Gstreamer transcoding performance issue
Hello.
I use gstreamer to test the performance of tegra’s (tx1) video subsystem.
I’ve managed to transcode two FHD H264 streams to H265 simultaneously on stock system image. If I add the third one, the error message appears and fps drops. The message is about the reference frame not decoded from DPB. Tergastats says that the load is below of the half of the maximum by CPU and mem controller. The single stream is processed like this:
udpsrc uri='some multicast group' ! tsdemux ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! fakesink or filesink
By the way omxmpeg2videodec produces errors and the wrong frames on interlaced input (progressive not tested).
I’ve flashed the system image from jetpack 2.3.1 and have installed additional plugins for gstreamer. It can’t even decode single stream without DPB errors and the FPS drops now on fresh system.
  • What could be the reason of this?
  • How to fix it?
I’ve also read about new multimedia API but it seems that there is no MPEG2 support.
  • MPEG2 is not supported now, isn't it?
Thank you.
I’ve dumped H264 elementary stream from multicast source to file and have tried to play it with gst-play, gst-launch and the sample application from Multimedia API.
  • The sample from Multimedia API plays it fine.
  • Gst-play shows one image per 10 seconds or so.
  • Gst-launch plays ok with this pipeline:
    filesrc location='some_es.h264' ! h264parse ! omxh264dec ! nvvidconv ! videorate ! 'video/x-raw, framerate=50/1' ! nveglglessink
    It behaves the same way as gst-play if there is no videorate in pipeline.
The framerate counter shows some weird numbers but there is no message about the reference in DPB was never decoded. Here are the output logs:
gst-launch multicast:
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/00_video_decode$ gst-launch-1.0 udpsrc uri='udp://225.101.15.16:1234' ! tsdemux ! h264parse ! omxh264dec ! nvvidconv ! nveglglessink
Setting pipeline to PAUSED ...
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7580: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 1166: BeginSequence  1920x1088, bVPR = 0, fFrameRate = 25.000000
TVMR: LowCorner Frequency = 180000
TVMR: cbBeginSequence: 1545: DecodeBuffers = 5, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1606: Display Resolution : (1920x1080)
TVMR: cbBeginSequence: 1607: Display Aspect Ratio : (1920x1080)
TVMR: cbBeginSequence: 1649: ColorFormat : 5
TVMR: cbBeginSequence:1660 ColorSpace = NvColorSpace_YCbCr709
TVMR: cbBeginSequence: 1761: Layout 3: Interlaced Output Resolution : (1920x1088)
TVMR: InterlaceBufferAlloc !!!!!!!!!!!!!!!!!!!!!
TVMR: TVMRInit: 100: frameWidth = 1920, frameHeight = 1088
TVMR: TVMRInit: 114: deinterlaceType = 2
TVMR: DeinterlaceThread: 827: DeinterlaceThread is created
TVMR: cbBeginSequence: 1868: NumOfSurfaces = 4, InteraceStream = 1, InterlaceEnabled = 1, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
Allocating new output: 1920x1088 (x 6), ThumbnailMode = 0
TVMR: FrameRate = 50
TVMR: NVDEC LowCorner Freq = (300000 * 1024)
---> TVMR: Video-conferencing detected !!!!!!!!!
TVMR: FrameRate = 2.837210
ERROR: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Output window was closed
Additional debug info:
/dvs/git/dirty/git-master_linux/external/gstreamer/gst-nveglglessink/ext/eglgles/gsteglglessink.c(820): gst_eglglessink_event_thread (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0
Execution ended after 0:06:12.945089854
Setting pipeline to READY ...
TVMR: TVMRFrameStatusReporting: 6067: Closing TVMR Frame Status Thread -------------
TVMR: TVMRVPRFloorSizeSettingThread: 5885: Closing TVMRVPRFloorSizeSettingThread -------------
TVMR: TVMRFrameDelivery: 5917: Closing TVMR Frame Delivery Thread -------------
TVMR: DeinterlaceThread: 903: Closing Deinterlace Thread
TVMR: NvMMLiteTVMRDecBlockClose: 7740: Done
Setting pipeline to NULL ...
Freeing pipeline ...
video_decode dumped ES:
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/00_video_decode$ ./video_decode /home/ubuntu/dump.h264 H264
Set governor to performance before enabling profiler
Failed to query video capabilities: Bad address
Starting decoder capture loop thread
TVMR: LowCorner Frequency = 0
TVMR: cbBeginSequence: 1790: SurfaceLayout = 3
TVMR: cbBeginSequence: 1868: NumOfSurfaces = 6, InteraceStream = 1, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
Video Resolution: 1920x1080
libv4l2_nvvidconv (0):(765) (INFO) : Allocating (10) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (0):(775) (INFO) : Allocating (10) CAPTURE PLANE BUFFERS Layout=0
Query and set capture successful
TVMR: NvMMLiteTVMRDecDoWork: 6466: NVMMLITE_TVMR: EOS detected
Input file read complete
TVMR: FrameRate = 25.000000
TVMR: TVMRBufferProcessing: 5444: Processing of EOS
TVMR: TVMRBufferProcessing: 5519: Processing of EOS Done
Exiting decoder capture loop thread
App run was successful
gst-play dumped ES:
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/00_video_decode$ gst-play-1.0 /home/ubuntu/dump.h264
Press 'k' to see a list of keyboard shortcuts.
Now playing /home/ubuntu/dump.h264
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingNvMMLiteOpen : Block : BlockType = 261
TVMR: FrameRate = 150.001500
TVMR: FrameRate = -428.577551
TVMR: FrameRate = 750.018750
TVMR: NVDEC LowCorner Freq = (150000 * 1024)
TVMR: FrameRate = 250.000000
TVMR: FrameRate = 375.009375
TVMR: FrameRate = 300.003000
TVMR: FrameRate = -200.000000
0:00:01.0 / 0:01:20.5
gst-launch dumped ES:
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/00_video_decode$ gst-launch-1.0 filesrc location='/home/ubuntu/dump.h264' ! h264parse ! omxh264dec ! nvvidconv ! videorate ! 'video/x-raw, framerate=50/1' ! nveglglessink
Inside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is PREROLLING ...
Pipeline is PREROLLED ...
TVMR: FrameRate = 130.435917
Got EOS from element "pipeline0".
Execution ended after 0:00:37.999986604
Hi Yar1k,
As omxh264dec and omxh265enc are HW engines, you can check the freq of NVDEC and MSENC in tegrastats. Three transcoding streams can be too heavy for the engines.
For #2, could you describe the steps and the issue in detail one more time? Not clearly understand what the issue is. If it is possible, please share some_es.h264 also.
For omxmpeg2videodec, please also share your test stream if possible. I think we don’t support interlaced input but would like to double confirm.
And MPEG2 is not supported in MM API.
I suppose TX1 can transcode even 4 streams. Data sheet says about decoding 240fps 1080p H264 and encoding 120fps 1080p H265. Decoder and Encoder are separate modules on diagram. Maybe ISP or VIC is the issue.
I have flashed the fresh ubuntu image(16.04) on target board during Jetpack installation process, have installed gstreamer plugins via apt and have tried to launch the same transcoding pipeline. The result is that the single stream transcoding pipeline drops frames and produces “DPB not decoed” errors just like three transcoding streams on stock ubuntu(14.04) image. So I have tried to just decode and display the stream which I wanted to transcode before. The result is in output log of gst-launch: fps=2 and “reference in DPB was never decoded”. I’ve decided to check that HW decoder is working OK by dumping ES from TS and playing it both on GST-OMX and MM API. It seems that the problems is in gst or omx.
MPEG2 decoder produces correct frames on fresh ubuntu now but the playback speed is floating. I guess it’s a gstreamer issue because totem player which uses SW decoder and Gst framework have this problem too.
GStreamer 1.8.2
The samples are here:
Hi Yar1k,
I tried to run 4 transcodings:
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 filesrc location=some_es.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a.h265 & gst-launch-1.0 filesrc location=some_es1.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a1.h265 & gst-launch-1.0 filesrc location=some_es2.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a2.h265 & gst-launch-1.0 filesrc location=some_es3.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a3.h265
[1] 5218
[2] 5219
[3] 5220
Inside NvxLiteH264DecoderLowLatencyInitInside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH264DecoderLowLatencyInitNvxLiteH264DecoderLowLatencyInit set DPB and MjstreamingInside NvxLiteH265DecoderLowLatencyInitNvxLiteH265DecoderLowLatencyInit set DPB and MjstreamingPipeline is PREROLLING ...
Framerate set to : 25 at NvxVideoEncoderSetParameterTVMR: cbBeginSequence: 1166: BeginSequence  1920x1088, bVPR = 0, fFrameRate = 25.000000
NvMMLiteOpen : Block : BlockType = 8
Framerate set to : 25 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
===== MSENC =====
===== MSENC =====
===== MSENC =====
lv 20, tier 1
lv 20, tier 1
lv 20, tier 1
lv 20, tier 1
Execution ended after 0:00:27.650336088
ubuntu@tegra-ubuntu:~$ TVMR: FrameRate = 130.435917
Execution ended after 0:00:28.575044439
Execution ended after 0:00:28.823468480
Execution ended after 0:00:29.008143820
[1]   Done                    gst-launch-1.0 filesrc location=some_es.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a.h265
[2]-  Done                    gst-launch-1.0 filesrc location=some_es1.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a1.h265
[3]+  Done                    gst-launch-1.0 filesrc location=some_es2.h264 ! h264parse ! omxh264dec ! nvvidconv ! omxh265enc ! 'video/x-h265,stream-format=(string)byte-stream' ! filesink location=a2.h265
some_es.h264 is a 32-second content, so the performance seems good enough:
I think the error you see is probably because of the network bandwidth. I check some_es.h264 via JM decoder:
00040( I | P )   81   471    18                             4:2:0      42
00038( B | B )   77   472    22                             4:2:0      48
00037( B | B )   75   473    22                             4:2:0      50
00039( B | B )   79   474    22                             4:2:0      60
00044( P | P )   89   475    18                             4:2:0      49
00042( B | B )   85   476    22                             4:2:0      44
00041( B | B )   83   477    22                             4:2:0      47
00043( B | B )   87   478    22                             4:2:0      47
00048( P | P )   97   479    18                             4:2:0      54
There are three B frames between I and P / P and P frames. If one of the I/P frame is incomplete and not decoded successfully, the three B frames cannot be decoded as well. Since 4 transcodings with filesrc work fine, the issue should be from the udpsrc. Possibly the network bandwidth is limited and some packets are dropped.
Hello DaneLLL,
It’s nice to see this.
What’s about MPEG2? Is it played fine on your side?
Maybe I should open another thread, but are there any plans about MPEG2 support in MM API?
Thank you.
Hi Yar1k,
On my side, it is played fine by running
$ gst-launch-1.0 filesrc location=some_es.mpv ! mpegvideoparse ! omxmpeg2videodec ! nvoverlaysink
Will update you about supporting MPEG2 decoding in MM API.
Hi Yar1k,
Confirm that we don’t have plan to support MPEG2 decoding in MM API.
Hello DaneLLL,
This is sad. Thank you for your support.
