Hi…I am working on Nvidia Jetson AGX Xavier within Dockerized container…I want to take input from RTSP stream…it’s encoding type is H264 and .avi video input.Input stream frame size is 1920x1080 and 25 FPS
It is able to read the frames but after reading frames, frames got completely blurred ,that’s why object detection is not happening.
Kindly help me to solve this issue ASAP. Thank You!
When I am trying this
cap = cv2.VideoCapture(“rtsp_link”)
then it is able to read the frame,detection is also happening, but after sometime it is getting stopped.(around 1 min)
Hi…I have another similar AGX xavier…there is also same OpenCV version installed but GStreamer pipeline is working there.There is only 1 difference in VPI…is that creating problem…I am sharing both configuration…Please can you check and help me.
My system on which I am currently working(GStreamer is not working)—>
If you fail to run the sample in executing the command directly(without docker), we would suggest re-flash the system image. The sample should be successfully run on default releases.
I have tried to install VPI with “sudo apt install nvidia-vpi” and it worked. Now without re-flashing also GStreamer is working fine within and outside of the docker.
Thank you for support!
Hi…
After installing VPI GStreamer is now working . The sample RTSP is running but still I am getting problem in reading frames from actual site RTSP. Code is started but stalled
