\ packets-received\=\(guint64\)7537\,\ bitrate\=\(guint64\)12440704\,\ packets-lost\=\(int\)149\,\ jitter\=\(uint\)25\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725885888711623\,\ sr-rtptime\=\(uint\)3132125330\,\ sr-octet-count\=\(uint\)8442853\,\ sr-packet-count\=\(uint\)6218\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)5\,\ sent-rb-packetslost\=\(int\)108\,\ sent-rb-exthighestseq\=\(uint\)51639\,\ sent-rb-jitter\=\(uint\)57\,\ sent-rb-lsr\=\(uint\)4033050705\,\ sent-rb-dlsr\=\(uint\)317058\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)12920114\,\ packets-received\=\(guint64\)9595\,\ bitrate\=\(guint64\)11200273\,\ packets-lost\=\(int\)194\,\ jitter\=\(uint\)23\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725885888711623\,\ sr-rtptime\=\(uint\)3132125330\,\ sr-octet-count\=\(uint\)8442853\,\ sr-packet-count\=\(uint\)6218\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)4\,\ sent-rb-packetslost\=\(int\)194\,\ sent-rb-exthighestseq\=\(uint\)56045\,\ sent-rb-jitter\=\(uint\)23\,\ sent-rb-lsr\=\(uint\)4033382711\,\ sent-rb-dlsr\=\(uint\)301501\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)17083758\,\ packets-received\=\(guint64\)12661\,\ bitrate\=\(guint64\)11522240\,\ packets-lost\=\(int\)260\,\ jitter\=\(uint\)50\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725907500987056\,\ sr-rtptime\=\(uint\)3132578257\,\ sr-octet-count\=\(uint\)14562639\,\ sr-packet-count\=\(uint\)10783\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)4\,\ sent-rb-packetslost\=\(int\)194\,\ sent-rb-exthighestseq\=\(uint\)56045\,\ sent-rb-jitter\=\(uint\)23\,\ sent-rb-lsr\=\(uint\)4033382711\,\ sent-rb-dlsr\=\(uint\)301501\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)17237338\,\ packets-received\=\(guint64\)12778\,\ bitrate\=\(guint64\)11522240\,\ packets-lost\=\(int\)265\,\ jitter\=\(uint\)38\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725907500987056\,\ sr-rtptime\=\(uint\)3132578257\,\ sr-octet-count\=\(uint\)14562639\,\ sr-packet-count\=\(uint\)10783\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)5\,\ sent-rb-packetslost\=\(int\)265\,\ sent-rb-exthighestseq\=\(uint\)59299\,\ sent-rb-jitter\=\(uint\)38\,\ sent-rb-lsr\=\(uint\)4033712488\,\ sent-rb-dlsr\=\(uint\)149829\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)19808524\,\ packets-received\=\(guint64\)14699\,\ bitrate\=\(guint64\)11197406\,\ packets-lost\=\(int\)295\,\ jitter\=\(uint\)56\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725907500987056\,\ sr-rtptime\=\(uint\)3132578257\,\ sr-octet-count\=\(uint\)14562639\,\ sr-packet-count\=\(uint\)10783\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)5\,\ sent-rb-packetslost\=\(int\)265\,\ sent-rb-exthighestseq\=\(uint\)59299\,\ sent-rb-jitter\=\(uint\)38\,\ sent-rb-lsr\=\(uint\)4033712488\,\ sent-rb-dlsr\=\(uint\)149829\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)3305988739\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1174459676\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.121.181:15344\,\ rtcp-from\=\(string\)192.168.121.181:15345\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)19831974\,\ packets-received\=\(guint64\)14717\,\ bitrate\=\(guint64\)11197406\,\ packets-lost\=\(int\)295\,\ jitter\=\(uint\)38\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16568725907500987056\,\ sr-rtptime\=\(uint\)3132578257\,\ sr-octet-count\=\(uint\)14562639\,\ sr-packet-count\=\(uint\)10783\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)5\,\ sent-rb-packetslost\=\(int\)265\,\ sent-rb-exthighestseq\=\(uint\)59299\,\ sent-rb-jitter\=\(uint\)38\,\ sent-rb-lsr\=\(uint\)4033712488\,\ sent-rb-dlsr\=\(uint\)149829\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
ERROR: from element /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0: No valid frames decoded before end of stream
Additional debug info:
gstvideodecoder.c(1161): gst_video_decoder_sink_event_default (): /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0:
no valid frames found
An error happened while waiting for EOS
Execution ended after 0:00:17.294270047
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
In this way, I am savig empty files. But looks like decoder hasn’t retrieved any image either. Does the error happens because of this?
*(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_is_empty: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_truncate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_fixate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:10288): GStreamer-CRITICAL **: 11:18:29.587: gst_structure_get_string: assertion ‘structure != NULL’ failed
(gst-launch-1.0:10288): GStreamer-CRITICAL *: 11:18:29.587: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
And what is this?
You can also follow this issue here:
