Encountering issues when attempting to stream RTMP with Jetson Nano using Gstreamer and OpenCV
My device is a jetson nano.
I want to use opencv and Gstreamer to push the processed frame image to a computer on the same LAN with the corresponding GPU acceleration enabled, which uses VLC to pull and display. But something went wrong. The corresponding code and log are as follows:
import time
import cv2
# Cam properties
fps = 25
frame_width = 1920
frame_height = 1080
# Create capture
address = 'rtspsrc location=rtsp://admin:wzu123456@192.168.0.64:554/h264/ch1/main/av_stream latency=0  ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw,width=1920,height=1080,format=BGRx ! videoconvert ! appsink '
cap = cv2.VideoCapture(address)
# Set camera properties
#cap.set(cv2.CAP_PROP_FRAME_WIDTH, frame_width)
#cap.set(cv2.CAP_PROP_FRAME_HEIGHT, frame_height)
#cap.set(cv2.CAP_PROP_FPS, fps)
**# Define the gstreamer sink**
**gst_str_rtp = "appsrc ! videoconvert ! nvvidconv ! nvv4l2h264enc tune=zerolatency bitrate=500 speed-preset=superfast ! h264parse ! flvmux ! rtmpsink location='rtmp://127.0.0.1:8554'"**
# Check if cap is open
if cap.isOpened() is not True:
    print ("Cannot open camera. Exiting.")
    quit()
# Create videowriter as a SHM sink
**out = cv2.VideoWriter(gst_str_rtp, 0, fps, (frame_width, frame_height), True)**
# Loop it
while True:
    # Get the frame
    ret, frame = cap.read()
    # Check
    if ret is True:
        cv2.imshow('frame1', frame)
        if cv2.waitKey(1) == ord('q'):
            break
        # Flip frame
        # frame = cv2.flip(frame, 1)
        # Write to SHM
        **out.write(frame)**
    else:
        print("Camera error.")
        time.sleep(10)
cap.release()
(ocr) wzu@wzu-desktop:~/jjh/demo$ python gst_device_to_rtp.py
(python:13353): GStreamer-CRITICAL **: 20:20:24.125: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(python:13353): GStreamer-CRITICAL **: 20:20:24.125: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(python:13353): GStreamer-CRITICAL **: 20:20:24.125: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(python:13353): GStreamer-CRITICAL **: 20:20:24.125: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(python:13353): GStreamer-CRITICAL **: 20:20:24.125: gst_structure_get_string: assertion 'structure != NULL' failed
(python:13353): GStreamer-CRITICAL **: 20:20:24.125: gst_mini_object_unref: assertion 'mini_object != NULL' failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 2560x1440 (x 14), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 2560, nFrameHeight = 1440
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (1063) open OpenCV | GStreamer warning: unable to query duration of stream
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (1100) open OpenCV | GStreamer warning: Cannot query video position: status=1, value=0, duration=-1
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (1673) open OpenCV | GStreamer warning: error opening writer pipeline: no property "tune" in element "nvv4l2h264enc0"
Nano address is 192.168.0.166, pull flow is normal, but another computer via VLC display screen, VLC using address is RTMP: / / 192.168.0.166:8554
We are uncertain if RTMP works in VLC. This would need other users to share experience.
Generally, we use test-launch to launch RTSP server and VLC player can open the network stream successfully. Please refer to
Jetson Nano FAQ
Q: Is there any example of running RTSP streaming?
I tried what you said, and it worked. But now I want to push the processed image through rtmp, just like the code I wrote above, how I can modify it. If VLC doesn’t support RTMP, try RTSP first. Here is the key code:
 if ret is True:
            break
        out.write(frame)
We are uncertain how to launch RTMP. This would need other users to share experience and knowledge.
Try the command on Jetson device:
$ gst-launch-1.0 videotestsrc is-live=1 ! queue ! videoconvert ! x264enc ! flvmux streamable=true ! queue ! rtmpsink location='rtmp://10.19.100.135:1234/test'
10.19.100.135 is IP address of Windows laptop. The command can be run. But I try to open VLC player on Windows laptop and access the stream, it fails. We don’t know what we are missing in setting up RTMP. Please check and see if you have any idea.
I changed some of the code and found that the pipeline works fine under the following test commands.
gst-launch-1.0 -v videotestsrc ! video/x-raw,width=1920,height=1080,format=BGRx,framerate=25/1 ! nvvidconv ! omxh264enc ! flvmux ! rtmpsink location='rtmp://192.168.0.2:1935/live'
But the following code does not work properly.
import time
import cv2
# Cam properties
fps = 25
frame_width = 1920
frame_height = 1080
# Create capture
gst_str_rtp = "appsrc ! video/x-raw,width=1920,height=1080,format=BGRx,framerate=25/1 ! nvvidconv ! omxh264enc !  flvmux ! rtmpsink location='rtmp://192.168.0.2:1935/live'"
    quit()
# Loop it
while True:
    # Get the frame
    # Check
    if ret is True:
            break
        # Flip frame
        # Write to SHM
        out.write(frame)
    else:
        time.sleep(10)
cap.release()
The following error occurred:
(python:6300): GStreamer-CRITICAL **: 16:02:33.673: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(python:6300): GStreamer-CRITICAL **: 16:02:33.673: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(python:6300): GStreamer-CRITICAL **: 16:02:33.673: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(python:6300): GStreamer-CRITICAL **: 16:02:33.673: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(python:6300): GStreamer-CRITICAL **: 16:02:33.673: gst_structure_get_string: assertion 'structure != NULL' failed
(python:6300): GStreamer-CRITICAL **: 16:02:33.674: gst_mini_object_unref: assertion 'mini_object != NULL' failed
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (2076) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module appsrc0 reported: Internal data stream error.
[ WARN:0] global /home/wzu/jjh/opencv/opencv-4.5.4/modules/videoio/src/cap_gstreamer.cpp (1967) writeFrame OpenCV | GStreamer warning: Error pushing buffer to GStreamer pipeline
What should I do to make the code work?
In addition, the video stream can be obtained normally.
