I want to use opencv with gstreamer support on x86 platform , GPU is Tesla T4 , I built the opencv with gstreamer from source, and install all the gstreamer dependencies to the system.
Here is my code:
import cv2
import time
uri = "rtsp://10.168.1.202:8554/test"
# cap = "rtspsrc location=%s latency=0 ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! appsink" % uri
cap = "rtspsrc location=%s ! application/x-rtp, media=video ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink" % uri
cap = cv2.VideoCapture(cap, cv2.CAP_GSTREAMER)
frame_num = 0
tic = time.time()
while True:
frame_num += 1
ret, frame = cap.read()
if ret:
pass
else:
break
toc = time.time()
print("Decode FPS: %.2f" % (frame_num / (toc - tic)))
cap.release()
However it failed to run:
[ WARN:0] global /opt/opencv-4.4.0/modules/videoio/src/cap_gstreamer.cpp (713) open OpenCV | GStreamer warning: Error opening bin: no element "nvv4l2decoder"
[ WARN:0] global /opt/opencv-4.4.0/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
I built the opencv and dependencies as follows (Dockerfile):
RUN apt-get update && apt-get install -y libgstreamer-plugins-base1.0-dev gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav
RUN apt-get install -y libgstreamer1.0 libgstreamer1.0-dev libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgstrtspserver-1.0-0 libjansson4 \
build-essential cmake pkg-config vim wget \
libjpeg8-dev libtiff5-dev libjasper-dev libpng12-dev libgtk-3-dev \
libsm6 libxrender1 libxext-dev libgl1-mesa-glx && \
rm -rf /var/lib/apt/lists/*
ADD opencv-4.4.0/ /opt/opencv-4.4.0/ # I've download the opencv code repo.
RUN cd /opt/opencv-4.4.0 && mkdir build && cd build/ && \
cmake -D CMAKE_BUILD_TYPE=RELEASE \
-D PYTHON_DEFAULT_EXECUTABLE=$(python3 -c "import sys; print(sys.executable)") \
-D PYTHON3_EXECUTABLE=$(python3 -c "import sys; print(sys.executable)") \
-D PYTHON3_NUMPY_INCLUDE_DIRS=$(python3 -c "import numpy; print (numpy.get_include())") \
-D PYTHON3_PACKAGES_PATH=$(python3 -c "from distutils.sysconfig import get_python_lib; print(get_python_lib())") \
-D CMAKE_CXX_FLAGS="-std=c++11" \
-D CUDA_NVCC_FLAGS="--compiler-options "-std=c++03"" \
-D WITH_GSTREAMER=ON \
-D WITH_GSTREAMER_0_10=OFF .. && \
make -j20 && make install && ldconfig
mchi
February 9, 2021, 3:44pm
3
didn’t get chance to repo with your steps.
but you may could refer to IP Camera RTSP + GSTREAMER + C++ (Stream Latency 4-5 seconds) - #4 by mchi firstly.
Thanks, I am 100% sure that it would work on jetson platform, I tried the same pipeline before. But this time I want to run on x86, some say the nv-gst-plugin only work on ARM machine?
mchi
February 10, 2021, 2:41am
5
DS propvides DS plugins, e.g. nvv4l2decoder, that has the same name, properities on Jetson/ARM and x86.
But some NV plugins, e.g. nvvidconv , is not DS plugin, which can only work on Jetson.
Here is the reference - DeepStream SDK FAQ - #15 by Fiona.Chen about DS plugin and non-DS plugin
I found a solution (maybe…), https://github.com/jkjung-avt/tensorrt_demos/blob/32ce1c39ae74c9cf0b93e491ecefbe3453a855c8/utils/camera.py#L69
Instead of using nvv4l2decoder, using avdec_h264 can make this pipeline running successfully.
uri = "rtsp://192.168.1.202:8554/test"
cap = "rtspsrc location=%s ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! appsink" % uri
I wonder if it will hurt the performance? @mchi Since it doesn’t use the nv decoder plugin.
I test the decode perf with this script:
import cv2
import time
frame_num = 0
tic = time.time()
while True:
frame_num += 1
if ret:
pass
if not cap.isOpened():
sys.exit("Failed to open camera!")
if frame_num == 1000:
break
toc = time.time()
cap.release()
The decoding FPS is: 23.96, almost the same as the web camera’s FPS, CPU utilization is about 50% (htop).
mchi
February 22, 2021, 5:28am
7
avdec_h264 is using SW/CPU for decoding, and videoconvert is also using CPU to do conversion.
So, this pipeline is complete using CPU.
Why can’t use
rtspsrc location=%s ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! appsink" % uri ?
I’m afraid it won’t work:
root@2a13c2648369:/opt/nvidia/deepstream/deepstream-5.0# python3 test_decode.py
(python3:15540): GStreamer-CRITICAL **: 05:58:01.239: gst_mini_object_unref: assertion 'mini_object != NULL' failed
The testing script will stuck in here and seem to be frozen, even ctrl + C can not quit the program.
I already use the deepstream-5.0.1 docker container, which is x86 version.
Really need help to run opencv with gstreamer in x86 machine.
mchi
February 23, 2021, 1:17am
9
Tried below command wroks on my side.
$ gst-launch-1.0 -e rtspsrc location=rtsp://10.19.225.234/media/video1 ! decodebin ! nvvideoconvert ! “video/x-raw(memory:NVMM), format=I420” ! queue ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=test.mp4
below command runs well without error
$ gst-launch-1.0 -e rtspsrc location=rtsp://10.19.225.234/media/video1 ! decodebin ! nvvideoconvert nvbuf-memory-type=3 ! fakesink
but it failed with log - “VideoCapture not opened” after integrating into opencv. The same code work on Jetson.
Will check and get back.
int main()
std::string pipe = "rtspsrc location=rtsp://10.19.225.234/media/video1 ! decodebin ! nvvideoconvert nvbuf-memory-type=3 ! appsink";
VideoCapture cap(pipe, CAP_GSTREAMER);
if (!cap.isOpened()) {
cerr <<"VideoCapture not opened"<<endl;
exit(-1);
while (true) {
Mat frame;
cap.read(frame);
imwrite("receiver.png", frame);
getchar();
return 0;
@mchi hi, any update here?
mchi
March 20, 2021, 2:31pm
14
Hi @CoderJustin
Didn’t find any clues now.
Tried to set_enc(…“GST_DEBUG”), but can’t get failure log.
Do you have any failure log to share when using these components in OpenCV?
Or, for now, could you use other method instead of OpenCV?
@CoderJustin
I used the nvcr.io/nvidia/deepstream:6.0-devel image and tried to re-implement this problem.
Although it still won’t work with your opencv-python code, but I found out the rtsp can be played with the cmd bellow:
gst-launch-1.0 rtspsrc location=<rtsp-url> ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! autovideosink
And it take my gpu :
usage about 8%
gpu memory 207MB
So I think there is some problem from opencv-python. I still try to figure it out.
I rebuild the opencv-python by following blog. And it works finally.
## Ubuntu
Reading time: 4 min read
Thank you for the link, I’ll try that later.
system
Closed
June 16, 2022, 2:09am
19
