I’m trying with the following pipeline:
GST_DEBUG=3 gst-launch-1.0 -v rtmpsrc location=rtmp://192.168.0.168/live/0 do-timestamp=true ! queue2 ! flvdemux name=demux flvmux name=mux demux.video ! queue ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw' ! clockoverlay ! nvvidconv ! 'video/x-raw(memory:NVMM)' ! nvv4l2h264enc ! h264parse ! mux.video demux.audio ! queue name="dmx_aud_q" ! mux.audio mux.src ! queue name="mux_q" ! filesink location="rtmp.flv"
The streaming starts, and then stops after a few seconds (varying from 20s to 1min). The logs are as follows:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
0:00:00.127652888 10540 0x5585e14ad0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x5585e05b00 Failed to determine interlace mode
0:00:00.127734086 10540 0x5585e14ad0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x5585e05b00 Failed to determine interlace mode
0:00:00.127996638 10540 0x5585e14ad0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x5585e05b00 Failed to determine interlace mode
0:00:00.128090127 10540 0x5585e14ad0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2h264enc0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.130235282 10540 0x5585e14ad0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.130284865 10540 0x5585e14ad0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x5585de9080 Failed to determine interlace mode
Pipeline is PREROLLING ...
0:00:00.882069463 10540 0x7f80004ad0 WARN flvdemux gstflvdemux.c:659:gst_flv_demux_parse_tag_script:<demux> failed reading a tag, skipping
/GstPipeline:pipeline0/GstQueue:dmx_aud_q.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, rate=(int)44100, channels=(int)2, codec_data=(buffer)1210
/GstPipeline:pipeline0/GstFlvMux:mux.GstFlvMuxPad:sink_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, rate=(int)44100, channels=(int)2, codec_data=(buffer)1210
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, width=(int)1920, height=(int)1080, codec_data=(buffer)0142002affe100166742002a95a81e0089f961000003000100000300648401000468ce3c80
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, width=(int)1920, height=(int)1080, codec_data=(buffer)0142002affe100166742002a95a81e0089f961000003000100000300648401000468ce3c80
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, width=(int)1920, height=(int)1080, codec_data=(buffer)0142002affe100166742002a95a81e0089f961000003000100000300648401000468ce3c80
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, width=(int)1920, height=(int)1080, framerate=(fraction)50/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, alignment=(string)au, profile=(string)baseline, level=(string)4.2
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, width=(int)1920, height=(int)1080, framerate=(fraction)50/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, alignment=(string)au, profile=(string)baseline, level=(string)4.2
0:00:01.037006284 10540 0x5585deb5e0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:01.037716023 10540 0x5585deb5e0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x5585de9080 Failed to determine interlace mode
/GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)50/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/GstClockOverlay:clockoverlay0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, level=(string)NULL, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstH264Parse:h264parse1.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, level=(string)NULL, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
Redistribute latency...
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
0:00:01.060473968 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1054:gst_v4l2_buffer_pool_start:<nvv4l2h264enc0:pool:src> Uncertain or not enough buffers, enabling copy threshold
/GstPipeline:pipeline0/nvv4l2h264enc:nvv4l2h264enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/GstClockOverlay:clockoverlay0.GstPad:video_sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
0:00:01.061759748 10540 0x5585deb5e0 WARN v4l2videodec gstv4l2videodec.c:1433:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, format=(string)NV12
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)50/1
0:00:01.062155738 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1054:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:01.070839167 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1518:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
H264: Profile = 66, Level = 0
0:00:01.158465695 10540 0x7f5c004230 WARN v4l2bufferpool gstv4l2bufferpool.c:1518:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:src> Driver should never set v4l2_buffer.field to ANY
/GstPipeline:pipeline0/GstH264Parse:h264parse1.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, profile=(string)constrained-baseline, level=(string)4.2, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, codec_data=(buffer)0142402affe1000b6742402a965403c0113f2a01000468ce3c80
/GstPipeline:pipeline0/GstFlvMux:mux.GstFlvMuxPad:sink_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, profile=(string)constrained-baseline, level=(string)4.2, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)50/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, codec_data=(buffer)0142402affe1000b6742402a965403c0113f2a01000468ce3c80
/GstPipeline:pipeline0/GstFlvMux:mux.GstAggregatorPad:src: caps = video/x-flv
/GstPipeline:pipeline0/GstQueue:mux_q.GstPad:sink: caps = video/x-flv
0:00:01.160030902 10540 0x5585deb540 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<filesink0> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
/GstPipeline:pipeline0/GstQueue:mux_q.GstPad:src: caps = video/x-flv
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-flv
/GstPipeline:pipeline0/GstFlvMux:mux.GstAggregatorPad:src: caps = video/x-flv, streamheader=(buffer)< 464c5601050000000900000000, 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, 0900001f0000000000000017000000000142402affe1000b6742402a965403c0113f2a01000468ce3c800000002a, 0800000400000000000000af0012100000000f >
/GstPipeline:pipeline0/GstQueue:mux_q.GstPad:sink: caps = video/x-flv, streamheader=(buffer)< 464c5601050000000900000000, 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, 0900001f0000000000000017000000000142402affe1000b6742402a965403c0113f2a01000468ce3c800000002a, 0800000400000000000000af0012100000000f >
/GstPipeline:pipeline0/GstQueue:mux_q.GstPad:src: caps = video/x-flv, streamheader=(buffer)< 464c5601050000000900000000, 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, 0900001f0000000000000017000000000142402affe1000b6742402a965403c0113f2a01000468ce3c800000002a, 0800000400000000000000af0012100000000f >
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-flv, streamheader=(buffer)< 464c5601050000000900000000, 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, 0900001f0000000000000017000000000142402affe1000b6742402a965403c0113f2a01000468ce3c800000002a, 0800000400000000000000af0012100000000f >
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:01.180260205 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.180303069 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.191619517 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.191661235 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.203118776 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.203161016 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.215887045 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.215929076 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.216090430 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.227862866 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.227904794 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.239488324 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.239528636 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.251247791 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.251291281 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.251427635 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.251673572 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.251859510 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.252013624 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.252161072 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.266393974 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.266529808 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.266707464 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.279493545 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.279538232 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.292037960 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.292082178 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.304636333 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.304680187 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.316938873 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.316981269 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.328374747 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.328415945 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.328539851 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.328781309 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.328923288 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.344502283 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.344544262 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.356454198 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.356495657 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.368331166 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:01.368369916 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
. <Truncated>
0:00:46.676258702 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:46.676306567 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:46.844523910 10540 0x5585deb5e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:46.872275646 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:46.872324188 10540 0x7f7c0040f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1463:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
My main concern is the part that says “nvv4l2decoder0:pool:sink v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.” - is this actually a bug with nvv4l2decoder? If so, is there a solution? If not, what could be going wrong here?
The resulting flv file is playable, but with significant frame drops.
