Hi there,
I was using the following commands on NANO and it was working perfectly, then I switched to NX and run the exact same commands but surprisingly it works with lots of hiccups and short pauses in the video:
I am using
gstreamer (gst-launch-1.0) Version: 1.14.5,
Jetpack 4.4.1 (L4T 32.4.4)
CUDA:10.2.89
cuDNN: 8.0.0.180
TensorRT: 7.1.3.0
On both NX and NANO.
and I have tried with and without jetson_clocks on both boards with no difference in the performance. CPU and RAM are below 30% while running the commands.
My Test involves 4 scripts:
- TCP SERVERS: which get the frames from usb3.0 camera and provides them on multiple tcpserversinks for different types of clients:
SCRIPT:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2, width=1920, height=1080, framerate=60/1 ! tee name=t t. ! videorate max-rate=15 ! nvvidconv ! ‘video/x-raw(memory:NVMM),width=1920,height=1280’ ! omxh264enc bitrate=10000000 preset-level=2 ! ‘video/x-h264, stream-format=(string)byte-stream’ ! h264parse ! queue ! rtph264pay config-interval=1 pt=96 ! gdppay ! queue ! tcpserversink port=5002 sync=false async=false t. ! videorate max-rate=20 ! nvvidconv ! ‘video/x-raw(memory:NVMM),width=880,height=512’ ! omxh264enc bitrate=2000000 preset-level=2 ! ‘video/x-h264, stream-format=(string)byte-stream’ ! h264parse ! queue ! rtph264pay config-interval=1 pt=96 ! gdppay ! queue ! tcpserversink port=5001 sync=false async=false t. ! videorate max-rate=30 ! nvvidconv ! ‘video/x-raw(memory:NVMM),width=1920,height=1080’ ! omxh264enc bitrate=10000000 preset-level=2 ! ‘video/x-h264, stream-format=(string)byte-stream’ ! h264parse ! queue ! rtph264pay config-interval=1 pt=96 ! gdppay ! queue ! tcpserversink port=5000 sync=false async=false -e
OUTPUT:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Framerate set to : 15 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
Framerate set to : 20 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
- TCP CLIENTS: Here I just want to refer to those ones which are problematic (slow) on NX (as mentioned earlier, they work perfectly fine on NANO)
2.1. Client 1: Gets data from TCPSERVER, makes modifications, and sends them udpsink.
Script:
gst-launch-1.0 tcpclientsrc port=5002 ! gdpdepay ! rtph264depay ! queue ! h264parse ! omxh264dec ! ‘video/x-raw(memory:NVMM),width=1920,height=1280’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),width=1920,height=1280’ ! nvvidconv ! ‘video/x-raw,width=1280,height=720’ ! textoverlay text=“TITLE” shaded-background=yes deltay=-20 deltax=-20 valignment=top halignment=left font-desc=“Sans, 10” ! nvvidconv ! ‘video/x-raw(memory:NVMM)’ ! omxh264enc bitrate=2000000 preset-level=0 ! ‘video/x-h264, stream-format=(string)byte-stream’ ! h264parse ! queue ! rtph264pay config-interval=1 pt=96 ! gdppay ! queue ! udpsink host=10.0.0.1 port=6000 buffer-size=100000000 sync=false async=false -e
Client 1 OUPUT:
Pipeline is PREROLLED …
(gst-launch-1.0:13179): GStreamer-CRITICAL **: 14:35:01.965: gst_caps_is_empty: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:13179): GStreamer-CRITICAL **: 14:35:01.966: gst_caps_truncate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:13179): GStreamer-CRITICAL **: 14:35:01.966: gst_caps_fixate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:13179): GStreamer-CRITICAL **: 14:35:01.966: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:13179): GStreamer-CRITICAL **: 14:35:01.966: gst_structure_get_string: assertion ‘structure != NULL’ failed
(gst-launch-1.0:13179): GStreamer-CRITICAL **: 14:35:01.966: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 1920x1280 (x 18), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 1920, nFrameHeight = 1280
reference in DPB was never decoded
NOTE1: In spite of those “CRITICAL” warnings, the pipeline works fine.
NOTE2: These errors happen both on NANO and NX.
Question1: Is it possible that this is actually causing some errors in the background that is contributing to the problem I described?
Question2: Why these warnings are happening? how can I modify my GStreamer pipeline to get rid of them?
Client 2.1.1 : (In remote windows OS) : gets data from udpsrc and displays it on the monitor.
Script:
gst-launch-1.0 udpsrc port=6000 ! gdpdepay ! rtph264depay ! avdec_h264 ! video/x-raw ! autovideosink sync=false async=false
Output:
Got context from element ‘autovideosink0’: gst.d3d11.device.handle=context, device=(GstD3D11Device)"(GstD3D11Device)\ d3d11device4", adapter=(int)0;
Redistribute latency…
0:34:36.8 / 99:99:99.
Note: At this point I can see the video on the display (in remote windows OS) but with NANO, the video is much smoother than NX.
2.2. Client 2: Gets the data from TCPSERVER and saves it on the disk.
Script:
gst-launch-1.0 tcpclientsrc port=5000 ! gdpdepay ! rtph264depay ! queue ! h264parse ! mpegtsmux ! filesink location=/media/6FE3-EC2C/test.ts -e
Output:
Pipeline is PREROLLING …
Note: After Running This command, the file (test.ts) will be created on the disk and keeps recording the data. ( Again the recoded video in NANO is smoother)
2.3. Client3: Gets data from TCP Server, adds text overlays, then saves them on the disk.
SCRIPT:
gst-launch-1.0 tcpclientsrc port=5000 ! gdpdepay ! rtph264depay ! queue ! h264parse ! omxh264dec ! ‘video/x-raw(memory:NVMM),width=1920,height=1080’ ! nvvidconv ! ‘video/x-raw,width=1920,height=1080’ ! textoverlay text=“TITLE” valignment=top halignment=left font-desc=“Sans,15” ! textoverlay text=“TITLE2” valignment=bottom halignment=left deltay=-45 font-desc=“Sans,10” shaded-background=yes ! nvvidconv ! ‘video/x-raw(memory:NVMM)’ ! omxh264enc bitrate=10000000 preset-level=2 ! ‘video/x-h264,stream-format=(string)byte-stream’ ! h264parse ! mpegtsmux ! filesink location=/media/6FE3-EC2C/test_overlay.ts -e
OUTPUT:
(gst-launch-1.0:3256): GStreamer-CRITICAL **: 17:27:21.311: gst_caps_is_empty: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:3256): GStreamer-CRITICAL **: 17:27:21.311: gst_caps_truncate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:3256): GStreamer-CRITICAL **: 17:27:21.311: gst_caps_fixate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:3256): GStreamer-CRITICAL **: 17:27:21.311: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:3256): GStreamer-CRITICAL **: 17:27:21.311: gst_structure_get_string: assertion ‘structure != NULL’ failed
(gst-launch-1.0:3256): GStreamer-CRITICAL **: 17:27:21.312: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
Allocating new output: 1920x1088 (x 11), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 1920, nFrameHeight = 1080
NOTE1: I still get those “CRITICAL” warnings but again the pipeline works and creates the video files.
NOTE2: As you may have noticed, I am writing to a USB flash drive, which is USB3, but due to the bandwidth of the USB3 and the amount of inputs (from camera) and outputs (to files) I don’t think this would be an issue.
NOTE3: It is the exact same setup on NANO as well, but again NANO performs much better.
Question3: How can I get rid of these “CRITICAL” warnings?
ALL clients (except for the one that I mentioned which runs on windows) and the server script are running locally on NX (or NANO) at the same time.
I truly appreciate if someone can tell me what might be wrong or what I can do to get at least the same performance on NX if not better, plus, it would be great if you can answer questions 1-3 about the CRITICAL messages that I get after running the scripts.
Thank you!
