Writing h264 video using GST pipeline with OpenCV using NVENC engine
Hardware : Xavier NX
JetPack: 5.1.2
Python : 3.8.10
gst-launch-1.0 : 1.16.3
My main goal is to efficiently record videos in h264 format using GPU hardware acceleration using a GStreamer pipeline as show here:
gst_out = "appsrc ! video/x-raw, format=BGR ! queue ! videoconvert ! nvvidconv ! nvv4l2h264enc ! h264parse ! matroskamux ! filesink location=output.mp4"
writer = cv2.VideoWriter(gst_out, cv2.CAP_GSTREAMER, fps, framz_size)
This pipeline works well in some cases, but not in others. Let me explain.
From a video read by videoCapture as it’s done here, the following code works very well:
class VideoEncoder:
    def __init__(self):
        self.cap = cv2.VideoCapture("input.mp4")
        gst_out = f"appsrc ! video/x-raw, format=BGR ! queue ! videoconvert ! video/x-raw,format=BGRx ! nvvidconv ! nvv4l2h264enc ! h264parse ! matroskamux ! filesink location=output.mp4"
        self.writer = cv2.VideoWriter(gst_out,
                                      cv2.CAP_GSTREAMER,
                                      self.cap.get(cv2.CAP_PROP_FPS),
                                      (int(self.cap.get(cv2.CAP_PROP_FRAME_WIDTH)), int(self.cap.get(cv2.CAP_PROP_FRAME_HEIGHT))))
    def encode_video(self):
        while True:
            ret, frame = self.cap.read()
            if not ret:
                break
            self.writer.write(frame)
    def release(self):
        self.cap.release()
        self.writer.release()
if __name__ == "__main__":
    encoder = VideoEncoder()
    encoder.encode_video()
    encoder.release()
However, in my application, I use an RTSP source initially read like this:
gst_in = f"rtspsrc location=rtsp://ip:port/mystream protocol=tcp latency=10 ! rtph264depay ! h264parse ! avdec_h264 ! videorate ! video/x-raw,framerate=25/1 ! videoconvert ! appsink max-buffers=1 drop=true"
cap = cv2.VideoCapture(gst_in, cv2.CAP_GSTREAMER)
When I use this source, initializing the videowriter generates alarms:
FFMPEG: tag 0x00000708/‘???’ is not found (format ‘mp4 / MP4 (MPEG-4 Part 14)’)
(python3:144948): GStreamer-WARNING **: 13:50:13.313: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so’: /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(python3:144948): GStreamer-WARNING **: 13:50:13.328: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so’: /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
[ WARN:0] global /opt/opencv-4.5.3/modules/videoio/src/cap_gstreamer.cpp (1654) open OpenCV | GStreamer warning: error opening writer pipeline: no element “nvvidconv”
And no video is recorded. Here’s the code I use:
import cv2
class VideoEncoder:
    def __init__(self):
        self.cap = cv2.VideoCapture(gst_in, cv2.CAP_GSTREAMER)
        if not self.cap.isOpened():
            print("Error: Could not open RTSP stream")
            exit()
                                      cv2.CAP_GSTREAMER,
        start_time = cv2.getTickCount()
        while True:
            if not ret:
                break
            current_time = cv2.getTickCount()
            elapsed_time = (current_time - start_time) / cv2.getTickFrequency()
            if elapsed_time > 10:
                break
    def release(self):
        self.cap.release()
    encoder.release()
I have several questions:
  • Why does using a different source affect the VideoWriter?
  • What should I do to be able to record videos from an RTSP stream?
  • Is it possible to accelerate the VideoCapture of the RTSP stream using the GPU?
The problem seems to stem from the fact that I’m using a GStreamer pipeline for both reading and writing, causing memory allocation conflicts. When I read in OpenCV and write in GStreamer, it’s fine. Similarly, when I read in GStreamer and write in OpenCV, it’s fine. However, when I do both operations in GStreamer, these memory allocation errors occur.
You may eliminate max-buffers=1 drop=true from appsink and give it a try. Not sure but it looks like with the setting, only one buffer is allocated.
