Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Hi everyone,
My institute has purchased a Jetson Xavier AGX board from a retailer. Currently, we are developing a GUI application on it, and we are wondering that it can support a Java apps or not?
If yes, are there any Java installation guidelines for developing this GUI?
If not, are there any GUI tools that are appropriate? (Qt or something like that)
If there is enough memory I wouldn’t expect Java to be any different than any other language, but you might need to install something. Just to explore, check this command out for listing software from the public repositories: apt search java | less -i
(the “less” is a pager, the “-i” makes this case-insensitive, e.g., once less is open search for “java” via “/java”…the “/” says that what you type next is a regular expression search term)
Note: I’ve also seen a lot of people use QT. I would thing this would also have a smaller footprint than Java, but that’s just a guess.
