I am using Nvidia Video Codec to encode YUV4:4:4 to H.264 .
- Operation system : Ubuntu 16.04
- Driver : NVIDIA-Linux-x86_64-384.98
- SDK: Video_Codec_SDK_8.0.14
- My Card: P400
I compiled Samples/NvEncoder and it generate an executable file “NvEncoder”
Then I use following command:
./NvEncoder -i …/test.yuv -o test.264 -inputFormat 1 -size 1280 720
which produce encoded h264 file and “NvEncoder” has following output:
Encoding input : “…/test.yuv”
output : “test.264”
codec : “H264”
bitrate : 5000000 bits/sec
vbvMaxBitrate : 0 bits/sec
vbvSize : 0 bits
fps : 30 frames/sec
rcMode : CONSTQP
goplength : INFINITE GOP
B frames : 0
QP : 28
Input Format : YUV 444
preset : DEFAULT
Picture Structure : Frame Mode
devicetype : CUDA
Issue is the “test.264” file has unknown profile_idc in its sps.
It gives " 00 00 00 01 67 F4 00 1F"
F4 is the profile_idc = 244
There is no definition of 244 in H264 Recommendation
66:Baseline
77:Main profile
88:Extended profile
144: High 4:4:4 profile
122: High 4:2:2 profile
110: High 10 profile
100: High profile
I’m actually not sure what happened with my encoder.
