内核日志如下
[ 5258.397285] iommu_context_dev 13e40000.host1x:niso1_ctx0: pin_array_ids: could not get buf err=-22
[ 5258.406634] falcon 15340000.vic: pin_job_mem -22
[ 5258.412071] falcon 15340000.vic: nvhost_ioctl_channel_submit: failed with err nvhost_job_pin
[ 5258.420858] falcon 15340000.vic: nvhost_ioctl_channel_submit: =====================
[ 5258.428882] falcon 15340000.vic: nvhost_ioctl_channel_submit: failed with err -22
目前难以复现,可否给一个pipeline能够调用nvhost_ioctl_channel_submit,使得复现的概率大一些,另外出现此问题时,有哪些原因?
We support jetson_multimedia_api and gstreamer. Please make sure you have checked the document:
There are some examples in
Q: Is there any example of running RTSP streaming?
Q: Is there an example for running UDP streaming?
Q: I have a USB camera. How can I launch it on AGX Orin?
For further issues, please share a method to replicate the issue through gstreamer command, or either sample. We will set up developer kit and check.
You can execute the script to fix VIC at maximum frequency:
VPI - Vision Programming Interface: Performance Benchmark
And see if the issue is still present. If it persists, we would need to replicate the issue and check further. Please share us a test sample and we will try to replicate it on developer kit.
The code of calling nvhost_ioctl_channel_submit is built in libs and not public. We cannot reveal further information. For moving this topic forward, please share a method so that we can reproduce it on developer kit. And check.
另外能否告知下,具体是哪个库会调用 nvhost_ioctl_channel_submit
这是其他出错日志
Jan 14 23:59:55 cntjitpy-igvak-21-dcu1 kernel: [429064.035922] falcon 15340000.vic: nvhost_ioctl_channel_submit: failed with err -22
Jan 14 23:59:55 cntjitpy-igvak-21-dcu1 kernel: [429064.063666] arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ff5b21000, fsynr=0x3c0003, cbfrsynra=0x435, cb=8
Jan 14 23:59:55 cntjitpy-igvak-21-dcu1 kernel: [429064.076320] arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ff5b20000, fsynr=0x650003, cbfrsynra=0x435, cb=8
Jan 14 23:59:55 cntjitpy-igvak-21-dcu1 kernel: [429064.092836] mc-err: (255) csr_vicsrd: EMEM address decode error
Jan 14 23:59:55 cntjitpy-igvak-21-dcu1 kernel: [429064.099100] mc-err: status = 0x2006406c; hi_addr_reg = 0x000000ff addr = 0xffffffff00
gstreamer log:
NvRmStream: Channel submission failed (err=196623)
NvRmStream: Flush failed (err=196623)
NvMMLiteVideoEncDoWork:NvEncNvVicConvertSurfaceFormat failed
NvVideoEncTransferOutputBufferToBlock: DoWork failed line# 679
NvVideoEnc: NvVideoEncTransferOutputBufferToBlock TransferBufferToBlock failed Line=690
kernel log:
[219816.987868] falcon 15340000.vic: nvhost_ioctl_channel_submit: failed with err -22
[219817.020508] falcon 15340000.vic: nvhost_job_alloc: job is very large (96504), expect performance loss
We are not able to comment further. Would suggest make a simple test application so that we can reproduce it on developer kit.
请问下,nvhost_ioctl_channel_submint调用是属于哪个gstreamer库的?
库调用的错误,这个信息是否能够定位
SYS_write(2, "25:13:39.349595680 \033[334m 333\033[00m 0xfffe88058460 \033[31;01mERROR \033[00m \033[00m v4l2videoenc gstv4l2videoenc.c:1472:gst_v4l2_video_enc_loop:<nvv4l2h264enc0>\033[00m Failed to process output buffer\n", 199 <unfinished ...>
