I have an issue with the VUI generated by v4l tegra H264 encoder in L4T 32.1. Here is an output of h264_parse utility for H264 bitstream generated in L4T 32.1:
Nal length 26 start code 4 bytes
ref 3 type 7 Sequence parameter set
profile: 100
constaint_set0_flag: 0
constaint_set1_flag: 0
constaint_set2_flag: 0
constaint_set3_flag: 0
field error - 4 bits should be 0 is c
level_idc: 51
seq parameter set id: 0
chroma format idx: 1
bit depth luma minus8: 0
bit depth chroma minus8: 0
Qpprime Y Zero Transform Bypass flag: 0
Seq Scaling Matrix Present Flag: 0
log2_max_frame_num_minus4: 4
pic_order_cnt_type: 0
log2_max_pic_order_cnt_lsb_minus4: 4
num_ref_frames: 1
gaps_in_frame_num_value_allowed_flag: 0
pic_width_in_mbs_minus1: 119 (1920)
pic_height_in_map_minus1: 67
frame_mbs_only_flag: 1
derived height: 1088
direct_8x8_inference_flag: 1
frame_cropping_flag: 1
frame_crop_left_offset: 0
frame_crop_right_offset: 0
frame_crop_top_offset: 0
frame_crop_bottom_offset: 4
vui_parameters_present_flag: 1
aspect_ratio_info_present_flag: 0
overscan_info_present_flag: 0
video_signal_info_present_flag: 1
video_format: 5
video_full_range_flag: 0
colour_description_present_flag: 0
chroma_loc_info_present_flag: 0
timing_info_present_flag: 1
num_units_in_tick: 1
time_scale: 60
fixed_frame_scale: 1
nal_hrd_parameters_present_flag: 0
vcl_hrd_parameters_present_flag: 0
pic_struct_present_flag: 0
Compare to L4T 28.2.1:
Nal length 42 start code 4 bytes
profile: 100
level_idc: 51
num_ref_frames: 1
video_signal_info_present_flag: 0
num_units_in_tick: 1000
time_scale: 60000
fixed_frame_scale: 0
nal_hrd_parameters_present_flag: 1
cpb_cnt_minus1: 0
bit_rate_scale: 0
cpb_size_scale: 0
bit_rate_value_minus1[0]: 156249
cpb_size_value_minus1[0]: 671087
cbr_flag[0]: 1
initial_cpb_removal_delay_length_minus1: 23
cpb_removal_delay_length_minus1: 15
dpb_output_delay_length_minus1: 5
time_offset_length: 24
low_delay_hrd_flag: 1
motion_vectors_over_pic_boundaries_flag: 1
max_bytes_per_pic_denom: 0
max_bits_per_mb_denom: 0
log2_max_mv_length_horizontal: 16
log2_max_mv_length_vertical: 16
num_reorder_frames: 0
max_dec_frame_buffering: 1
The difference between these 2 VUI versions causes nvdec desktop decoder to buffer frames in case of L4T 32.1 bitstream. For L4T 28.2.1 nvdec returns frames without any delay (but only if VUI is enabled in encoder). I guess these flags are of interest here:
Is it possible to return the old behaviour? I don’t want to be stuck with older L4T release and this latency issue is crucial for me.
