Gstreamer issue streaming USB camera from Xavier NX over UDP
Hi all,
I’m currently quite fresh to using Gstreamer so forgive me if there is any missing information; this is my first time using it for streaming footage for a project so there is a lot I am still unaware of and would love any advice you could give me.
For the purpose of the project I will need to stream a USB camera connected to my Xaxier NX to another machine over UDP. Whilst testing the pipeline I am using the same Xavier NX however I have tried a different machine and am having the same problem.
Although the script is not showing up with any errors, the client is stuck at “New clock: Gstsystemclock” though will not open up a new window to view the stream.
Server Code:
gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! video/x-raw,framerate=30/1 ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay ! udpsink host=<IP_ADDRESS> port=<PORT>
Client Code
gst-launch-1.0 udpsrc port=<PORT> ! application/x-rtp, payload=96 ! rtph264depay ! avdec_h264 ! autovideosink
Server Output
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
Client Output:
Is it an issue with the sink I have chosen? I have also tried xvimagesink and glimagesink and have been having the same problem with no window opening to view the stream. I have tested with videotestsrc and have had no problem so I would appreciate any help at all.
Please let me know if there’s any additional information I should provide as I am quite new to these forums.
Please try the example in
Jetson AGX Orin FAQ
Q: Is there an example for running UDP streaming?
Hi, I have attempted to modify the script that you wrote for UDP in TX2 NX as the server and an X86 as a client, however I am having trouble getting gstreamer to accept any caps to stream video from my USB device.
Server Code:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=1280,height=720,framerate=30/1 ! timeoverlay valignment=4 halignment=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720' ! tee name=t ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! udpsink host=<HOST_IP> port=5000 sync=0 t. ! queue ! nvegltransform ! nveglglessink sync=0
Server Output:
Using winsys: x11
Opening in BLOCKING MODE
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
Please try
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=1280,height=720,framerate=30/1 ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720' ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! udpsink host=<HOST_IP> port=5000 sync=0
HOST_IP has to be IP of the client.
Hi there,
Unfortunately still no luck at the moment:
Thank you for your help so far. Could this have to do with the caps I am using? If it helps at all the USB device I am using supports both MJPG and YUYV.
Please refer to
Jetson AGX Orin FAQ
Q: I have a USB camera. How can I launch it on AGX Orin?
to work out a command to launch the camera. And then you can link like:
... ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720,format=I420' ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! udpsink host=<HOST_IP> port=5000 sync=0
Thank you so much for your help, was finally able to crack it. All though v4l2-ctl lists YUYV as an accepted video format Gstreamer prefers listing the format as YUY2.
Final Working Server Code:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! videoconvert ! video/x-raw,format=NV12 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1280,height=720,format=I420' ! nvv4l2h264enc insert-sps-pps=1 idrinterval=15 ! h264parse ! rtph264pay ! udpsink host=<HOST_IP> port=5000 sync=0
For future reference for anyone.
I used the same format of client code as detailed in this example and was able to stream the footage over UDP onto my ACER laptop.
Once again thank you!!
