i did like follow step
install cuda9.0.176
install nvidia driver for 1080,NVIDIA-Linux-x86_64-390.48.run
uninstall cuda8.0 /usr/local/cuda-8.0/bin/uninstall*.pl
sudo rm -r /usr/local/cuda-8.0
but when i run caffe with GPU,
ImportError:libcudart.so.8.0 cannot open shared object file. …
beside,i do many time like this,but the result are same error!
systerm path and environment variables already set to cuda-9.0
GTX1080 ubuntu16.04
so,i want to known how to generate the erroe?
anyone’s support is greatly appreciated!
thanks!
your caffe is built against CUDA 8
You cannot use CUDA 9 as a substitute/replacement for CUDA 8 in that case.
You either need to reinstall CUDA 8, or else rebuild your caffe against CUDA 9.
You can reinstall CUDA 8 without disturbing your CUDA 9 install. Use the CUDA 8 runfile installer, and deselect the option to install the driver.
thanks for your reply.
i can understand your mean,but i already set systerm path and environment variables to cuda-9.0
but caffe find cuda-8.0 still yet.
i also rebuild caffe src with cmake …
i do not know if i need to change the cuda path in .cmake and how to do that?
I download caffe from bvlc and rebuild caffe as guide
when run “make runtest”,get error
[==========] Running 2085 tests from 269 test cases.
[----------] Global test environment set-up.
[----------] 6 tests from GPUMathFunctionsTest/0, where TypeParam = float
[ RUN ] GPUMathFunctionsTest/0.TestScale
E0521 13:41:36.948266 26087 common.cpp:114] Cannot create Cublas handle. Cublas won’t be available.
E0521 13:41:36.952231 26087 common.cpp:121] Cannot create Curand generator. Curand won’t be available.
E0521 13:41:36.952272 26087 common.cpp:141] Curand not available. Skipping setting the curand seed.
F0521 13:41:36.952304 26087 syncedmem.hpp:22] Check failed: error == cudaSuccess (30 vs. 0) unknown error
*** Check failure stack trace: ***
@ 0x7f1889ada5cd google::LogMessage::Fail()
@ 0x7f1889adc433 google::LogMessage::SendToLog()
@ 0x7f1889ada15b google::LogMessage::Flush()
@ 0x7f1889adce1e google::LogMessageFatal::~LogMessageFatal()
@ 0x7f1887a17a11 caffe::SyncedMemory::mutable_cpu_data()
@ 0x7f1887a37700 caffe::Blob<>::Reshape()
@ 0x7f1887a37b7a caffe::Blob<>::Reshape()
@ 0x82f795 caffe::MathFunctionsTest<>::SetUp()
@ 0x8f6c53 testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0x8f0206 testing::Test::Run()
@ 0x8f03b8 testing::TestInfo::Run()
@ 0x8f0495 testing::TestCase::Run()
@ 0x8f176f testing::internal::UnitTestImpl::RunAllTests()
@ 0x8f1a93 testing::UnitTest::Run()
@ 0x46974d main
@ 0x7f1886c2e830 __libc_start_main
@ 0x470fc9 _start
@ (nil) (unknown)
Makefile:533: recipe for target ‘runtest’ failed
make: *** [runtest] Aborted (core dumped)
and
$ ldd libcaffe.so
linux-vdso.so.1 => (0x00007ffc9ebec000)
libcudart.so.9.0 => /usr/local/cuda-9.0/lib64/libcudart.so.9.0 (0x00007f29000a8000)
libcublas.so.9.0 => /usr/local/cuda-9.0/lib64/libcublas.so.9.0 (0x00007f28fcc72000)
libcurand.so.9.0 => /usr/local/cuda-9.0/lib64/libcurand.so.9.0 (0x00007f28f8d0e000)
libglog.so.0 => /usr/lib/x86_64-linux-gnu/libglog.so.0 (0x00007f28f8adf000)
libgflags.so.2 => /usr/lib/x86_64-linux-gnu/libgflags.so.2 (0x00007f28f88be000)
libprotobuf.so.9 => /usr/lib/x86_64-linux-gnu/libprotobuf.so.9 (0x00007f28f85a0000)
libboost_system.so.1.58.0 => /usr/lib/x86_64-linux-gnu/libboost_system.so.1.58.0 (0x00007f28f839c000)
libboost_filesystem.so.1.58.0 => /usr/lib/x86_64-linux-gnu/libboost_filesystem.so.1.58.0 (0x00007f28f8184000)
libhdf5_serial_hl.so.10 => /usr/lib/x86_64-linux-gnu/libhdf5_serial_hl.so.10 (0x00007f28f7f64000)
libhdf5_serial.so.10 => /usr/lib/x86_64-linux-gnu/libhdf5_serial.so.10 (0x00007f28f7ac7000)
libleveldb.so.1 => /usr/lib/x86_64-linux-gnu/libleveldb.so.1 (0x00007f28f786d000)
libopencv_core.so.2.4 => /usr/lib/x86_64-linux-gnu/libopencv_core.so.2.4 (0x00007f28f7443000)
libopencv_highgui.so.2.4 => /usr/lib/x86_64-linux-gnu/libopencv_highgui.so.2.4 (0x00007f28f71fa000)
libopencv_imgproc.so.2.4 => /usr/lib/x86_64-linux-gnu/libopencv_imgproc.so.2.4 (0x00007f28f6d6f000)
libboost_thread.so.1.58.0 => /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.58.0 (0x00007f28f6b49000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f28f67c7000)
libcblas.so.3 => /usr/lib/libcblas.so.3 (0x00007f28f65a5000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f28f629c000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f28f6086000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f28f5e69000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f28f5a9f000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f28f589b000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f28f5693000)
libunwind.so.8 => /usr/lib/x86_64-linux-gnu/libunwind.so.8 (0x00007f28f5478000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f28f525e000)
libsz.so.2 => /usr/lib/x86_64-linux-gnu/libsz.so.2 (0x00007f28f505b000)
libsnappy.so.1 => /usr/lib/x86_64-linux-gnu/libsnappy.so.1 (0x00007f28f4e53000)
libGL.so.1 => /usr/lib/nvidia-384/libGL.so.1 (0x00007f28f4baf000)
libtbb.so.2 => /usr/lib/x86_64-linux-gnu/libtbb.so.2 (0x00007f28f4972000)
libjpeg.so.8 => /usr/lib/x86_64-linux-gnu/libjpeg.so.8 (0x00007f28f4719000)
libpng12.so.0 => /lib/x86_64-linux-gnu/libpng12.so.0 (0x00007f28f44f4000)
libtiff.so.5 => /usr/lib/x86_64-linux-gnu/libtiff.so.5 (0x00007f28f4280000)
libjasper.so.1 => /usr/lib/x86_64-linux-gnu/libjasper.so.1 (0x00007f28f402b000)
libIlmImf-2_2.so.22 => /usr/lib/x86_64-linux-gnu/libIlmImf-2_2.so.22 (0x00007f28f3b5d000)
libHalf.so.12 => /usr/lib/x86_64-linux-gnu/libHalf.so.12 (0x00007f28f391a000)
libgtk-x11-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0 (0x00007f28f32cf000)
libgdk-x11-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgdk-x11-2.0.so.0 (0x00007f28f301a000)
libgobject-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007f28f2dc7000)
libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f28f2ab6000)
libgtkglext-x11-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libgtkglext-x11-1.0.so.0 (0x00007f28f28b2000)
libgdkglext-x11-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libgdkglext-x11-1.0.so.0 (0x00007f28f264e000)
libdc1394.so.22 => /usr/lib/x86_64-linux-gnu/libdc1394.so.22 (0x00007f28f23d8000)
libv4l1.so.0 => /usr/lib/x86_64-linux-gnu/libv4l1.so.0 (0x00007f28f21d2000)
libavcodec-ffmpeg.so.56 => /usr/lib/x86_64-linux-gnu/libavcodec-ffmpeg.so.56 (0x00007f28f0da2000)
libavformat-ffmpeg.so.56 => /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56 (0x00007f28f09a4000)
libavutil-ffmpeg.so.54 => /usr/lib/x86_64-linux-gnu/libavutil-ffmpeg.so.54 (0x00007f28f0735000)
libswscale-ffmpeg.so.3 => /usr/lib/x86_64-linux-gnu/libswscale-ffmpeg.so.3 (0x00007f28f04a6000)
/lib64/ld-linux-x86-64.so.2 (0x00007f2900a53000)
libatlas.so.3 => /usr/lib/libatlas.so.3 (0x00007f28eff08000)
libgfortran.so.3 => /usr/lib/x86_64-linux-gnu/libgfortran.so.3 (0x00007f28efbdd000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f28ef9bb000)
libaec.so.0 => /usr/lib/x86_64-linux-gnu/libaec.so.0 (0x00007f28ef7b3000)
libGLX.so.0 => /usr/lib/nvidia-384/libGLX.so.0 (0x00007f28ef583000)
libGLdispatch.so.0 => /usr/lib/nvidia-384/libGLdispatch.so.0 (0x00007f28ef2b5000)
libjbig.so.0 => /usr/lib/x86_64-linux-gnu/libjbig.so.0 (0x00007f28ef0a7000)
libIex-2_2.so.12 => /usr/lib/x86_64-linux-gnu/libIex-2_2.so.12 (0x00007f28eee89000)
libIlmThread-2_2.so.12 => /usr/lib/x86_64-linux-gnu/libIlmThread-2_2.so.12 (0x00007f28eec82000)
libgmodule-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0 (0x00007f28eea7e000)
libpangocairo-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0 (0x00007f28ee871000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f28ee537000)
libXfixes.so.3 => /usr/lib/x86_64-linux-gnu/libXfixes.so.3 (0x00007f28ee331000)
libatk-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0 (0x00007f28ee10c000)
libcairo.so.2 => /usr/lib/x86_64-linux-gnu/libcairo.so.2 (0x00007f28eddf8000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0 (0x00007f28edbd6000)
libgio-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0 (0x00007f28ed84e000)
libpangoft2-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0 (0x00007f28ed638000)
libpango-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0 (0x00007f28ed3ec000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f28ed1a9000)
libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f28ecf9f000)
libXinerama.so.1 => /usr/lib/x86_64-linux-gnu/libXinerama.so.1 (0x00007f28ecd9c000)
libXi.so.6 => /usr/lib/x86_64-linux-gnu/libXi.so.6 (0x00007f28ecb8c000)
libXrandr.so.2 => /usr/lib/x86_64-linux-gnu/libXrandr.so.2 (0x00007f28ec981000)
libXcursor.so.1 => /usr/lib/x86_64-linux-gnu/libXcursor.so.1 (0x00007f28ec777000)
libXcomposite.so.1 => /usr/lib/x86_64-linux-gnu/libXcomposite.so.1 (0x00007f28ec574000)
libXdamage.so.1 => /usr/lib/x86_64-linux-gnu/libXdamage.so.1 (0x00007f28ec371000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f28ec15f000)
libffi.so.6 => /usr/lib/x86_64-linux-gnu/libffi.so.6 (0x00007f28ebf57000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f28ebce7000)
libGLU.so.1 => /usr/lib/x86_64-linux-gnu/libGLU.so.1 (0x00007f28eba78000)
libXmu.so.6 => /usr/lib/x86_64-linux-gnu/libXmu.so.6 (0x00007f28eb85f000)
libpangox-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libpangox-1.0.so.0 (0x00007f28eb63f000)
libraw1394.so.11 => /usr/lib/x86_64-linux-gnu/libraw1394.so.11 (0x00007f28eb430000)
libusb-1.0.so.0 => /lib/x86_64-linux-gnu/libusb-1.0.so.0 (0x00007f28eb218000)
libv4l2.so.0 => /usr/lib/x86_64-linux-gnu/libv4l2.so.0 (0x00007f28eb00a000)
libswresample-ffmpeg.so.1 => /usr/lib/x86_64-linux-gnu/libswresample-ffmpeg.so.1 (0x00007f28eaded000)
libva.so.1 => /usr/lib/x86_64-linux-gnu/libva.so.1 (0x00007f28eabd1000)
libzvbi.so.0 => /usr/lib/x86_64-linux-gnu/libzvbi.so.0 (0x00007f28ea946000)
libxvidcore.so.4 => /usr/lib/x86_64-linux-gnu/libxvidcore.so.4 (0x00007f28ea632000)
libx265.so.79 => /usr/lib/x86_64-linux-gnu/libx265.so.79 (0x00007f28e9a13000)
libx264.so.148 => /usr/lib/x86_64-linux-gnu/libx264.so.148 (0x00007f28e966f000)
libwebp.so.5 => /usr/lib/x86_64-linux-gnu/libwebp.so.5 (0x00007f28e9413000)
libwavpack.so.1 => /usr/lib/x86_64-linux-gnu/libwavpack.so.1 (0x00007f28e91ea000)
libvpx.so.3 => /usr/lib/x86_64-linux-gnu/libvpx.so.3 (0x00007f28e8dc6000)
libvorbisenc.so.2 => /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2 (0x00007f28e8b1d000)
libvorbis.so.0 => /usr/lib/x86_64-linux-gnu/libvorbis.so.0 (0x00007f28e88f2000)
libtwolame.so.0 => /usr/lib/x86_64-linux-gnu/libtwolame.so.0 (0x00007f28e86cf000)
libtheoraenc.so.1 => /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1 (0x00007f28e8490000)
libtheoradec.so.1 => /usr/lib/x86_64-linux-gnu/libtheoradec.so.1 (0x00007f28e8276000)
libspeex.so.1 => /usr/lib/x86_64-linux-gnu/libspeex.so.1 (0x00007f28e805d000)
libshine.so.3 => /usr/lib/x86_64-linux-gnu/libshine.so.3 (0x00007f28e7e50000)
libschroedinger-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libschroedinger-1.0.so.0 (0x00007f28e7b7b000)
libopus.so.0 => /usr/lib/x86_64-linux-gnu/libopus.so.0 (0x00007f28e7931000)
libopenjpeg.so.5 => /usr/lib/x86_64-linux-gnu/libopenjpeg.so.5 (0x00007f28e770e000)
libmp3lame.so.0 => /usr/lib/x86_64-linux-gnu/libmp3lame.so.0 (0x00007f28e7499000)
libgsm.so.1 => /usr/lib/x86_64-linux-gnu/libgsm.so.1 (0x00007f28e728b000)
libcrystalhd.so.3 => /usr/lib/x86_64-linux-gnu/libcrystalhd.so.3 (0x00007f28e7070000)
libssh-gcrypt.so.4 => /usr/lib/x86_64-linux-gnu/libssh-gcrypt.so.4 (0x00007f28e6e27000)
librtmp.so.1 => /usr/lib/x86_64-linux-gnu/librtmp.so.1 (0x00007f28e6c0b000)
libmodplug.so.1 => /usr/lib/x86_64-linux-gnu/libmodplug.so.1 (0x00007f28e6880000)
libgme.so.0 => /usr/lib/x86_64-linux-gnu/libgme.so.0 (0x00007f28e6632000)
libbluray.so.1 => /usr/lib/x86_64-linux-gnu/libbluray.so.1 (0x00007f28e63e9000)
libgnutls.so.30 => /usr/lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007f28e60b9000)
libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007f28e5ea9000)
libquadmath.so.0 => /usr/lib/x86_64-linux-gnu/libquadmath.so.0 (0x00007f28e5c6a000)
libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f28e59c0000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f28e579e000)
libpixman-1.so.0 => /usr/lib/x86_64-linux-gnu/libpixman-1.so.0 (0x00007f28e54f6000)
libxcb-shm.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x00007f28e52f2000)
libxcb-render.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-render.so.0 (0x00007f28e50e8000)
libselinux.so.1 => /lib/x86_64-linux-gnu/libselinux.so.1 (0x00007f28e4ec6000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f28e4cab000)
libharfbuzz.so.0 => /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f28e4a4d000)
libthai.so.0 => /usr/lib/x86_64-linux-gnu/libthai.so.0 (0x00007f28e4844000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f28e461b000)
libXt.so.6 => /usr/lib/x86_64-linux-gnu/libXt.so.6 (0x00007f28e43b2000)
libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x00007f2900c04000)
libv4lconvert.so.0 => /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0 (0x00007f28e4138000)
libsoxr.so.0 => /usr/lib/x86_64-linux-gnu/libsoxr.so.0 (0x00007f28e3ed3000)
libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f28e3cc8000)
libogg.so.0 => /usr/lib/x86_64-linux-gnu/libogg.so.0 (0x00007f28e3abf000)
liborc-0.4.so.0 => /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0 (0x00007f28e383f000)
libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f28e355e000)
libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007f28e3314000)
libhogweed.so.4 => /usr/lib/x86_64-linux-gnu/libhogweed.so.4 (0x00007f28e30e1000)
libnettle.so.6 => /usr/lib/x86_64-linux-gnu/libnettle.so.6 (0x00007f28e2eab000)
libgmp.so.10 => /usr/lib/x86_64-linux-gnu/libgmp.so.10 (0x00007f28e2c2b000)
libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2 (0x00007f28e2870000)
libp11-kit.so.0 => /usr/lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007f28e260c000)
libidn.so.11 => /usr/lib/x86_64-linux-gnu/libidn.so.11 (0x00007f28e23d9000)
libtasn1.so.6 => /usr/lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007f28e21c6000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f28e1fc2000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f28e1dbc000)
libgraphite2.so.3 => /usr/lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f28e1b96000)
libdatrie.so.1 => /usr/lib/x86_64-linux-gnu/libdatrie.so.1 (0x00007f28e198e000)
libSM.so.6 => /usr/lib/x86_64-linux-gnu/libSM.so.6 (0x00007f28e1786000)
libICE.so.6 => /usr/lib/x86_64-linux-gnu/libICE.so.6 (0x00007f28e156c000)
libgomp.so.1 => /usr/lib/x86_64-linux-gnu/libgomp.so.1 (0x00007f28e134a000)
libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f28e1136000)
libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007f28e0e64000)
libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007f28e0c35000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007f28e0a31000)
libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007f28e0826000)
libicuuc.so.55 => /usr/lib/x86_64-linux-gnu/libicuuc.so.55 (0x00007f28e0492000)
libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f28e028d000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007f28e0089000)
libicudata.so.55 => /usr/lib/x86_64-linux-gnu/libicudata.so.55 (0x00007f28de5d2000)
what happen?
now you are getting errors because CUDA or the GPU driver is not installed correctly. First you should verify your CUDA install using the instructions in the linux install guide.
thanks for your reply!
i have know which case this error!
when i run ‘DriveInstall_5.0.5.0bL_SDK_b3.run’ to setup Cross-Compiling for the NVIDIA DRIVE Platform,it will install GPU Drive 384,but the GPU need higher version Drive,so it actually result the error.
thanks
