aseyoum@6368-desktop:~/NVIDIA_CUDA-11.4_Samples$ gcc --version
gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
aseyoum@6368-desktop:~/NVIDIA_CUDA-11.4_Samples$ nvcc --version
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Sun_Jul_28_19:07:16_PDT_2019
Cuda compilation tools, release 10.1, V10.1.243
Here is the log for the build:
aseyoum@6368-desktop:~$ nvidia/nvidia_sdk/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS/drive-linux/filesystem/targetfs/usr/local/cuda-11.4/bin/cuda-install-samples-11.4.sh .
Copying samples to ./NVIDIA_CUDA-11.4_Samples now…
Finished copying samples.
aseyoum@6368-desktop:~/NVIDIA_CUDA-11.4_Samples$ sudo make SMS=87 TARGET_ARCH=aarch64 TARGET_OS=linux TARGET_FS=$NV_WORKSPACE/drive-linux_src/filesystem/targetfs
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cppOverload’
/bin/sh: 1: aarch64-linux-gnu-g++: not found
expr: syntax error: unexpected argument ‘4.6’
expr: missing operand
Try ‘expr --help’ for more information.
This CUDA Sample cannot be built if the OpenMP compiler is not set up correctly.
This will be a dry-run of the Makefile.
For more information on how to set up your environment to build and run this
sample, please refer the CUDA Samples documentation and release notes
This is devtools forum and I am not familiar with Drive platform also . So if you have further questions, you can seek more help in the Autonomous Vehicles - NVIDIA Developer Forums forums.
After installing cross-compile toolchain I see warnings like below and I don’t see the directory : ```
NVIDIA_CUDA-11.4_Samples/bin/aarch64/linux/release/
WARNING - libcuda.so not found, CUDA Driver is not installed. Please re-install the driver. <<<
WARNING - libEGL.so not found, please install libEGL.so <<<
WARNING - libGLES.so not found, please install libGLES.so <<<
WARNING - libX11.so not found, please install libX11.so <<<
WARNING - egl.h not found, please install egl.h <<<
WARNING - eglext.h not found, please install eglext.h <<<
WARNING - gl31.h not found, please install gl31.h <<<
WARNING - Xlib.h not found, refer to CUDA Samples release notes for how to find and install them. <<<
WARNING - libvulkan.so not found, please install Vulkan SDK and pass VULKAN_SDK_PATH=<PATH_TO_VULKAN_SDK> <<<
WARNING - vulkan.h not found, please install vulkan.h <<<
GCC Version is greater or equal to 4.7.0 <<<
make[1]: Nothing to be done for ‘all’.
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cppOverload’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAssert’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAssert’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/vectorAddDrv’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/vectorAddDrv’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/clock_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/clock_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleMultiCopy’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleMultiCopy’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cudaOpenMP’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cudaOpenMP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCooperativeGroups’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCooperativeGroups’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/streamOrderedAllocationP2P’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/streamOrderedAllocationP2P’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCudaGraphs’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCudaGraphs’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMul’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMul’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/UnifiedMemoryStreams’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/UnifiedMemoryStreams’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/binaryPartitionCG’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/binaryPartitionCG’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAssert_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAssert_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/inlinePTX_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/inlinePTX_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/memMapIPCDrv’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o helper_multiprocess.o -c …/…/common/src/helper_multiprocess.cpp
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/memMapIPCDrv’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/asyncAPI’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/asyncAPI’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTextureDrv’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTextureDrv’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleVoteIntrinsics_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleVoteIntrinsics_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleZeroCopy’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleZeroCopy’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAtomicIntrinsics_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAtomicIntrinsics_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/globalToShmemAsyncCopy’
GCC Version is greater or equal to 5.0.0 <<<
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/globalToShmemAsyncCopy’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMulDrv’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMulDrv’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/immaTensorCoreGemm’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/immaTensorCoreGemm’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMulCUBLAS’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMulCUBLAS’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAtomicIntrinsics’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAtomicIntrinsics’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleSurfaceWrite’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleSurfaceWrite’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/vectorAdd_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/vectorAdd_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/clock’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/clock’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTemplates’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTemplates’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/tf32TensorCoreGemm’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/tf32TensorCoreGemm’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleMultiGPU’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleMultiGPU’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/streamOrderedAllocation’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/streamOrderedAllocation’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleOccupancy’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleOccupancy’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAttributes’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAttributes’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCallback’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCallback’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cppIntegration’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cppIntegration’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTemplates_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTemplates_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/bf16TensorCoreGemm’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/bf16TensorCoreGemm’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCubemapTexture’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleCubemapTexture’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleDrvRuntime’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleDrvRuntime’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/template’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/template’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleLayeredTexture’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleLayeredTexture’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/vectorAdd’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/vectorAdd’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cudaNvSci’
WARNING - libnvscibuf.so not found, please install libnvscibuf.so <<<
WARNING - libnvscisync.so not found, please install libnvscisync.so <<<
WARNING - nvscibuf.h not found, please install nvscibuf.h <<<
WARNING - nvscisync.h not found, please install nvscisync.h <<<
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --std=c++11 --threads 0 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o cudaNvSci.o -c cudaNvSci.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --std=c++11 --threads 0 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o imageKernels.o -c imageKernels.cu
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --std=c++11 --threads 0 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o main.o -c main.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o cudaNvSci cudaNvSci.o imageKernels.o main.o -lnvscibuf -lnvscisync
[@] mkdir -p …/…/bin/aarch64/linux/release
[@] cp cudaNvSci …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cudaNvSci’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAWBarrier’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleAWBarrier’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleVoteIntrinsics’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleVoteIntrinsics’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/inlinePTX’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/inlinePTX’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/fp16ScalarProduct’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/fp16ScalarProduct’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleStreams’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleStreams’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleSeparateCompilation’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleSeparateCompilation’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTexture’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simpleTexture’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMul_nvrtc’
[@] cp /usr/local/cuda-11.4/targets/aarch64-linux/include/cooperative_groups.h .
[@] cp -r /usr/local/cuda-11.4/targets/aarch64-linux/include/cooperative_groups .
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/matrixMul_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simplePrintf’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simplePrintf’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cdpSimpleQuicksort’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cdpSimpleQuicksort’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cudaTensorCoreGemm’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cudaTensorCoreGemm’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cdpSimplePrint’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/cdpSimplePrint’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/dmmaTensorCoreGemm’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/dmmaTensorCoreGemm’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simplePitchLinearTexture’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/0_Simple/simplePitchLinearTexture’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/p2pBandwidthLatencyTest’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/p2pBandwidthLatencyTest’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/UnifiedMemoryPerf’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/UnifiedMemoryPerf’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQuery’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/bandwidthTest’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/bandwidthTest’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQueryDrv’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/1_Utilities/deviceQueryDrv’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleVulkanMMAP’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -I -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --std=c++11 --threads 0 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o helper_multiprocess.o -c …/…/common/src/helper_multiprocess.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o simpleVulkanMMAP helper_multiprocess.o MonteCarloPi.o VulkanBaseApp.o main.o -L -lvulkan -lglfw
[@] cp simpleVulkanMMAP …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleVulkanMMAP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleGLES’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -DUSE_CUDAINTEROP -DGRAPHICS_SETUP_EGL -DUSE_GLES --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o simpleGLES.o -c simpleGLES.cu
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o simpleGLES simpleGLES.o -lGLESv2 -lEGL -lX11
[@] cp simpleGLES …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleGLES’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleGLES_EGLOutput’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -DUSE_CUDAINTEROP -DGRAPHICS_SETUP_EGL -DUSE_GLES -I/usr/include/libdrm -I/usr/include/drm --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o simpleGLES_EGLOutput.o -c simpleGLES_EGLOutput.cu
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o simpleGLES_EGLOutput simpleGLES_EGLOutput.o -lGLESv2 -lEGL -ldrm
[@] cp simpleGLES_EGLOutput …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleGLES_EGLOutput’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleVulkan’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o simpleVulkan SineWaveSimulation.o VulkanBaseApp.o main.o -L -lvulkan -lglfw
[@] cp simpleVulkan …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/2_Graphics/simpleVulkan’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/dwtHaar1D’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/dwtHaar1D’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/dct8x8’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/dct8x8’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/stereoDisparity’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/stereoDisparity’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/EGLStream_CUDA_CrossGPU’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/EGLStream_CUDA_CrossGPU’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/EGLSync_CUDAEvent_Interop’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o EGLSync_CUDAEvent_Interop.o -c EGLSync_CUDAEvent_Interop.cu
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o EGLSync_CUDAEvent_Interop EGLSync_CUDAEvent_Interop.o -lEGL -lX11 -lGLESv2
[@] cp EGLSync_CUDAEvent_Interop …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/EGLSync_CUDAEvent_Interop’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/EGLStreams_CUDA_Interop’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/EGLStreams_CUDA_Interop’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/vulkanImageCUDA’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o vulkanImageCUDA vulkanImageCUDA.o -L -lvulkan -lglfw
[@] cp vulkanImageCUDA …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/vulkanImageCUDA’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/convolutionSeparable’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/convolutionSeparable’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/dxtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/dxtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/convolutionFFT2D’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/convolutionFFT2D’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/NV12toBGRandResize’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/NV12toBGRandResize’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/histogram’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/histogram’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/HSOpticalFlow’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/HSOpticalFlow’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/convolutionTexture’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/3_Imaging/convolutionTexture’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/MonteCarloMultiGPU’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/MonteCarloMultiGPU’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/binomialOptions’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/binomialOptions’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/quasirandomGenerator’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/quasirandomGenerator’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/SobolQRNG’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/SobolQRNG’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/binomialOptions_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/binomialOptions_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/BlackScholes’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/BlackScholes’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/quasirandomGenerator_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/quasirandomGenerator_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/BlackScholes_nvrtc’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/4_Finance/BlackScholes_nvrtc’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/5_Simulations/nbody_opengles’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -ftz=true --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o bodysystemcuda.o -c bodysystemcuda.cu
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -ftz=true --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o nbody_opengles.o -c nbody_opengles.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -ftz=true --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o render_particles.o -c render_particles.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o nbody_opengles bodysystemcuda.o nbody_opengles.o render_particles.o -lGLESv2 -lEGL -lX11
[@] cp nbody_opengles …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/5_Simulations/nbody_opengles’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/5_Simulations/fluidsGLES’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o fluidsGLES.o -c fluidsGLES.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o fluidsGLES_kernels.o -c fluidsGLES_kernels.cu
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o fluidsGLES fluidsGLES.o fluidsGLES_kernels.o -lGLESv2 -lEGL -lX11 -lcufft
[@] cp fluidsGLES …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/5_Simulations/fluidsGLES’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/matrixMulDynlinkJIT’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/matrixMulDynlinkJIT’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/ptxjit’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/ptxjit’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/scalarProd’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/scalarProd’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/transpose’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/transpose’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/radixSortThrust’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/radixSortThrust’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/conjugateGradientMultiDeviceCG’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/conjugateGradientMultiDeviceCG’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cdpAdvancedQuicksort’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cdpAdvancedQuicksort’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/sortingNetworks’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/sortingNetworks’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/jacobiCudaGraphs’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/jacobiCudaGraphs’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/reductionMultiBlockCG’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/reductionMultiBlockCG’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/fastWalshTransform’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/fastWalshTransform’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cdpQuadtree’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cdpQuadtree’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/reduction’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/reduction’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/eigenvalues’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/eigenvalues’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/lineOfSight’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/lineOfSight’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/concurrentKernels’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/concurrentKernels’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/scan’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/scan’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/FDTD3d’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/FDTD3d’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/segmentationTreeThrust’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/segmentationTreeThrust’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/c++11_cuda’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/c++11_cuda’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cdpBezierTessellation’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cdpBezierTessellation’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/simpleHyperQ’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/simpleHyperQ’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cudaCompressibleMemory’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/cudaCompressibleMemory’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/mergeSort’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/mergeSort’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/alignedTypes’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/alignedTypes’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/shfl_scan’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/shfl_scan’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/newdelete’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/newdelete’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/threadFenceReduction’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/threadFenceReduction’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/interval’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/interval’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/conjugateGradientMultiBlockCG’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/conjugateGradientMultiBlockCG’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/warpAggregatedAtomicsCG’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/warpAggregatedAtomicsCG’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/threadMigration’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/6_Advanced/threadMigration’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverRf’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverRf’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT_2d_MGPU’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT_2d_MGPU’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverDn_LinearSolver’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverDn_LinearSolver’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/freeImageInteropNPP’
test.c:1:10: fatal error: FreeImage.h: No such file or directory
1 | include “FreeImage.h”
compilation terminated.
WARNING - FreeImage is not set up correctly. Please ensure FreeImage is set up correctly. <<<
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -I…/common/UtilNPP -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o freeImageInteropNPP.o -c freeImageInteropNPP.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o freeImageInteropNPP freeImageInteropNPP.o -lnppisu -lnppif -lnppc -lfreeimage
[@] cp freeImageInteropNPP …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/freeImageInteropNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT_callback’
GCC Version is greater or equal to 5.3.0 <<<
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT_callback’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MersenneTwisterGP11213’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MersenneTwisterGP11213’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/batchedLabelMarkersAndLabelCompressionNPP’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/batchedLabelMarkersAndLabelCompressionNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverSp_LowlevelQR’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverSp_LowlevelQR’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiInlineQ’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiInlineQ’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cannyEdgeDetectorNPP’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -I…/common/UtilNPP -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o cannyEdgeDetectorNPP.o -c cannyEdgeDetectorNPP.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o cannyEdgeDetectorNPP cannyEdgeDetectorNPP.o -lnppisu_static -lnppif_static -lnppc_static -lculibos -lfreeimage
[@] cp cannyEdgeDetectorNPP …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cannyEdgeDetectorNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUBLAS’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUBLAS’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT_MGPU’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUFFT_MGPU’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradientCudaGraphs’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradientCudaGraphs’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiInlineP’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiInlineP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiP’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUBLASXT’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUBLASXT’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/FilterBorderControlNPP’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -I…/common/UtilNPP -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o FilterBorderControlNPP.o -c FilterBorderControlNPP.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o FilterBorderControlNPP FilterBorderControlNPP.o -lnppisu_static -lnppif_static -lnppitc_static -lnppidei_static -lnppial_static -lnppc_static -lculibos -lfreeimage
[@] cp FilterBorderControlNPP …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/FilterBorderControlNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/histEqualizationNPP’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -I…/common/UtilNPP -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o histEqualizationNPP.o -c histEqualizationNPP.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o histEqualizationNPP histEqualizationNPP.o -lnppisu -lnppist -lnppicc -lnppc -lfreeimage
[@] cp histEqualizationNPP …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/histEqualizationNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradientUM’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradientUM’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverSp_LinearSolver’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverSp_LinearSolver’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradientPrecond’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradientPrecond’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/boxFilterNPP’
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -I…/…/common/inc -I…/common/UtilNPP -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu --threads 0 --std=c++11 -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o boxFilterNPP.o -c boxFilterNPP.cpp
[@] /usr/local/cuda-11.4/bin/nvcc -ccbin aarch64-linux-gnu-g++ -m64 -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/libdrm -Xcompiler -isystem=/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xcompiler -I/drive-linux_src/filesystem/targetfs/usr/include/aarch64-linux-gnu -Xlinker --sysroot=/drive-linux_src/filesystem/targetfs -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/lib/aarch64-linux-gnu -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib -Xlinker -rpath-link=/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker -L/drive-linux_src/filesystem/targetfs/usr/lib/aarch64-linux-gnu -Xlinker --unresolved-symbols=ignore-in-shared-libs -gencode arch=compute_87,code=sm_87 -gencode arch=compute_87,code=compute_87 -o boxFilterNPP boxFilterNPP.o -lnppisu_static -lnppif_static -lnppc_static -lculibos -lfreeimage
[@] cp boxFilterNPP …/…/bin/aarch64/linux/release
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/boxFilterNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_SingleAsianOptionP’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_SingleAsianOptionP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverSp_LowlevelCholesky’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/cuSolverSp_LowlevelCholesky’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/watershedSegmentationNPP’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/watershedSegmentationNPP’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiQ’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/MC_EstimatePiQ’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradient’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/conjugateGradient’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/batchCUBLAS’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/batchCUBLAS’
make[1]: Entering directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUBLAS_LU’
make[1]: Leaving directory ‘/home/aseyoum/NVIDIA_CUDA-11.4_Samples/7_CUDALibraries/simpleCUBLAS_LU’
Finished building CUDA samples
