Hello, I have been studying this thread ( https://devtalk.nvidia.com/default/topic/827737/system-with-cuda-7-installed-giving-error-for-libcudart-so-6-5/ ) but I so far cannot fix my own situation based off of what is written there.
I am on Ubuntu 16.04 and am using CUDA 8. I am attempting to make Caffe. Following their instructions I run:
make all
make test
make runtest
Everything works quite fine until the runtest, where I get the following error:
user@cuda:~/caffe-master$ make runtest -j $(($(nproc) + 1))
.build_release/tools/caffe
.build_release/tools/caffe: error while loading shared libraries: libcudart.so.8.0: cannot open shared object file: No such file or directory
Makefile:523: recipe for target 'runtest' failed
make: *** [runtest] Error 127
I have located the missing library:
user@cuda:~/caffe-master$ ls /usr/local/cuda/lib64 | grep libcudart
libcudart.so
libcudart.so.8.0
libcudart.so.8.0.27
libcudart_static.a
I have the following in my .profile:
PATH="$PATH:/usr/local/cuda/bin";export PATH
LD_LIBRARY_PATH="/usr/local/cuda/lib64"
The output of nvcc --version is:
user@cuda:~/caffe-master$ nvcc --version
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Wed_May__4_21:01:56_CDT_2016
Cuda compilation tools, release 8.0, V8.0.26
I don’t understand why I am getting this error given the information above. I might be missing something trivial. Either way I would greatly appreciate some guidance if anyone has an idea of what the issue is here. Have been banging my head against the wall for a while now.
You seem to be missing something here:
I think that last line should be:
LD_LIBRARY_PATH="/usr/local/cuda/lib64"; export LD_LIBRARY_PATH
In bash, doing this:
only sets that variable for the duration of any commands on that command line
Before making any changes, you could verify that LD_LIBRARY_PATH not set is the issue by testing what is the output of:
echo $LD_LIBRARY_PATH
If it doesn’t include the path to cuda/lib64 then that is your problem.
Usually what I use is:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/lib64
Hello, txbob. Thank you for the reply. The output of echo $LD_LIBRARY_PATH was correct:
user@cuda:~/caffe-master$ echo $LD_LIBRARY_PATH
I did go ahead and append
to the end of my LD_LIBRARY_PATH variable in my .profile to be sure though.
Unfortunately I still have an issue getting through the runtest and the errors just are not adding up for me - I have followed the install instructions closely. I am able to start the runtest, and it runs for a brief while before aborting with a segmentation or memory error, although the error does not happen at a consistent point in the process. I am trying to figure out if this has to do with my install or is perhaps some kind of hardware issue.
Here is a representative error I get:
[----------] 8 tests from RMSPropSolverTest/3, where TypeParam = caffe::GPUDevice<double>
[ RUN ] RMSPropSolverTest/3.TestRMSPropLeastSquaresUpdateWithWeightDecay
*** Aborted at 1473439642 (unix time) try "date -d @1473439642" if you are using GNU date ***
PC: @ 0x7f5fac0ce677 (unknown)
make: *** [runtest] Segmentation fault (core dumped)
And a longer one in another case:
[code]
*** Aborted at 1473439152 (unix time) try “date -d @1473439152 ” if you are using GNU date ***
PC: @ 0x7ff59f98267c (unknown)
*** Error in `.build_release/test/test_all.testbin’: malloc(): memory corruption: 0x00000000168e7d50 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x77725)[0x7ff59f89a725]
/lib/x86_64-linux-gnu/libc.so.6(+0x819be)[0x7ff59f8a49be]
/lib/x86_64-linux-gnu/libc.so.6(__libc_malloc+0x54)[0x7ff59f8a65a4]
/lib/x86_64-linux-gnu/libc.so.6(+0x6dc8d)[0x7ff59f890c8d]
/usr/lib/x86_64-linux-gnu/libGL.so.1(+0xabd07)[0x7ff59e92fd07]
======= Memory map: ========
00400000-00ae8000 r-xp 00000000 08:01 9177594 /home/tom/caffe-master/.build_release/test/test_all.testbin
00ce8000-00d4b000 r–p 006e8000 08:01 9177594 /home/tom/caffe-master/.build_release/test/test_all.testbin
00d4b000-00d4d000 rw-p 0074b000 08:01 9177594 /home/tom/caffe-master/.build_release/test/test_all.testbin
012fa000-1697f000 rw-p 00000000 00:00 0 [heap]
200000000-200100000 rw-s 5f17a000 00:06 623 /dev/nvidiactl
200100000-204300000 —p 00000000 00:00 0
204300000-204400000 rw-s 27b0c6000 00:06 623 /dev/nvidiactl
204400000-204500000 —p 00000000 00:00 0
204500000-204600000 rw-s 24bccf000 00:06 623 /dev/nvidiactl
204600000-204700000 —p 00000000 00:00 0
204700000-204800000 rw-s 279fe1000 00:06 623 /dev/nvidiactl
204800000-2048e0000 rw-s 26c5ec000 00:06 623 /dev/nvidiactl
2048e0000-2049e0000 rw-s 00000000 00:05 55482 /dev/zero (deleted)
2049e0000-204ae0000 rw-s 00000000 00:05 55483 /dev/zero (deleted)
204ae0000-204be0000 rw-s 00000000 00:05 55484 /dev/zero (deleted)
204be0000-204ce0000 rw-s 349d08000 00:06 623 /dev/nvidiactl
204ce0000-205520000 —p 00000000 00:00 0
205520000-205620000 rw-s 28833e000 00:06 623 /dev/nvidiactl
205620000-205720000 —p 00000000 00:00 0
205720000-205820000 rw-s 27c69c000 00:06 623 /dev/nvidiactl
205820000-e04000000 —p 00000000 00:00 0
7ff550000000-7ff5500ce000 rw-p 00000000 00:00 0
7ff5500ce000-7ff554000000 —p 00000000 00:00 0
7ff558000000-7ff55c000000 rw-p 00000000 00:00 0
7ff55f0a5000-7ff55f0a6000 —p 00000000 00:00 0
7ff55f0a6000-7ff560000000 rw-p 00000000 00:00 0
7ff560000000-7ff560021000 rw-p 00000000 00:00 0
7ff560021000-7ff564000000 —p 00000000 00:00 0
7ff564000000-7ff564021000 rw-p 00000000 00:00 0
7ff564021000-7ff568000000 —p 00000000 00:00 0
7ff568000000-7ff568021000 rw-p 00000000 00:00 0
7ff568021000-7ff56c000000 —p 00000000 00:00 0
7ff56c717000-7ff56cb17000 rw-s 262e80000 00:06 623 /dev/nvidiactl
7ff56cb17000-7ff56d1c4000 rw-p 00000000 00:00 0
7ff56d471000-7ff56d871000 rw-s 5f0e8000 00:06 623 /dev/nvidiactl
7ff56d871000-7ff56d872000 —p 00000000 00:00 0
7ff56d872000-7ff56e072000 rw-p 00000000 00:00 0
7ff56e072000-7ff56e073000 —p 00000000 00:00 0
7ff56e073000-7ff56ec6f000 rw-p 00000000 00:00 0
7ff56ecc7000-7ff56ed1f000 rw-p 00000000 00:00 0
7ff56ed1f000-7ff56ed6b000 rw-s 1acba3000 00:06 623 /dev/nvidiactl
7ff56ed6b000-7ff56ee6b000 rw-s 1acaa2000 00:06 623 /dev/nvidiactl
7ff56ee6b000-7ff56ef6b000 rw-s 24be9f000 00:06 623 /dev/nvidiactl
7ff56ef6b000-7ff56f06b000 rw-s 24c799000 00:06 623 /dev/nvidiactl
7ff56f06b000-7ff56f435000 rw-p 00000000 00:00 0
7ff56f438000-7ff56f478000 rw-p 00000000 00:00 0
7ff56f478000-7ff56f479000 rw-s bff62000 00:06 628 /dev/nvidia1
7ff56f479000-7ff56f47a000 rw-s 28709e000 00:06 623 /dev/nvidiactl
7ff56f47a000-7ff56f47e000 rw-s 262e79000 00:06 623 /dev/nvidiactl
7ff56f47e000-7ff56f47f000 rw-s bff61000 00:06 628 /dev/nvidia1
7ff56f47f000-7ff56f527000 rw-p 00000000 00:00 0
7ff56f527000-7ff56f7ff000 r–p 00000000 08:01 17044229 /usr/lib/locale/locale-archive
7ff56f7ff000-7ff56f800000 —p 00000000 00:00 0
7ff56f800000-7ff570000000 rw-p 00000000 00:00 0
7ff570000000-7ff570021000 rw-p 00000000 00:00 0
7ff570021000-7ff574000000 —p 00000000 00:00 0
7ff574000000-7ff574400000 rw-s 24bfa6000 00:06 623 /dev/nvidiactl
7ff574400000-7ff574800000 rw-s 249b97000 00:06 623 /dev/nvidiactl
7ff574800000-7ff574c00000 rw-s 27f074000 00:06 623 /dev/nvidiactl
7ff574c00000-7ff575000000 rw-s 5f1c1000 00:06 623 /dev/nvidiactl
7ff575000000-7ff575400000 rw-s 25de27000 00:06 623 /dev/nvidiactl
7ff575400000-7ff575800000 rw-s 26bd10000 00:06 623 /dev/nvidiactl
7ff575800000-7ff575c00000 rw-s 34b5f5000 00:06 623 /dev/nvidiactl
7ff575c00000-7ff576000000 rw-s 5f07e000 00:06 623 /dev/nvidiactl
7ff576000000-7ff576400000 rw-s 28812f000 00:06 623 /dev/nvidiactl
7ff576400000-7ff576800000 rw-s 26c4bf000 00:06 623 /dev/nvidiactl
7ff576800000-7ff576c00000 rw-s 264d8a000 00:06 623 /dev/nvidiactl
7ff576c00000-7ff577000000 rw-s 5f028000 00:06 623 /dev/nvidiactl
7ff577000000-7ff577400000 rw-s 264cc2000 00:06 623 /dev/nvidiactl
7ff577400000-7ff577800000 rw-s 279c73000 00:06 623 /dev/nvidiactl
7ff577800000-7ff577c00000 rw-s 2499f4000 00:06 623 /dev/nvidiactl
7ff577c00000-7ff578000000 rw-s 65fa8000 00:06 623 /dev/nvidiactl
7ff578000000-7ff578021000 rw-p 00000000 00:00 0
7ff578021000-7ff57c000000 —p 00000000 00:00 0
7ff57c000000-7ff57c004000 rw-s 5f0e4000 00:06 623 /dev/nvidiactl
7ff57c004000-7ff57c134000 rw-p 00000000 00:00 0
7ff57c134000-7ff57c13b000 r–s 00000000 08:01 17041679 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
7ff57c13b000-7ff57c27b000 rw-p 00000000 00:00 0
7ff57c27b000-7ff57c37b000 rw-s 2498de000 00:06 623 /dev/nvidiactl
7ff57c37b000-7ff57c37c000 —p 00000000 00:00 0
7ff57c37c000-7ff57cb7c000 rw-p 00000000 00:00 0
7ff57cb7c000-7ff57cbc3000 r-xp 00000000 08:01 17047847 /usr/lib/x86_64-linux-gnu/libnvidia-fatbinaryloader.so.361.77
7ff57cbc3000-7ff57cdc2000 —p 00047000 08:01 17047847 /usr/lib/x86_64-linux-gnu/libnvidia-fatbinaryloader.so.361.77
7ff57cdc2000-7ff57cdcc000 rw-p 00046000 08:01 17047847 /usr/lib/x86_64-linux-gnu/libnvidia-fatbinaryloader.so.361.77
7ff57cdcc000-7ff57cdcd000 rw-p 00000000 00:00 0
7ff57cdcd000-7ff57d471000 r-xp 00000000 08:01 17047825 /usr/lib/x86_64-linux-gnu/libcuda.so.361.77
7ff57d471000-7ff57d671000 —p 006a4000 08:01 17047825 /usr/lib/x86_64-linux-gnu/libcuda.so.361.77
7ff57d671000-7ff57d789000 rw-p 006a4000 08:01 17047825 /usr/lib/x86_64-linux-gnu/libcuda.so.361.77
7ff57d789000-7ff57d795000 rw-p 00000000 00:00 0
7ff57d795000-7ff57d796000 —p 00000000 00:00 0
7ff57d796000-7ff57df96000 rw-p 00000000 00:00 0
7ff57df96000-7ff57f84c000 r-xp 00000000 08:01 17045228 /usr/lib/x86_64-linux-gnu/libicudata.so.55.1
7ff57f84c000-7ff57fa4b000 —p 018b6000 08:01 17045228 /usr/lib/x86_64-linux-gnu/libicudata.so.55.1
7ff57fa4b000-7ff57fa4c000 r–p 018b5000 08:01 17045228 /usr/lib/x86_64-linux-gnu/libicudata.so.55.1
7ff57fa4c000-7ff57fa4d000 rw-p 018b6000 08:01 17045228 /usr/lib/x86_64-linux-gnu/libicudata.so.55.1
7ff57fa4d000-7ff57fa50000 r-xp 00000000 08:01 20189315 /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7ff57fa50000-7ff57fc4f000 —p 00003000 08:01 20189315 /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7ff57fc4f000-7ff57fc50000 r–p 00002000 08:01 20189315 /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7ff57fc50000-7ff57fc51000 rw-p 00003000 08:01 20189315 /lib/x86_64-linux-gnu/libkeyutils.so.1.5
7ff57fc51000-7ff57fc55000 r-xp 00000000 08:01 20185102 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7ff57fc55000-7ff57fe54000 —p 00004000 08:01 20185102 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7ff57fe54000-7ff57fe55000 r–p 00003000 08:01 20185102 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7ff57fe55000-7ff57fe56000 rw-p 00004000 08:01 20185102 /lib/x86_64-linux-gnu/libuuid.so.1.3.0
7ff57fe56000-7ff57ffd5000 r-xp 00000000 08:01 17045224 /usr/lib/x86_64-linux-gnu/libicuuc.so.55.1
7ff57ffd5000-7ff5801d5000 —p 0017f000 08:01 17045224 /usr/lib/x86_64-linux-gnu/libicuuc.so.55.1
7ff5801d5000-7ff5801e5000 r–p 0017f000 08:01 17045224 /usr/lib/x86_64-linux-gnu/libicuuc.so.55.1
7ff5801e5000-7ff5801e6000 rw-p 0018f000 08:01 17045224 /usr/lib/x86_64-linux-gnu/libicuuc.so.55.1
7ff5801e6000-7ff5801ea000 rw-p 00000000 00:00 0
7ff5801ea000-7ff5801f4000 r-xp 00000000 08:01 17045180 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7ff5801f4000-7ff5803f3000 —p 0000a000 08:01 17045180 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7ff5803f3000-7ff5803f4000 r–p 00009000 08:01 17045180 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7ff5803f4000-7ff5803f5000 rw-p 0000a000 08:01 17045180 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
7ff5803f5000-7ff5803f8000 r-xp 00000000 08:01 20185599 /lib/x86_64-linux-gnu/libcom_err.so.2.1
7ff5803f8000-7ff5805f7000 —p 00003000 08:01 20185599 /lib/x86_64-linux-gnu/libcom_err.so.2.1
7ff5805f7000-7ff5805f8000 r–p 00002000 08:01 20185599 /lib/x86_64-linux-gnu/libcom_err.so.2.1
7ff5805f8000-7ff5805f9000 rw-p 00003000 08:01 20185599 /lib/x86_64-linux-gnu/libcom_err.so.2.1
7ff5805f9000-7ff580625000 r-xp 00000000 08:01 17045182 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7ff580625000-7ff580824000 —p 0002c000 08:01 17045182 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7ff580824000-7ff580826000 r–p 0002b000 08:01 17045182 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7ff580826000-7ff580827000 rw-p 0002d000 08:01 17045182 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
7ff580827000-7ff580828000 rw-p 00000000 00:00 0
7ff580828000-7ff5808eb000 r-xp 00000000 08:01 17045185 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7ff5808eb000-7ff580aeb000 —p 000c3000 08:01 17045185 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7ff580aeb000-7ff580af8000 r–p 000c3000 08:01 17045185 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7ff580af8000-7ff580afa000 rw-p 000d0000 08:01 17045185 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
7ff580afa000-7ff580b0c000 r-xp 00000000 08:01 20185622 /lib/x86_64-linux-gnu/libgpg-error.so.0.17.0
7ff580b0c000-7ff580d0c000 —p 00012000 08:01 20185622 /lib/x86_64-linux-gnu/libgpg-error.so.0.17.0
7ff580d0c000-7ff580d0d000 r–p 00012000 08:01 20185622 /lib/x86_64-linux-gnu/libgpg-error.so.0.17.0
7ff580d0d000-7ff580d0e000 rw-p 00013000 08:01 20185622 /lib/x86_64-linux-gnu/libgpg-error.so.0.17.0
7ff580d0e000-7ff580d2f000 r-xp 00000000 08:01 17045520 /usr/lib/x86_64-linux-gnu/libgomp.so.1.0.0
7ff580d2f000-7ff580f2e000 —p 00021000 08:01 17045520 /usr/lib/x86_64-linux-gnu/libgomp.so.1.0.0
7ff580f2e000-7ff580f2f000 r–p 00020000 08:01 17045520 /usr/lib/x86_64-linux-gnu/libgomp.so.1.0.0
7ff580f2f000-7ff580f30000 rw-p 00021000 08:01 17045520 /usr/lib/x86_64-linux-gnu/libgomp.so.1.0.0
7ff580f30000-7ff580f46000 r-xp 00000000 08:01 17047399 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7ff580f46000-7ff581145000 —p 00016000 08:01 17047399 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7ff581145000-7ff581146000 r–p 00015000 08:01 17047399 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7ff581146000-7ff581147000 rw-p 00016000 08:01 17047399 /usr/lib/x86_64-linux-gnu/libICE.so.6.3.0
7ff581147000-7ff58114a000 rw-p 00000000 00:00 0
7ff58114a000-7ff581151000 r-xp 00000000 08:01 17047440 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7ff581151000-7ff581350000 —p 00007000 08:01 17047440 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7ff581350000-7ff581351000 r–p 00006000 08:01 17047440 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7ff581351000-7ff581352000 rw-p 00007000 08:01 17047440 /usr/lib/x86_64-linux-gnu/libSM.so.6.0.1
7ff581352000-7ff581358000 r-xp 00000000 08:01 17047462 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.3.3
7ff581358000-7ff581558000 —p 00006000 08:01 17047462 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.3.3
7ff581558000-7ff581559000 r–p 00006000 08:01 17047462 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.3.3
7ff581559000-7ff58155a000 rw-p 00007000 08:01 17047462 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.3.3
7ff58155a000-7ff58157d000 r-xp 00000000 08:01 17047615 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.0.1
7ff58157d000-7ff58177c000 —p 00023000 08:01 17047615 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.0.1
7ff58177c000-7ff58177e000 r–p 00022000 08:01 17047615 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.0.1
7ff58177e000-7ff58177f000 rw-p 00024000 08:01 17047615 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.0.1
7ff58177f000-7ff581784000 r-xp 00000000 08:01 17044995 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7ff581784000-7ff581983000 —p 00005000 08:01 17044995 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7ff581983000-7ff581984000 r–p 00004000 08:01 17044995 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7ff581984000-7ff581985000 rw-p 00005000 08:01 17044995 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
7ff581985000-7ff581987000 r-xp 00000000 08:01 17044993 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7ff581987000-7ff581b87000 —p 00002000 08:01 17044993 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7ff581b87000-7ff581b88000 r–p 00002000 08:01 17044993 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7ff581b88000-7ff581b89000 rw-p 00003000 08:01 17044993 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
7ff581b89000-7ff581bc7000 r-xp 00000000 08:01 17048069 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7ff581bc7000-7ff581dc6000 —p 0003e000 08:01 17048069 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7ff581dc6000-7ff581dc7000 r–p 0003d000 08:01 17048069 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7ff581dc7000-7ff581dc8000 rw-p 0003e000 08:01 17048069 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
7ff581dc8000-7ff581dd9000 r-xp 00000000 08:01 17041697 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.1
7ff581dd9000-7ff581fd9000 —p 00011000 08:01 17041697 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.1
7ff581fd9000-7ff581fda000 r–p 00011000 08:01 17041697 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.1
7ff581fda000-7ff581fdb000 rw-p 00012000 08:01 17041697 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.1
7ff581fdb000-7ff58200c000 r-xp 00000000 08:01 17039454 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.15
7ff58200c000-7ff58220c000 —p 00031000 08:01 17039454 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.15
7ff58220c000-7ff58220d000 r–p 00031000 08:01 17039454 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.15
7ff58220d000-7ff58220e000 rw-p 00032000 08:01 17039454 /usr/lib/x86_64-linux-gnu/libidn.so.11.6.15
7ff58220e000-7ff582267000 r-xp 00000000 08:01 17044753 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.1.0
7ff582267000-7ff582466000 —p 00059000 08:01 17044753 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.1.0
7ff582466000-7ff582470000 r–p 00058000 08:01 17044753 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.1.0
7ff582470000-7ff582472000 rw-p 00062000 08:01 17044753 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.1.0
7ff582472000-7ff582621000 r-xp 00000000 08:01 17039674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.3
7ff582621000-7ff582821000 —p 001af000 08:01 17039674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.3
7ff582821000-7ff582829000 r–p 001af000 08:01 17039674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.3
7ff582829000-7ff58282b000 rw-p 001b7000 08:01 17039674 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.3
7ff58282b000-7ff58282c000 rw-p 00000000 00:00 0
7ff58282c000-7ff5828ab000 r-xp 00000000 08:01 17041708 /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.0
7ff5828ab000-7ff582aaa000 —p 0007f000 08:01 17041708 /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.0
7ff582aaa000-7ff582aab000 r–p 0007e000 08:01 17041708 /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.0
7ff582aab000-7ff582aac000 rw-p 0007f000 08:01 17041708 /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.0
7ff582aac000-7ff582ae0000 r-xp 00000000 08:01 17041728 /usr/lib/x86_64-linux-gnu/libnettle.so.6.2
7ff582ae0000-7ff582cdf000 —p 00034000 08:01 17041728 /usr/lib/x86_64-linux-gnu/libnettle.so.6.2
7ff582cdf000-7ff582ce1000 r–p 00033000 08:01 17041728 /usr/lib/x86_64-linux-gnu/libnettle.so.6.2
7ff582ce1000-7ff582ce2000 rw-p 00035000 08:01 17041728 /usr/lib/x86_64-linux-gnu/libnettle.so.6.2
7ff582ce2000-7ff582d14000 r-xp 00000000 08:01 17041714 /usr/lib/x86_64-linux-gnu/libhogweed.so.4.2
7ff582d14000-7ff582f13000 —p 00032000 08:01 17041714 /usr/lib/x86_64-linux-gnu/libhogweed.so.4.2
7ff582f13000-7ff582f14000 r–p 00031000 08:01 17041714 /usr/lib/x86_64-linux-gnu/libhogweed.so.4.2
7ff582f14000-7ff582f15000 rw-p 00032000 08:01 17041714 /usr/lib/x86_64-linux-gnu/libhogweed.so.4.2
7ff582f15000-7ff582f5c000 r-xp 00000000 08:01 17045187 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7ff582f5c000-7ff58315b000 —p 00047000 08:01 17045187 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7ff58315b000-7ff58315d000 r–p 00046000 08:01 17045187 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7ff58315d000-7ff58315f000 rw-p 00048000 08:01 17045187 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
7ff58315f000-7ff583237000 r-xp 00000000 08:01 20185131 /lib/x86_64-linux-gnu/libgcrypt.so.20.0.5
7ff583237000-7ff583436000 —p 000d8000 08:01 20185131 /lib/x86_64-linux-gnu/libgcrypt.so.20.0.5
7ff583436000-7ff583437000 r–p 000d7000 08:01 20185131 /lib/x86_64-linux-gnu/libgcrypt.so.20.0.5
7ff583437000-7ff58343f000 rw-p 000d8000 08:01 20185131 /lib/x86_64-linux-gnu/libgcrypt.so.20.0.5
7ff58343f000-7ff583440000 rw-p 00000000 00:00 0
7ff583440000-7ff5834bb000 r-xp 00000000 08:01 17047434 /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0.25.0
7ff5834bb000-7ff5836ba000 —p 0007b000 08:01 17047434 /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0.25.0
7ff5836ba000-7ff5836bc000 r–p 0007a000 08:01 17047434 /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0.25.0
7ff5836bc000-7ff5836c0000 rw-p 0007c000 08:01 17047434 /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0.25.0
7ff5836c0000-7ff5836c7000 r-xp 00000000 08:01 17047403 /usr/lib/x86_64-linux-gnu/libogg.so.0.8.2
7ff5836c7000-7ff5838c7000 —p 00007000 08:01 17047403 /usr/lib/x86_64-linux-gnu/libogg.so.0.8.2
7ff5838c7000-7ff5838c8000 r–p 00007000 08:01 17047403 /usr/lib/x86_64-linux-gnu/libogg.so.0.8.2
7ff5838c8000-7ff5838c9000 rw-p 00008000 08:01 17047403 /usr/lib/x86_64-linux-gnu/libogg.so.0.8.2
7ff5838c9000-7ff5838d3000 r-xp 00000000 08:01 17045279 /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7ff5838d3000-7ff583ad2000 —p 0000a000 08:01 17045279 /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7ff583ad2000-7ff583ad3000 r–p 00009000 08:01 17045279 /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7ff583ad3000-7ff583ad4000 rw-p 0000a000 08:01 17045279 /usr/lib/x86_64-linux-gnu/libnuma.so.1.0.0
7ff583ad4000-7ff583b02000 r-xp 00000000 08:01 17047711 /usr/lib/x86_64-linux-gnu/libsoxr.so.0.1.1
7ff583b02000-7ff583d01000 —p 0002e000 08:01 17047711 /usr/lib/x86_64-linux-gnu/libsoxr.so.0.1.1
7ff583d01000-7ff583d03000 r–p 0002d000 08:01 17047711 /usr/lib/x86_64-linux-gnu/libsoxr.so.0.1.1
7ff583d03000-7ff583d04000 rw-p 0002f000 08:01 17047711 /usr/lib/x86_64-linux-gnu/libsoxr.so.0.1.1
7ff583d04000-7ff583d39000 rw-p 00000000 00:00 0
7ff583d39000-7ff583d5e000 r-xp 00000000 08:01 17047893 /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0.0.0
7ff583d5e000-7ff583f5e000 —p 00025000 08:01 17047893 /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0.0.0
7ff583f5e000-7ff583f60000 r–p 00025000 08:01 17047893 /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0.0.0
7ff583f60000-7ff583f61000 rw-p 00027000 08:01 17047893 /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0.0.0
7ff583f61000-7ff583fb3000 rw-p 00000000 00:00 0
7ff583fb3000-7ff584015000 r-xp 00000000 08:01 17047881 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7ff584015000-7ff584215000 —p 00062000 08:01 17047881 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7ff584215000-7ff584216000 r–p 00062000 08:01 17047881 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7ff584216000-7ff58421b000 rw-p 00063000 08:01 17047881 /usr/lib/x86_64-linux-gnu/libXt.so.6.0.0
7ff58421b000-7ff58421c000 rw-p 00000000 00:00 0
7ff58421c000-7ff584242000 r-xp 00000000 08:01 20185142 /lib/x86_64-linux-gnu/libexpat.so.1.6.0
7ff584242000-7ff584442000 —p 00026000 08:01 20185142 /lib/x86_64-linux-gnu/libexpat.so.1.6.0
7ff584442000-7ff584444000 r–p 00026000 08:01 20185142 /lib/x86_64-linux-gnu/libexpat.so.1.6.0
7ff584444000-7ff584445000 rw-p 00028000 08:01 20185142 /lib/x86_64-linux-gnu/libexpat.so.1.6.0
7ff584445000-7ff58444d000 r-xp 00000000 08:01 17047464 /usr/lib/x86_64-linux-gnu/libthai.so.0.2.4
7ff58444d000-7ff58464c000 —p 00008000 08:01 17047464 /usr/lib/x86_64-linux-gnu/libthai.so.0.2.4
7ff58464c000-7ff58464d000 r–p 00007000 08:01 17047464 /usr/lib/x86_64-linux-gnu/libthai.so.0.2.4
7ff58464d000-7ff58464e000 rw-p 00008000 08:01 17047464 /usr/lib/x86_64-linux-gnu/libthai.so.0.2.4
7ff58464e000-7ff5846aa000 r-xp 00000000 08:01 17039725 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.10000.1
7ff5846aa000-7ff5848aa000 —p 0005c000 08:01 17039725 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.10000.1
7ff5848aa000-7ff5848ab000 r–p 0005c000 08:01 17039725 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.10000.1
7ff5848ab000-7ff5848ac000 rw-p 0005d000 08:01 17039725 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.10000.1
7ff5848ac000-7ff5848c3000 r-xp 00000000 08:01 20185683 /lib/x86_64-linux-gnu/libresolv-2.23.so
7ff5848c3000-7ff584ac3000 —p 00017000 08:01 20185683 /lib/x86_64-linux-gnu/libresolv-2.23.so
7ff584ac3000-7ff584ac4000 r–p 00017000 08:01 20185683 /lib/x86_64-linux-gnu/libresolv-2.23.so
7ff584ac4000-7ff584ac5000 rw-p 00018000 08:01 20185683 /lib/x86_64-linux-gnu/libresolv-2.23.so
7ff584ac5000-7ff584ac7000 rw-p 00000000 00:00 0
7ff584ac7000-7ff584ae6000 r-xp 00000000 08:01 20185689 /lib/x86_64-linux-gnu/libselinux.so.1
7ff584ae6000-7ff584ce5000 —p 0001f000 08:01 20185689 /lib/x86_64-linux-gnu/libselinux.so.1
7ff584ce5000-7ff584ce6000 r–p 0001e000 08:01 20185689 /lib/x86_64-linux-gnu/libselinux.so.1
7ff584ce6000-7ff584ce7000 rw-p 0001f000 08:01 20185689 /lib/x86_64-linux-gnu/libselinux.so.1
7ff584ce7000-7ff584ce9000 rw-p 00000000 00:00 0
7ff584ce9000-7ff584cf1000 r-xp 00000000 08:01 17047609 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
7ff584cf1000-7ff584ef1000 —p 00008000 08:01 17047609 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
7ff584ef1000-7ff584ef2000 r–p 00008000 08:01 17047609 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
7ff584ef2000-7ff584ef3000 rw-p 00009000 08:01 17047609 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
7ff584ef3000-7ff584ef5000 r-xp 00000000 08:01 17047611 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
7ff584ef5000-7ff5850f5000 —p 00002000 08:01 17047611 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
7ff5850f5000-7ff5850f6000 r–p 00002000 08:01 17047611 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
7ff5850f6000-7ff5850f7000 rw-p 00003000 08:01 17047611 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
7ff5850f7000-7ff585196000 r-xp 00000000 08:01 17047607 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.33.6
7ff585196000-7ff585396000 —p 0009f000 08:01 17047607 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.33.6
7ff585396000-7ff58539e000 r–p 0009f000 08:01 17047607 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.33.6
7ff58539e000-7ff58539f000 rw-p 000a7000 08:01 17047607 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.33.6
7ff58539f000-7ff585443000 r-xp 00000000 08:01 17044293 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.12.1
7ff585443000-7ff585642000 —p 000a4000 08:01 17044293 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.12.1
7ff585642000-7ff585648000 r–p 000a3000 08:01 17044293 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.12.1
7ff585648000-7ff585649000 rw-p 000a9000 08:01 17044293 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.12.1
7ff585649000-7ff58566a000 r-xp 00000000 08:01 17044997 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7ff58566a000-7ff585869000 —p 00021000 08:01 17044997 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7ff585869000-7ff58586a000 r–p 00020000 08:01 17044997 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7ff58586a000-7ff58586b000 rw-p 00021000 08:01 17044997 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
7ff58586b000-7ff585994000 r-xp 00000000 08:01 17045502 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7ff585994000-7ff585b93000 —p 00129000 08:01 17045502 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7ff585b93000-7ff585b94000 r–p 00128000 08:01 17045502 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7ff585b94000-7ff585b96000 rw-p 00129000 08:01 17045502 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
7ff585b96000-7ff585f2d000 r-xp 00000000 08:01 17437070 /usr/lib/atlas-base/libatlas.so.3.0
7ff585f2d000-7ff58612d000 —p 00397000 08:01 17437070 /usr/lib/atlas-base/libatlas.so.3.0
7ff58612d000-7ff586134000 rw-p 00397000 08:01 17437070 /usr/lib/atlas-base/libatlas.so.3.0
7ff586134000-7ff586136000 r-xp 00000000 08:01 20185708 /lib/x86_64-linux-gnu/libutil-2.23.so
7ff586136000-7ff586335000 —p 00002000 08:01 20185708 /lib/x86_64-linux-gnu/libutil-2.23.so
7ff586335000-7ff586336000 r–p 00001000 08:01 20185708 /lib/x86_64-linux-gnu/libutil-2.23.so
7ff586336000-7ff586337000 rw-p 00002000 08:01 20185708 /lib/x86_64-linux-gnu/libutil-2.23.so
7ff586337000-7ff586346000 r-xp 00000000 08:01 20185591 /lib/x86_64-linux-gnu/libbz2.so.1.0.4
7ff586346000-7ff586545000 —p 0000f000 08:01 20185591 /lib/x86_64-linux-gnu/libbz2.so.1.0.4
7ff586545000-7ff586546000 r–p 0000e000 08:01 20185591 /lib/x86_64-linux-gnu/libbz2.so.1.0.4
7ff586546000-7ff586547000 rw-p 0000f000 08:01 20185591 /lib/x86_64-linux-gnu/libbz2.so.1.0.4
7ff586547000-7ff58666a000 r-xp 00000000 08:01 17041709 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.6.2
7ff58666a000-7ff586869000 —p 00123000 08:01 17041709 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.6.2
7ff586869000-7ff586874000 r–p 00122000 08:01 17041709 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.6.2
7ff586874000-7ff586876000 rw-p 0012d000 08:01 17041709 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.6.2
7ff586876000-7ff586877000 rw-p 00000000 00:00 0
7ff586877000-7ff5868be000 r-xp 00000000 08:01 17047758 /usr/lib/x86_64-linux-gnu/libbluray.so.1.9.2
7ff5868be000-7ff586abd000 —p 00047000 08:01 17047758 /usr/lib/x86_64-linux-gnu/libbluray.so.1.9.2
7ff586abd000-7ff586abf000 r–p 00046000 08:01 17047758 /usr/lib/x86_64-linux-gnu/libbluray.so.1.9.2
7ff586abf000-7ff586ac0000 rw-p 00048000 08:01 17047758 /usr/lib/x86_64-linux-gnu/libbluray.so.1.9.2
7ff586ac0000-7ff586b0a000 r-xp 00000000 08:01 17047760 /usr/lib/x86_64-linux-gnu/libgme.so.0.6.0
7ff586b0a000-7ff586d0a000 —p 0004a000 08:01 17047760 /usr/lib/x86_64-linux-gnu/libgme.so.0.6.0
7ff586d0a000-7ff586d0d000 r–p 0004a000 08:01 17047760 /usr/lib/x86_64-linux-gnu/libgme.so.0.6.0
7ff586d0d000-7ff586d0e000 rw-p 0004d000 08:01 17047760 /usr/lib/x86_64-linux-gnu/libgme.so.0.6.0
7ff586d0e000-7ff586d58000 r-xp 00000000 08:01 17047762 /usr/lib/x86_64-linux-gnu/libmodplug.so.1.0.0
7ff586d58000-7ff586f58000 —p 0004a000 08:01 17047762 /usr/lib/x86_64-linux-gnu/libmodplug.so.1.0.0
7ff586f58000-7ff586f59000 r–p 0004a000 08:01 17047762 /usr/lib/x86_64-linux-gnu/libmodplug.so.1.0.0
7ff586f59000-7ff586f5a000 rw-p 0004b000 08:01 17047762 /usr/lib/x86_64-linux-gnu/libmodplug.so.1.0.0
7ff586f5a000-7ff587099000 rw-p 00000000 00:00 0
7ff587099000-7ff5870b4000 r-xp 00000000 08:01 17045214 /usr/lib/x86_64-linux-gnu/librtmp.so.1
7ff5870b4000-7ff5872b3000 —p 0001b000 08:01 17045214 /usr/lib/x86_64-linux-gnu/librtmp.so.1
7ff5872b3000-7ff5872b4000 r–p 0001a000 08:01 17045214 /usr/lib/x86_64-linux-gnu/librtmp.so.1
7ff5872b4000-7ff5872b5000 rw-p 0001b000 08:01 17045214 /usr/lib/x86_64-linux-gnu/librtmp.so.1
7ff5872b5000-7ff5872fd000 r-xp 00000000 08:01 17047764 /usr/lib/x86_64-linux-gnu/libssh-gcrypt.so.4.4.1
7ff5872fd000-7ff5874fc000 —p 00048000 08:01 17047764 /usr/lib/x86_64-linux-gnu/libssh-gcrypt.so.4.4.1
7ff5874fc000-7ff5874fd000 r–p 00047000 08:01 17047764 /usr/lib/x86_64-linux-gnu/libssh-gcrypt.so.4.4.1
7ff5874fd000-7ff5874fe000 rw-p 00048000 08:01 17047764 /usr/lib/x86_64-linux-gnu/libssh-gcrypt.so.4.4.1
7ff5874fe000-7ff587518000 r-xp 00000000 08:01 17045729 /usr/lib/x86_64-linux-gnu/libcrystalhd.so.3.6
7ff587518000-7ff587717000 —p 0001a000 08:01 17045729 /usr/lib/x86_64-linux-gnu/libcrystalhd.so.3.6
7ff587717000-7ff587718000 r–p 00019000 08:01 17045729 /usr/lib/x86_64-linux-gnu/libcrystalhd.so.3.6
7ff587718000-7ff587719000 rw-p 0001a000 08:01 17045729 /usr/lib/x86_64-linux-gnu/libcrystalhd.so.3.6
7ff587719000-7ff587726000 r-xp 00000000 08:01 17047391 /usr/lib/x86_64-linux-gnu/libgsm.so.1.0.12
7ff587726000-7ff587925000 —p 0000d000 08:01 17047391 /usr/lib/x86_64-linux-gnu/libgsm.so.1.0.12
7ff587925000-7ff587926000 r–p 0000c000 08:01 17047391 /usr/lib/x86_64-linux-gnu/libgsm.so.1.0.12
7ff587926000-7ff587927000 rw-p 0000d000 08:01 17047391 /usr/lib/x86_64-linux-gnu/libgsm.so.1.0.12
7ff587927000-7ff58796c000 r-xp 00000000 08:01 17047699 /usr/lib/x86_64-linux-gnu/libmp3lame.so.0.0.0
7ff58796c000-7ff587b6c000 —p 00045000 08:01 17047699 /usr/lib/x86_64-linux-gnu/libmp3lame.so.0.0.0
7ff587b6c000-7ff587b6d000 r–p 00045000 08:01 17047699 /usr/lib/x86_64-linux-gnu/libmp3lame.so.0.0.0
7ff587b6d000-7ff587b6e000 rw-p 00046000 08:01 17047699 /usr/lib/x86_64-linux-gnu/libmp3lame.so.0.0.0
7ff587b6e000-7ff587b9c000 rw-p 00000000 00:00 0
7ff587b9c000-7ff587bbe000 r-xp 00000000 08:01 17047702 /usr/lib/x86_64-linux-gnu/libopenjpeg.so.1.5.2
7ff587bbe000-7ff587dbd000 —p 00022000 08:01 17047702 /usr/lib/x86_64-linux-gnu/libopenjpeg.so.1.5.2
7ff587dbd000-7ff587dbe000 r–p 00021000 08:01 17047702 /usr/lib/x86_64-linux-gnu/libopenjpeg.so.1.5.2
7ff587dbe000-7ff587dbf000 rw-p 00022000 08:01 17047702 /usr/lib/x86_64-linux-gnu/libopenjpeg.so.1.5.2
7ff587dbf000-7ff587e08000 r-xp 00000000 08:01 17047705 /usr/lib/x86_64-linux-gnu/libopus.so.0.5.2
7ff587e08000-7ff588007000 —p 00049000 08:01 17047705 /usr/lib/x86_64-linux-gnu/libopus.so.0.5.2
7ff588007000-7ff588008000 r–p 00048000 08:01 17047705 /usr/lib/x86_64-linux-gnu/libopus.so.0.5.2
7ff588008000-7ff588009000 rw-p 00049000 08:01 17047705 /usr/lib/x86_64-linux-gnu/libopus.so.0.5.2
7ff588009000-7ff5880da000 r-xp 00000000 08:01 17047438 /usr/lib/x86_64-linux-gnu/libschroedinger-1.0.so.0.11.0
7ff5880da000-7ff5882da000 —p 000d1000 08:01 17047438 /usr/lib/x86_64-linux-gnu/libschroedinger-1.0.so.0.11.0
7ff5882da000-7ff5882dc000 r–p 000d1000 08:01 17047438 /usr/lib/x86_64-linux-gnu/libschroedinger-1.0.so.0.11.0
7ff5882dc000-7ff5882dd000 rw-p 000d3000 08:01 17047438 /usr/lib/x86_64-linux-gnu/libschroedinger-1.0.so.0.11.0
7ff5882dd000-7ff5882de000 rw-p 00000000 00:00 0
7ff5882de000-7ff5882ea000 r-xp 00000000 08:01 17047707 /usr/lib/x86_64-linux-gnu/libshine.so.3.0.1
7ff5882ea000-7ff5884e9000 —p 0000c000 08:01 17047707 /usr/lib/x86_64-linux-gnu/libshine.so.3.0.1
7ff5884e9000-7ff5884ea000 r–p 0000b000 08:01 17047707 /usr/lib/x86_64-linux-gnu/libshine.so.3.0.1
7ff5884ea000-7ff5884eb000 rw-p 0000c000 08:01 17047707 /usr/lib/x86_64-linux-gnu/libshine.so.3.0.1
7ff5884eb000-7ff5884f2000 r-xp 00000000 08:01 17046333 /usr/lib/x86_64-linux-gnu/libsnappy.so.1.3.0
7ff5884f2000-7ff5886f1000 —p 00007000 08:01 17046333 /usr/lib/x86_64-linux-gnu/libsnappy.so.1.3.0
7ff5886f1000-7ff5886f2000 r–p 00006000 08:01 17046333 /usr/lib/x86_64-linux-gnu/libsnappy.so.1.3.0
7ff5886f2000-7ff5886f3000 rw-p 00007000 08:01 17046333 /usr/lib/x86_64-linux-gnu/libsnappy.so.1.3.0
7ff5886f3000-7ff58870a000 r-xp 00000000 08:01 17047709 /usr/lib/x86_64-linux-gnu/libspeex.so.1.5.0
7ff58870a000-7ff58890a000 —p 00017000 08:01 17047709 /usr/lib/x86_64-linux-gnu/libspeex.so.1.5.0
7ff58890a000-7ff58890b000 r–p 00017000 08:01 17047709 /usr/lib/x86_64-linux-gnu/libspeex.so.1.5.0
7ff58890b000-7ff58890c000 rw-p 00018000 08:01 17047709 /usr/lib/x86_64-linux-gnu/libspeex.so.1.5.0
7ff58890c000-7ff588925000 r-xp 00000000 08:01 17047717 /usr/lib/x86_64-linux-gnu/libtheoradec.so.1.1.4
7ff588925000-7ff588b24000 —p 00019000 08:01 17047717 /usr/lib/x86_64-linux-gnu/libtheoradec.so.1.1.4
7ff588b24000-7ff588b25000 r–p 00018000 08:01 17047717 /usr/lib/x86_64-linux-gnu/libtheoradec.so.1.1.4
7ff588b25000-7ff588b26000 rw-p 00019000 08:01 17047717 /usr/lib/x86_64-linux-gnu/libtheoradec.so.1.1.4
7ff588b26000-7ff588b64000 r-xp 00000000 08:01 17047715 /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1.1.2
7ff588b64000-7ff588d63000 —p 0003e000 08:01 17047715 /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1.1.2
7ff588d63000-7ff588d64000 r–p 0003d000 08:01 17047715 /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1.1.2
7ff588d64000-7ff588d65000 rw-p 0003e000 08:01 17047715 /usr/lib/x86_64-linux-gnu/libtheoraenc.so.1.1.2
7ff588d65000-7ff588d83000 r-xp 00000000 08:01 17047721 /usr/lib/x86_64-linux-gnu/libtwolame.so.0.0.0
7ff588d83000-7ff588f82000 —p 0001e000 08:01 17047721 /usr/lib/x86_64-linux-gnu/libtwolame.so.0.0.0
7ff588f82000-7ff588f83000 r–p 0001d000 08:01 17047721 /usr/lib/x86_64-linux-gnu/libtwolame.so.0.0.0
7ff588f83000-7ff588f84000 rw-p 0001e000 08:01 17047721 /usr/lib/x86_64-linux-gnu/libtwolame.so.0.0.0
7ff588f84000-7ff588f88000 rw-p 00000000 00:00 0
7ff588f88000-7ff588fb2000 r-xp 00000000 08:01 17047727 /usr/lib/x86_64-linux-gnu/libvorbis.so.0.4.8
7ff588fb2000-7ff5891b2000 —p 0002a000 08:01 17047727 /usr/lib/x86_64-linux-gnu/libvorbis.so.0.4.8
7ff5891b2000-7ff5891b3000 r–p 0002a000 08:01 17047727 /usr/lib/x86_64-linux-gnu/libvorbis.so.0.4.8
7ff5891b3000-7ff5891b4000 rw-p 0002b000 08:01 17047727 /usr/lib/x86_64-linux-gnu/libvorbis.so.0.4.8
7ff5891b4000-7ff589241000 r-xp 00000000 08:01 17047729 /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2.0.11
7ff589241000-7ff589440000 —p 0008d000 08:01 17047729 /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2.0.11
7ff589440000-7ff58945c000 r–p 0008c000 08:01 17047729 /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2.0.11
7ff58945c000-7ff58945d000 rw-p 000a8000 08:01 17047729 /usr/lib/x86_64-linux-gnu/libvorbisenc.so.2.0.11
7ff58945d000-7ff58967c000 r-xp 00000000 08:01 17047731 /usr/lib/x86_64-linux-gnu/libvpx.so.3.0.0
7ff58967c000-7ff58987b000 —p 0021f000 08:01 17047731 /usr/lib/x86_64-linux-gnu/libvpx.so.3.0.0
7ff58987b000-7ff58987d000 r–p 0021e000 08:01 17047731 /usr/lib/x86_64-linux-gnu/libvpx.so.3.0.0
7ff58987d000-7ff58987e000 rw-p 00220000 08:01 17047731 /usr/lib/x86_64-linux-gnu/libvpx.so.3.0.0
7ff58987e000-7ff589881000 rw-p 00000000 00:00 0
7ff589881000-7ff5898a9000 r-xp 00000000 08:01 17047734 /usr/lib/x86_64-linux-gnu/libwavpack.so.1.1.7
7ff5898a9000-7ff589aa8000 —p 00028000 08:01 17047734 /usr/lib/x86_64-linux-gnu/libwavpack.so.1.1.7
7ff589aa8000-7ff589aa9000 r–p 00027000 08:01 17047734 /usr/lib/x86_64-linux-gnu/libwavpack.so.1.1.7
7ff589aa9000-7ff589aaa000 rw-p 00028000 08:01 17047734 /usr/lib/x86_64-linux-gnu/libwavpack.so.1.1.7
7ff589aaa000-7ff589b03000 r-xp 00000000 08:01 17045683 /usr/lib/x86_64-linux-gnu/libwebp.so.5.0.4
7ff589b03000-7ff589d03000 —p 00059000 08:01 17045683 /usr/lib/x86_64-linux-gnu/libwebp.so.5.0.4
7ff589d03000-7ff589d04000 r–p 00059000 08:01 17045683 /usr/lib/x86_64-linux-gnu/libwebp.so.5.0.4
7ff589d04000-7ff589d06000 rw-p 0005a000 08:01 17045683 /usr/lib/x86_64-linux-gnu/libwebp.so.5.0.4
7ff589d06000-7ff589e2e000 r-xp 00000000 08:01 17047736 /usr/lib/x86_64-linux-gnu/libx264.so.148
7ff589e2e000-7ff58a02d000 —p 00128000 08:01 17047736 /usr/lib/x86_64-linux-gnu/libx264.so.148
7ff58a02d000-7ff58a02e000 r–p 00127000 08:01 17047736 /usr/lib/x86_64-linux-gnu/libx264.so.148
7ff58a02e000-7ff58a02f000 rw-p 00128000 08:01 17047736 /usr/lib/x86_64-linux-gnu/libx264.so.148
7ff58a02f000-7ff58a0aa000 rw-p 00000000 00:00 0
7ff58a0aa000-7ff58aab7000 r-xp 00000000 08:01 17047737 /usr/lib/x86_64-linux-gnu/libx265.so.79
7ff58aab7000-7ff58acb6000 —p 00a0d000 08:01 17047737 /usr/lib/x86_64-linux-gnu/libx265.so.79
7ff58acb6000-7ff58acb9000 r–p 00a0c000 08:01 17047737 /usr/lib/x86_64-linux-gnu/libx265.so.79
7ff58acb9000-7ff58acbc000 rw-p 00a0f000 08:01 17047737 /usr/lib/x86_64-linux-gnu/libx265.so.79
7ff58acbc000-7ff58acc9000 rw-p 00000000 00:00 0
7ff58acc9000-7ff58ad6a000 r-xp 00000000 08:01 17047738 /usr/lib/x86_64-linux-gnu/libxvidcore.so.4.3
7ff58ad6a000-7ff58af69000 —p 000a1000 08:01 17047738 /usr/lib/x86_64-linux-gnu/libxvidcore.so.4.3
7ff58af69000-7ff58af6a000 r–p 000a0000 08:01 17047738 /usr/lib/x86_64-linux-gnu/libxvidcore.so.4.3
7ff58af6a000-7ff58af74000 rw-p 000a1000 08:01 17047738 /usr/lib/x86_64-linux-gnu/libxvidcore.so.4.3
7ff58af74000-7ff58afdd000 rw-p 00000000 00:00 0
7ff58afdd000-7ff58b054000 r-xp 00000000 08:01 17047740 /usr/lib/x86_64-linux-gnu/libzvbi.so.0.13.2
7ff58b054000-7ff58b253000 —p 00077000 08:01 17047740 /usr/lib/x86_64-linux-gnu/libzvbi.so.0.13.2
7ff58b253000-7ff58b25c000 r–p 00076000 08:01 17047740 /usr/lib/x86_64-linux-gnu/libzvbi.so.0.13.2
7ff58b25c000-7ff58b268000 rw-p 0007f000 08:01 17047740 /usr/lib/x86_64-linux-gnu/libzvbi.so.0.13.2
7ff58b268000-7ff58b283000 r-xp 00000000 08:01 17047725 /usr/lib/x86_64-linux-gnu/libva.so.1.3900.0
7ff58b283000-7ff58b482000 —p 0001b000 08:01 17047725 /usr/lib/x86_64-linux-gnu/libva.so.1.3900.0
7ff58b482000-7ff58b483000 r–p 0001a000 08:01 17047725 /usr/lib/x86_64-linux-gnu/libva.so.1.3900.0
7ff58b483000-7ff58b484000 rw-p 0001b000 08:01 17047725 /usr/lib/x86_64-linux-gnu/libva.so.1.3900.0
7ff58b484000-7ff58b49e000 r-xp 00000000 08:01 17047713 /usr/lib/x86_64-linux-gnu/libswresample-ffmpeg.so.1.2.101
7ff58b49e000-7ff58b69d000 —p 0001a000 08:01 17047713 /usr/lib/x86_64-linux-gnu/libswresample-ffmpeg.so.1.2.101
7ff58b69d000-7ff58b69f000 r–p 00019000 08:01 17047713 /usr/lib/x86_64-linux-gnu/libswresample-ffmpeg.so.1.2.101
7ff58b69f000-7ff58b6a0000 rw-p 0001b000 08:01 17047713 /usr/lib/x86_64-linux-gnu/libswresample-ffmpeg.so.1.2.101
7ff58b6a0000-7ff58b6a9000 r-xp 00000000 08:01 17047895 /usr/lib/x86_64-linux-gnu/libv4l2.so.0.0.0
7ff58b6a9000-7ff58b8a8000 —p 00009000 08:01 17047895 /usr/lib/x86_64-linux-gnu/libv4l2.so.0.0.0
7ff58b8a8000-7ff58b8a9000 r–p 00008000 08:01 17047895 /usr/lib/x86_64-linux-gnu/libv4l2.so.0.0.0
7ff58b8a9000-7ff58b8ae000 rw-p 00009000 08:01 17047895 /usr/lib/x86_64-linux-gnu/libv4l2.so.0.0.0
7ff58b8ae000-7ff58b8c5000 r-xp 00000000 08:01 20189154 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7ff58b8c5000-7ff58bac4000 —p 00017000 08:01 20189154 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7ff58bac4000-7ff58bac5000 r–p 00016000 08:01 20189154 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7ff58bac5000-7ff58bac6000 rw-p 00017000 08:01 20189154 /lib/x86_64-linux-gnu/libusb-1.0.so.0.1.0
7ff58bac6000-7ff58bad3000 r-xp 00000000 08:01 17047875 /usr/lib/x86_64-linux-gnu/libraw1394.so.11.1.0
7ff58bad3000-7ff58bcd3000 —p 0000d000 08:01 17047875 /usr/lib/x86_64-linux-gnu/libraw1394.so.11.1.0
7ff58bcd3000-7ff58bcd4000 r–p 0000d000 08:01 17047875 /usr/lib/x86_64-linux-gnu/libraw1394.so.11.1.0
7ff58bcd4000-7ff58bcd5000 rw-p 0000e000 08:01 17047875 /usr/lib/x86_64-linux-gnu/libraw1394.so.11.1.0
7ff58bcd5000-7ff58bcf3000 r-xp 00000000 08:01 17047468 /usr/lib/x86_64-linux-gnu/libpangox-1.0.so.0.0.0
7ff58bcf3000-7ff58bef3000 —p 0001e000 08:01 17047468 /usr/lib/x86_64-linux-gnu/libpangox-1.0.so.0.0.0
7ff58bef3000-7ff58bef4000 r–p 0001e000 08:01 17047468 /usr/lib/x86_64-linux-gnu/libpangox-1.0.so.0.0.0
7ff58bef4000-7ff58bef5000 rw-p 0001f000 08:01 17047468 /usr/lib/x86_64-linux-gnu/libpangox-1.0.so.0.0.0
7ff58bef5000-7ff58bf0d000 r-xp 00000000 08:01 17047883 /usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
7ff58bf0d000-7ff58c10c000 —p 00018000 08:01 17047883 /usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
7ff58c10c000-7ff58c10d000 r–p 00017000 08:01 17047883 /usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
7ff58c10d000-7ff58c10e000 rw-p 00018000 08:01 17047883 /usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
7ff58c10e000-7ff58c17b000 r-xp 00000000 08:01 17047879 /usr/lib/x86_64-linux-gnu/libGLU.so.1.3.1
7ff58c17b000-7ff58c37b000 —p 0006d000 08:01 17047879 /usr/lib/x86_64-linux-gnu/libGLU.so.1.3.1
7ff58c37b000-7ff58c37c000 r–p 0006d000 08:01 17047879 /usr/lib/x86_64-linux-gnu/libGLU.so.1.3.1
7ff58c37c000-7ff58c37d000 rw-p 0006e000 08:01 17047879 /usr/lib/x86_64-linux-gnu/libGLU.so.1.3.1
7ff58c37d000-7ff58c3eb000 r-xp 00000000 08:01 20185672 /lib/x86_64-linux-gnu/libpcre.so.3.13.2
7ff58c3eb000-7ff58c5eb000 —p 0006e000 08:01 20185672 /lib/x86_64-linux-gnu/libpcre.so.3.13.2
7ff58c5eb000-7ff58c5ec000 r–p 0006e000 08:01 20185672 /lib/x86_64-linux-gnu/libpcre.so.3.13.2
7ff58c5ec000-7ff58c5ed000 rw-p 0006f000 08:01 20185672 /lib/x86_64-linux-gnu/libpcre.so.3.13.2
7ff58c5ed000-7ff58c5f4000 r-xp 00000000 08:01 17041700 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7ff58c5f4000-7ff58c7f3000 —p 00007000 08:01 17041700 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7ff58c7f3000-7ff58c7f4000 r–p 00006000 08:01 17041700 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7ff58c7f4000-7ff58c7f5000 rw-p 00007000 08:01 17041700 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
7ff58c7f5000-7ff58c7f7000 r-xp 00000000 08:01 17047452 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
7ff58c7f7000-7ff58c9f6000 —p 00002000 08:01 17047452 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
7ff58c9f6000-7ff58c9f7000 r–p 00001000 08:01 17047452 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
7ff58c9f7000-7ff58c9f8000 rw-p 00002000 08:01 17047452 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
7ff58c9f8000-7ff58c9fa000 r-xp 00000000 08:01 17047444 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
7ff58c9fa000-7ff58cbf9000 —p 00002000 08:01 17047444 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
7ff58cbf9000-7ff58cbfa000 r–p 00001000 08:01 17047444 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
7ff58cbfa000-7ff58cbfb000 rw-p 00002000 08:01 17047444 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
7ff58cbfb000-7ff58cc04000 r-xp 00000000 08:01 17047450 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7ff58cc04000-7ff58ce03000 —p 00009000 08:01 17047450 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7ff58ce03000-7ff58ce04000 r–p 00008000 08:01 17047450 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7ff58ce04000-7ff58ce05000 rw-p 00009000 08:01 17047450 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
7ff58ce05000-7ff58ce0f000 r-xp 00000000 08:01 17047635 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
7ff58ce0f000-7ff58d00e000 —p 0000a000 08:01 17047635 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
7ff58d00e000-7ff58d00f000 r–p 00009000 08:01 17047635 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
7ff58d00f000-7ff58d010000 rw-p 0000a000 08:01 17047635 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
7ff58d010000-7ff58d01f000 r-xp 00000000 08:01 17047633 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7ff58d01f000-7ff58d21e000 —p 0000f000 08:01 17047633 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7ff58d21e000-7ff58d21f000 r–p 0000e000 08:01 17047633 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7ff58d21f000-7ff58d220000 rw-p 0000f000 08:01 17047633 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
7ff58d220000-7ff58d222000 r-xp 00000000 08:01 17047456 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
7ff58d222000-7ff58d421000 —p 00002000 08:01 17047456 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
7ff58d421000-7ff58d422000 r–p 00001000 08:01 17047456 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
7ff58d422000-7ff58d423000 rw-p 00002000 08:01 17047456 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
7ff58d423000-7ff58d42c000 r-xp 00000000 08:01 17047448 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7ff58d42c000-7ff58d62b000 —p 00009000 08:01 17047448 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7ff58d62b000-7ff58d62c000 r–p 00008000 08:01 17047448 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7ff58d62c000-7ff58d62d000 rw-p 00009000 08:01 17047448 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
7ff58d62d000-7ff58d66a000 r-xp 00000000 08:01 17044448 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.9.0
7ff58d66a000-7ff58d869000 —p 0003d000 08:01 17044448 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.9.0
7ff58d869000-7ff58d86b000 r–p 0003c000 08:01 17044448 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.9.0
7ff58d86b000-7ff58d870000 rw-p 0003e000 08:01 17044448 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.9.0
7ff58d870000-7ff58d8b9000 r-xp 00000000 08:01 17047466 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.3800.1
7ff58d8b9000-7ff58dab9000 —p 00049000 08:01 17047466 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.3800.1
7ff58dab9000-7ff58dabb000 r–p 00049000 08:01 17047466 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.3800.1
7ff58dabb000-7ff58dabc000 rw-p 0004b000 08:01 17047466 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.3800.1
7ff58dabc000-7ff58dad0000 r-xp 00000000 08:01 17047620 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.3800.1
7ff58dad0000-7ff58dcd0000 —p 00014000 08:01 17047620 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.3800.1
7ff58dcd0000-7ff58dcd1000 r–p 00014000 08:01 17047620 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.3800.1
7ff58dcd1000-7ff58dcd2000 rw-p 00015000 08:01 17047620 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.3800.1
7ff58dcd2000-7ff58de52000 r-xp 00000000 08:01 17044394 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.4800.1
7ff58de52000-7ff58e052000 —p 00180000 08:01 17044394 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.4800.1
7ff58e052000-7ff58e056000 r–p 00180000 08:01 17044394 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.4800.1
7ff58e056000-7ff58e058000 rw-p 00184000 08:01 17044394 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.4800.1
7ff58e058000-7ff58e05a000 rw-p 00000000 00:00 0
7ff58e05a000-7ff58e07b000 r-xp 00000000 08:01 17047604 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3200.2
7ff58e07b000-7ff58e27a000 —p 00021000 08:01 17047604 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3200.2
7ff58e27a000-7ff58e27b000 r–p 00020000 08:01 17047604 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3200.2
7ff58e27b000-7ff58e27c000 rw-p 00021000 08:01 17047604 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.3200.2
7ff58e27c000-7ff58e38a000 r-xp 00000000 08:01 17047613 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11400.6
7ff58e38a000-7ff58e58a000 —p 0010e000 08:01 17047613 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11400.6
7ff58e58a000-7ff58e58d000 r–p 0010e000 08:01 17047613 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11400.6
7ff58e58d000-7ff58e58e000 rw-p 00111000 08:01 17047613 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11400.6
7ff58e58e000-7ff58e590000 rw-p 00000000 00:00 0
7ff58e590000-7ff58e5b2000 r-xp 00000000 08:01 17047601 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.21809.1
7ff58e5b2000-7ff58e7b1000 —p 00022000 08:01 17047601 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.21809.1
7ff58e7b1000-7ff58e7b4000 r–p 00021000 08:01 17047601 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.21809.1
7ff58e7b4000-7ff58e7b5000 rw-p 00024000 08:01 17047601 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.21809.1
7ff58e7b5000-7ff58e7ba000 r-xp 00000000 08:01 17047446 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7ff58e7ba000-7ff58e9b9000 —p 00005000 08:01 17047446 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7ff58e9b9000-7ff58e9ba000 r–p 00004000 08:01 17047446 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7ff58e9ba000-7ff58e9bb000 rw-p 00005000 08:01 17047446 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
7ff58e9bb000-7ff58e9c7000 r-xp 00000000 08:01 17047622 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.3800.1
7ff58e9c7000-7ff58ebc6000 —p 0000c000 08:01 17047622 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.3800.1
7ff58ebc6000-7ff58ebc7000 r–p 0000b000 08:01 17047622 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.3800.1
7ff58ebc7000-7ff58ebc8000 rw-p 0000c000 08:01 17047622 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.3800.1
7ff58ebc8000-7ff58ebcb000 r-xp 00000000 08:01 17044393 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.4800.1
7ff58ebcb000-7ff58edca000 —p 00003000 08:01 17044393 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.4800.1
7ff58edca000-7ff58edcb000 r–p 00002000 08:01 17044393 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.4800.1
7ff58edcb000-7ff58edcc000 rw-p 00003000 08:01 17044393 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.4800.1
7ff58edcc000-7ff58edd1000 r-xp 00000000 08:01 17047413 /usr/lib/x86_64-linux-gnu/libIlmThread-2_2.so.12.0.0
7ff58edd1000-7ff58efd1000 —p 00005000 08:01 17047413 /usr/lib/x86_64-linux-gnu/libIlmThread-2_2.so.12.0.0
7ff58efd1000-7ff58efd2000 r–p 00005000 08:01 17047413 /usr/lib/x86_64-linux-gnu/libIlmThread-2_2.so.12.0.0
7ff58efd2000-7ff58efd3000 rw-p 00006000 08:01 17047413 /usr/lib/x86_64-linux-gnu/libIlmThread-2_2.so.12.0.0
7ff58efd3000-7ff58efee000 r-xp 00000000 08:01 17047412 /usr/lib/x86_64-linux-gnu/libIex-2_2.so.12.0.0
7ff58efee000-7ff58f1ed000 —p 0001b000 08:01 17047412 /usr/lib/x86_64-linux-gnu/libIex-2_2.so.12.0.0
7ff58f1ed000-7ff58f1f0000 r–p 0001a000 08:01 17047412 /usr/lib/x86_64-linux-gnu/libIex-2_2.so.12.0.0
7ff58f1f0000-7ff58f1f1000 rw-p 0001d000 08:01 17047412 /usr/lib/x86_64-linux-gnu/libIex-2_2.so.12.0.0
7ff58f1f1000-7ff58f1fc000 r-xp 00000000 08:01 17045679 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7ff58f1fc000-7ff58f3fb000 —p 0000b000 08:01 17045679 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7ff58f3fb000-7ff58f3fc000 r–p 0000a000 08:01 17045679 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7ff58f3fc000-7ff58f3ff000 rw-p 0000b000 08:01 17045679 /usr/lib/x86_64-linux-gnu/libjbig.so.0
7ff58f3ff000-7ff58f410000 r-xp 00000000 08:01 17045002 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7ff58f410000-7ff58f60f000 —p 00011000 08:01 17045002 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7ff58f60f000-7ff58f610000 r–p 00010000 08:01 17045002 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7ff58f610000-7ff58f611000 rw-p 00011000 08:01 17045002 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
7ff58f611000-7ff58f746000 r-xp 00000000 08:01 17045000 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7ff58f746000-7ff58f946000 —p 00135000 08:01 17045000 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7ff58f946000-7ff58f947000 r–p 00135000 08:01 17045000 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7ff58f947000-7ff58f94b000 rw-p 00136000 08:01 17045000 /usr/lib/x86_64-linux-gnu/libX11.so.6.3.0
7ff58f94b000-7ff590c4d000 r-xp 00000000 08:01 17044872 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.361.77
7ff590c4d000-7ff590c6d000 rwxp 01302000 08:01 17044872 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.361.77
7ff590c6d000-7ff590ffc000 r-xp 01322000 08:01 17044872 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.361.77
7ff590ffc000-7ff5911fb000 —p 016b1000 08:01 17044872 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.361.77
7ff5911fb000-7ff5915c8000 rw-p 016b0000 08:01 17044872 /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.361.77
7ff5915c8000-7ff5915dc000 rw-p 00000000 00:00 0
7ff5915dc000-7ff5915df000 r-xp 00000000 08:01 17045078 /usr/lib/x86_64-linux-gnu/tls/libnvidia-tls.so.361.77
7ff5915df000-7ff5917df000 —p 00003000 08:01 17045078 /usr/lib/x86_64-linux-gnu/tls/libnvidia-tls.so.361.77
7ff5917df000-7ff5917e0000 rw-p 00003000 08:01 17045078 /usr/lib/x86_64-linux-gnu/tls/libnvidia-tls.so.361.77
7ff5917e0000-7ff5917e7000 r-xp 00000000 08:01 17046235 /usr/lib/x86_64-linux-gnu/libaec.so.0.0.3
7ff5917e7000-7ff5919e6000 —p 00007000 08:01 17046235 /usr/lib/x86_64-linux-gnu/libaec.so.0.0.3
7ff5919e6000-7ff5919e7000 r–p 00006000 08:01 17046235 /usr/lib/x86_64-linux-gnu/libaec.so.0.0.3
7ff5919e7000-7ff5919e8000 rw-p 00007000 08:01 17046235 /usr/lib/x86_64-linux-gnu/libaec.so.0.0.3
7ff5919e8000-7ff591a09000 r-xp 00000000 08:01 20185632 /lib/x86_64-linux-gnu/liblzma.so.5.0.0
7ff591a09000-7ff591c08000 —p 00021000 08:01 20185632 /lib/x86_64-linux-gnu/liblzma.so.5.0.0
7ff591c08000-7ff591c09000 r–p 00020000 08:01 20185632 /lib/x86_64-linux-gnu/liblzma.so.5.0.0
7ff591c09000-7ff591c0a000 rw-p 00021000 08:01 20185632 /lib/x86_64-linux-gnu/liblzma.so.5.0.0
7ff591c0a000-7ff591c2b000 r-xp 00000000 08:01 17437071 /usr/lib/atlas-base/libcblas.so.3.0
7ff591c2b000-7ff591e2b000 —p 00021000 08:01 17437071 /usr/lib/atlas-base/libcblas.so.3.0
7ff591e2b000-7ff591e2c000 rw-p 00021000 08:01 17437071 /usr/lib/atlas-base/libcblas.so.3.0
7ff591e2c000-7ff59211e000 r-xp 00000000 08:01 17047095 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
7ff59211e000-7ff59231e000 —p 002f2000 08:01 17047095 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
7ff59231e000-7ff592320000 r–p 002f2000 08:01 17047095 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
7ff592320000-7ff592397000 rw-p 002f4000 08:01 17047095 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0
7ff592397000-7ff5923ba000 rw-p 00000000 00:00 0
7ff5923ba000-7ff592403000 r-xp 00000000 08:01 17047066 /usr/lib/x86_64-linux-gnu/libboost_python-py27.so.1.58.0
7ff592403000-7ff592603000 —p 00049000 08:01 17047066 /usr/lib/x86_64-linux-gnu/libboost_python-py27.so.1.58.0
7ff592603000-7ff592604000 r–p 00049000 08:01 17047066 /usr/lib/x86_64-linux-gnu/libboost_python-py27.so.1.58.0
7ff592604000-7ff592606000 rw-p 0004a000 08:01 17047066 /usr/lib/x86_64-linux-gnu/libboost_python-py27.so.1.58.0
7ff592606000-7ff597193000 r-xp 00000000 08:01 17828918 /usr/local/cuda-8.0/lib64/libcudnn.so.5
7ff597193000-7ff597392000 —p 04b8d000 08:01 17828918 /usr/local/cuda-8.0/lib64/libcudnn.so.5
7ff597392000-7ff5973b0000 rw-p 04b8c000 08:01 17828918 /usr/local/cuda-8.0/lib64/libcudnn.so.5
7ff5973b0000-7ff5973da000 rw-p 00000000 00:00 0
7ff5973da000-7ff5973ee000 r-xp 00000000 08:01 17047284 /usr/lib/x86_64-linux-gnu/liblmdb.so.0.0.0
7ff5973ee000-7ff5975ed000 —p 00014000 08:01 17047284 /usr/lib/x86_64-linux-gnu/liblmdb.so.0.0.0
7ff5975ed000-7ff5975ee000 r–p 00013000 08:01 17047284 /usr/lib/x86_64-linux-gnu/liblmdb.so.0.0.0
7ff5975ee000-7ff5975ef000 rw-p 00014000 08:01 17047284 /usr/lib/x86_64-linux-gnu/liblmdb.so.0.0.0
7ff5975ef000-7ff597647000 r-xp 00000000 08:01 17046337 /usr/lib/x86_64-linux-gnu/libleveldb.so.1.18
7ff597647000-7ff597846000 —p 00058000 08:01 17046337 /usr/lib/x86_64-linux-gnu/libleveldb.so.1.18
7ff597846000-7ff597848000 r–p 00057000 08:01 17046337 /usr/lib/x86_64-linux-gnu/libleveldb.so.1.18
7ff597848000-7ff597849000 rw-p 00059000 08:01 17046337 /usr/lib/x86_64-linux-gnu/libleveldb.so.1.18
7ff597849000-7ff597867000 r-xp 00000000 08:01 17046255 /usr/lib/x86_64-linux-gnu/libhdf5_serial_hl.so.10.0.2
7ff597867000-7ff597a66000 —p 0001e000 08:01 17046255 /usr/lib/x86_64-linux-gnu/libhdf5_serial_hl.so.10.0.2
7ff597a66000-7ff597a67000 r–p 0001d000 08:01 17046255 /usr/lib/x86_64-linux-gnu/libhdf5_serial_hl.so.10.0.2
7ff597a67000-7ff597a68000 rw-p 0001e000 08:01 17046255 /usr/lib/x86_64-linux-gnu/libhdf5_serial_hl.so.10.0.2
7ff597a68000-7ff597a69000 rw-p 00000000 00:00 0
7ff597a69000-7ff599f59000 r-xp 00000000 08:01 17828884 /usr/local/cuda-8.0/lib64/libcublas.so.8.0.27
7ff599f59000-7ff59a159000 —p 024f0000 08:01 17828884 /usr/local/cuda-8.0/lib64/libcublas.so.8.0.27
7ff59a159000-7ff59a173000 rw-p 024f0000 08:01 17828884 /usr/local/cuda-8.0/lib64/libcublas.so.8.0.27
7ff59a173000-7ff59a181000 rw-p 00000000 00:00 0
7ff59a181000-7ff59a206000 r-xp 00000000 08:01 17047891 /usr/lib/x86_64-linux-gnu/libswscale-ffmpeg.so.3.1.101
7ff59a206000-7ff59a405000 —p 00085000 08:01 17047891 /usr/lib/x86_64-linux-gnu/libswscale-ffmpeg.so.3.1.101
7ff59a405000-7ff59a407000 r–p 00084000 08:01 17047891 /usr/lib/x86_64-linux-gnu/libswscale-ffmpeg.so.3.1.101
7ff59a407000-7ff59a408000 rw-p 00086000 08:01 17047891 /usr/lib/x86_64-linux-gnu/libswscale-ffmpeg.so.3.1.101
7ff59a408000-7ff59a410000 rw-p 00000000 00:00 0
7ff59a410000-7ff59a465000 r-xp 00000000 08:01 17047697 /usr/lib/x86_64-linux-gnu/libavutil-ffmpeg.so.54.31.100
7ff59a46
I’m confused. You started out asking about this problem:
Is that problem fixed now?
Oh I’m sorry I’ve jumped ahead a bit. Yes that issue has been resolved. I sourced my .profile and then the libraries became visible. I am currently still trying to run caffe’s “make runtest” command and it is failing with the above outputs. I am concerned that the underlying cause of these failure may be related.
This was a hardware failure issue in case it helps anyone in the future.
@flyviapie . What kind of hardware failure did you experience?
