I have a Xavier NX that is out in the field:
JETSON_CUDA_ARCH_BIN=7.2
JETSON_MODEL=NVIDIA Jetson Xavier NX Developer Kit
JETSON_L4T=32.6.1
JETSON_SOC=tegra194
JETSON_JETPACK=4.6
JETSON_CODENAME=Jakku
JETSON_P_NUMBER=p3668-0001
JETSON_MODULE=NVIDIA Jetson Xavier NX
I’m working on using the video decoder in our software through FFMPEG and have been using nvv4l2_dec.c as well as the other related nvv4l2 code files. For videos that have a width divisible by 64 the images look correct, however for other videos the images come out scrambled.
I tried some various things without really know what the problem is, such as enabling src/dst cropping, disabling the 64 alignment, and some other things. I could use some help to figure out what is wrong in nvv4l2_dec.c:
* Copyright (c) 2021-2022, CTCaer <ctcaer@gmail.com>
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <stdatomic.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <unistd.h>
#include <pthread.h>
#include <string.h>
#include <fcntl.h>
#include <errno.h>
#include "codec_internal.h"
#include "internal.h"
#include "libavutil/log.h"
#include "nvv4l2.h"
** Output plane format support:
** S264 (H264 Encoded Slice bitstream)
** VP8F (VP8 Encoded Slice bitstream)
** H264 (H264 Encoded bitstream)
** H265 (H265 Encoded bitstream)
** VP80 (VP8 Encoded bitstream)
** VP90 (VP9 Encoded bitstream)
** MPG2 (MPEG2 Encoded bitstream)
** MPG4 (MPEG4 Encoded bitstream)
** JPEG (JPEG Encoded bitstream)
** MJPG (MJPEG Encoded bitstream)
** DVX4 (divx Encoded bitstream)
** DVX5 (divx Encoded bitstream)
** Capture plane format support:
** NM12 (YUV 4:2:0)
** Output plane memory type support:
** V4L2_MEMORY_MMAP
** V4L2_MEMORY_USERPTR
** Capture plane memory type support:
** V4L2_MEMORY_MMAP
** V4L2_MEMORY_DMABUF
#define DECODER_DEV "/dev/nvhost-nvdec"
#define OP_PLANE_REQ_SIZEIMAGE 4000000
typedef struct {
char eos_reached;
nvv4l2_ctx_t *ctx;
AVClass *av_class;
} nvv4l2DecodeContext;
static int
set_output_plane_format(nvv4l2_ctx_t *ctx, uint32_t pixfmt,
uint32_t sizeimage)
int ret;
struct v4l2_format format;
memset(&format, 0, sizeof(struct v4l2_format));
format.type = ctx->op_buf_type;
format.fmt.pix_mp.pixelformat = pixfmt;
format.fmt.pix_mp.num_planes = 1;
format.fmt.pix_mp.plane_fmt[0].sizeimage = sizeimage;
ret = v4l2_ioctl(ctx->fd, VIDIOC_S_FMT, &format);
if (ret == 0) {
ctx->op_num_planes = format.fmt.pix_mp.num_planes;
for (uint32_t i = 0; i < ctx->op_num_planes; i++) {
ctx->op_planefmts[i].stride =
format.fmt.pix_mp.plane_fmt[i].bytesperline;
ctx->op_planefmts[i].sizeimage =
format.fmt.pix_mp.plane_fmt[i].sizeimage;
return ret;
static int
set_capture_plane_format(AVCodecContext *avctx, nvv4l2_ctx_t *ctx,
uint32_t pixfmt, uint32_t width, uint32_t height)
int ret;
uint32_t num_bufferplanes;
NvBufferPlaneFormat planefmts[NV_MAX_PLANES];
nvv4l2_fill_buffer_plane_format(ctx, &num_bufferplanes, planefmts, width,
height, pixfmt);
ctx->cp_num_planes = num_bufferplanes;
for (uint32_t i = 0; i < num_bufferplanes; i++) {
ctx->cp_planefmts[i] = planefmts[i];
format.type = ctx->cp_buf_type;
format.fmt.pix_mp.width = width;
format.fmt.pix_mp.height = height;
format.fmt.pix_mp.num_planes = num_bufferplanes;
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Error in VIDIOC_S_FMT!\n");
ctx->in_error = true;
} else {
ctx->cp_num_planes = format.fmt.pix_mp.num_planes;
for (uint32_t i = 0; i < ctx->cp_num_planes; i++) {
ctx->cp_planefmts[i].stride =
ctx->cp_planefmts[i].sizeimage =
return ret;
static void query_set_capture(AVCodecContext *avctx, nvv4l2_ctx_t *ctx)
struct v4l2_crop crop;
struct v4l2_control ctl;
int ret, cp_num_old_buffers;
int32_t min_cap_buffers;
NvBufferCreateParams input_params = { 0 };
NvBufferCreateParams cap_params = { 0 };
if (ctx->in_error || ctx->eos)
return;
/* Get format on capture plane set by device.
** This may change after an resolution change event.
ret = v4l2_ioctl(ctx->fd, VIDIOC_G_FMT, &format);
if (ret) {
"Could not get format from decoder capture plane!\n");
return;
/* Query cropping size and position. */
crop.type = ctx->cp_buf_type;
ret = v4l2_ioctl(ctx->fd, VIDIOC_G_CROP, &crop);
if (ret) {
"Could not get crop from decoder capture plane!\n");
return;
/* Set codec resolution */
ctx->codec_width = crop.c.width;
ctx->codec_height = crop.c.height;
av_log(avctx, AV_LOG_VERBOSE, "Resolution changed to: %dx%d\n",
ctx->codec_width, ctx->codec_height);
/* Destroy all allocated transform/export DMA buffers. */
for (uint32_t i = 0; i < NV_MAX_BUFFERS; i++) {
if (ctx->plane_dma_fd[i] != -1) {
ret = NvBufferDestroy(ctx->plane_dma_fd[i]);
if (ret < 0) {
"Failed to destroy plane buffer!\n");
} else {
ctx->plane_dma_fd[i] = -1;
** Due to VIC constrains the transformation from Block Linear to Pitch
** must have aligned widths to 64B. Otherwise the frame might be produced
** as scrambled.
ctx->plane_width_aligned = NVALIGN(crop.c.width, 64);
if (ctx->plane_width_aligned != crop.c.width)
av_log(avctx, AV_LOG_VERBOSE, "Linesize got aligned: %d -> %d\n",
crop.c.width, ctx->plane_width_aligned);
crop.c.width = ctx->plane_width_aligned;
/* Create transform/export DMA buffers. */
input_params.width = crop.c.width;
input_params.height = crop.c.height;
input_params.layout = NvBufferLayout_Pitch;
input_params.payloadType = NvBufferPayload_SurfArray;
input_params.nvbuf_tag = NvBufferTag_VIDEO_CONVERT;
switch (ctx->cp_pixfmt) {
case V4L2_PIX_FMT_YUV420M:
input_params.colorFormat = NvBufferColorFormat_YUV420;
break;
case V4L2_PIX_FMT_NV12M:
input_params.colorFormat = NvBufferColorFormat_NV12;
if (ctx->pixfmt_list_ver == NvBufferPixFmtVersion_New)
input_params.colorFormat++;
break;
ret = NvBufferCreateEx(&ctx->plane_dma_fd[i], &input_params);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Creation of dmabuf failed!\n");
/* Stop streaming. */
pthread_mutex_lock(&ctx->queue_lock);
ret = v4l2_ioctl(ctx->fd, VIDIOC_STREAMOFF, &ctx->cp_buf_type);
if (ret) {
} else {
pthread_cond_broadcast(&ctx->queue_cond);
pthread_mutex_unlock(&ctx->queue_lock);
/* Request buffers with count 0 and destroy all
** previously allocated buffers.
cp_num_old_buffers = ctx->cp_num_buffers;
ret = nvv4l2_req_buffers_on_capture_plane(ctx,
ctx->cp_buf_type,
ctx->cp_mem_type, 0);
if (ret) {
av_log(avctx, AV_LOG_WARNING,
"Error in requesting 0 capture plane buffers!\n");
/* Destroy previous DMA buffers. */
for (uint32_t i = 0; i < cp_num_old_buffers; i++) {
if (ctx->dmabuff_fd[i] != -1) {
ret = NvBufferDestroy(ctx->dmabuff_fd[i]);
if (ret) {
"Failed to Destroy NvBuffer!\n");
} else {
ctx->dmabuff_fd[i] = -1;
if (ctx->in_error)
return;
/* Set capture plane format to update vars. */
ret = set_capture_plane_format(avctx, ctx,
format.fmt.pix_mp.pixelformat,
format.fmt.pix_mp.width,
format.fmt.pix_mp.height);
if (ret) {
"Error in setting capture plane format!\n");
return;
/* Get control value for min buffers which have to
** be requested on capture plane.
ctl.id = V4L2_CID_MIN_BUFFERS_FOR_CAPTURE;
ret = v4l2_ioctl(ctx->fd, VIDIOC_G_CTRL, &ctl);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Error getting value of control!\n");
return;
} else {
min_cap_buffers = ctl.value;
/* Set color format based on colorspace and quantization type. */
switch(format.fmt.pix_mp.colorspace)
case V4L2_COLORSPACE_REC709:
if (format.fmt.pix_mp.quantization == V4L2_QUANTIZATION_DEFAULT)
"Colorspace ITU-R BT.709 with standard range luma (16-235)\n");
cap_params.colorFormat = NvBufferColorFormat_NV12_709;
else
"Colorspace ITU-R BT.709 with extended range luma (0-255)\n");
cap_params.colorFormat = NvBufferColorFormat_NV12_709_ER;
break;
case V4L2_COLORSPACE_BT2020:
"Colorspace ITU-R BT.2020\n");
cap_params.colorFormat = NvBufferColorFormat_NV12_2020;
break;
default:
"Colorspace details are missing, using default\n");
case V4L2_COLORSPACE_SMPTE170M:
"Colorspace ITU-R BT.601 with standard range luma (16-235)\n");
cap_params.colorFormat = NvBufferColorFormat_NV12;
else
"Colorspace ITU-R BT.601 with extended range luma (0-255)\n");
cap_params.colorFormat = NvBufferColorFormat_NV12_ER;
break;
/* Increment color format if NvBuffer is newer. */
cap_params.colorFormat++;
/* Request number of buffers returned by ctrl, plus 10 more. */
ctx->cp_num_buffers = min_cap_buffers + 10;
/* Create DMA Buffers by defining the parameters for the HW Buffer. */
cap_params.width = crop.c.width;
cap_params.height = crop.c.height;
cap_params.layout = NvBufferLayout_BlockLinear;
cap_params.payloadType = NvBufferPayload_SurfArray;
cap_params.nvbuf_tag = NvBufferTag_VIDEO_DEC;
for (uint32_t i = 0; i < ctx->cp_num_buffers; i++) {
ret = NvBufferCreateEx(&ctx->dmabuff_fd[i], &cap_params);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Failed to create buffers!\n");
return;
/* Request buffers on capture plane. */
ctx->cp_buf_type,
ctx->cp_mem_type,
ctx->cp_num_buffers);
if (ret) {
"Error in requesting capture plane buffers!\n");
return;
/* Set max performance mode if low latency is requested. */
if (ctx->low_latency) {
ret = nvv4l2_set_ext_controls(ctx->fd,
V4L2_CID_MPEG_VIDEO_MAX_PERFORMANCE, 0, 1);
if (ret) {
"Failed to set control max performance!\n");
/* Set streaming status ON on capture plane. */
ret = v4l2_ioctl(ctx->fd, VIDIOC_STREAMON, &ctx->cp_buf_type);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Streaming error on capture plane!\n");
return;
/* Enqueue all empty buffers on capture plane. */
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[NV_MAX_PLANES];
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, sizeof(planes));
v4l2_buf.index = i;
v4l2_buf.m.planes = planes;
v4l2_buf.type = ctx->cp_buf_type;
v4l2_buf.memory = ctx->cp_mem_type;
v4l2_buf.length = ctx->cp_num_planes;
/* Set DMA plane handle. */
v4l2_buf.m.planes[0].m.fd = ctx->dmabuff_fd[i];
v4l2_buf.m.planes[1].m.fd = ctx->dmabuff_fd[i];
ret = nvv4l2_q_buffer(ctx, &v4l2_buf, ctx->cp_buffers[i],
ctx->cp_buf_type, ctx->cp_mem_type,
ctx->cp_num_planes);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Qing failed on capture plane!\n");
ctx->cp_streamon = true;
return;
av_log(avctx, AV_LOG_VERBOSE, "Query and set capture successful\n");
return;
static void *dec_capture_thread(void *arg)
nvv4l2_ctx_t *ctx = (nvv4l2_ctx_t *)arg;
struct v4l2_event event;
int buf_index;
int ret;
av_log(ctx->avctx, AV_LOG_VERBOSE, "Starting capture thread\n");
/* Need to wait for the first Resolution change event, so that
** the decoder knows the stream resolution and can allocate
** appropriate buffers when REQBUFS is called.
do {
/* Dequeue the subscribed event. */
ret = nvv4l2_dq_event(ctx, &event, 50000);
if (ret) {
if (errno == EAGAIN) {
"Timeout waiting for first resolution event!\n");
} else {
av_log(ctx->avctx, AV_LOG_ERROR,
"Error in dequeuing decoder event!\n");
break;
while ((event.type != V4L2_EVENT_RESOLUTION_CHANGE) &&
!ctx->in_error && !ctx->eos);
/* Received first resolution change event
** Format and buffers are now set on capture.
query_set_capture(ctx->avctx, ctx);
/* Check for resolution event to again
** set format and buffers on capture plane.
while (!ctx->in_error && !ctx->eos) {
ret = nvv4l2_dq_event(ctx, &event, 0);
if (ret == 0) {
switch (event.type) {
case V4L2_EVENT_RESOLUTION_CHANGE:
continue;
/* Main Capture loop for DQ and Q. */
while (!ctx->eos) {
struct v4l2_buffer v4l2_cp_buf;
struct v4l2_plane capture_planes[NV_MAX_PLANES];
NvBufferRect src_rect, dest_rect;
NvBufferParams buf_params;
NvBufferTransformParams transform_params;
memset(&v4l2_cp_buf, 0, sizeof(v4l2_cp_buf));
memset(capture_planes, 0, sizeof(capture_planes));
v4l2_cp_buf.m.planes = capture_planes;
/* Dequeue the filled buffer. */
if (nvv4l2_dq_buffer(ctx, &v4l2_cp_buf, NULL,
ctx->cp_buf_type, ctx->cp_mem_type, 0)) {
usleep(1000);
break;
/* Transformation parameters are defined
** which are passed to the NvBufferTransform
** for required conversion.
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = ctx->codec_width;
src_rect.height = ctx->codec_height;
dest_rect.top = 0;
dest_rect.left = 0;
dest_rect.width = ctx->codec_width;
dest_rect.height = ctx->codec_height;
/* @transform_flag defines the flags for enabling the
** valid transforms. All the valid parameters are
** present in the nvv4l2_ext_utils header.
transform_params.transform_flag = NVBUFFER_TRANSFORM_FILTER;
transform_params.transform_flip = NvBufferTransform_None;
transform_params.transform_filter =
NvBufferTransform_Filter_Smart;
transform_params.src_rect = src_rect;
transform_params.dst_rect = dest_rect;
transform_params.session = ctx->buf_session;
buf_index = nvv4l2_pool_idx_next(ctx, ctx->export_pool);
/* Blocklinear to Pitch transformation is required
** to dump the raw decoded buffer data.
if (buf_index >= 0) {
ret = NvBufferTransform(ctx->dmabuff_fd[v4l2_cp_buf.index],
ctx->plane_dma_fd[buf_index],
&transform_params);
if (ret == -1) {
av_log(ctx->avctx, AV_LOG_ERROR, "Transform failed!\n");
break;
ret = NvBufferGetParams(ctx->plane_dma_fd[buf_index],
&buf_params);
if (ret) {
av_log(ctx->avctx, AV_LOG_ERROR, "GetParams failed!\n");
break;
ctx->plane_width[0] = buf_params.width[0];
ctx->plane_height[0] = buf_params.height[0];
ctx->plane_width[1] = buf_params.width[1];
ctx->plane_height[1] = buf_params.height[1];
if (ctx->cp_pixfmt == V4L2_PIX_FMT_YUV420M) {
ctx->plane_width[2] = buf_params.width[2];
ctx->plane_height[2] = buf_params.height[2];
/* Set timestamp based on origin pts flags */
if (v4l2_cp_buf.timestamp.tv_usec == 0 &&
v4l2_cp_buf.timestamp.tv_sec == NV_V4L2_NOPTS_VALUE) {
/* Origin packet had no pts and user pts values. */
ctx->frame_pts[buf_index] = AV_NOPTS_VALUE;
ctx->frame_user_pts[buf_index] = AV_NOPTS_VALUE;
} else if (v4l2_cp_buf.timestamp.tv_sec &
NV_V4L2_REORDERED_OPAQUE_FLAG) {
/* Origin packet had only user pts value. */
v4l2_cp_buf.timestamp.tv_sec &=
(~NV_V4L2_REORDERED_OPAQUE_FLAG);
v4l2_cp_buf.timestamp.tv_usec +
(v4l2_cp_buf.timestamp.tv_sec * AV_TIME_BASE);
} else {
/* Origin packet had pts value. */
nvv4l2_pool_push(ctx, ctx->export_pool);
pthread_mutex_lock(&ctx->frame_lock);
pthread_cond_signal(&ctx->frame_cond);
pthread_mutex_unlock(&ctx->frame_lock);
v4l2_cp_buf.m.planes[0].m.fd = ctx->dmabuff_fd[v4l2_cp_buf.index];
/* Queue the buffer. */
ret = nvv4l2_q_buffer(ctx, &v4l2_cp_buf, NULL, ctx->cp_buf_type,
ctx->cp_mem_type, ctx->cp_num_planes);
if (ret) {
if (ctx->draining_event) {
ctx->draining_event = false;
"Draining event, rejecting error\n");
} else {
break;
pthread_cond_broadcast(&ctx->frame_cond);
"Exiting decoder capture loop thread\n");
return NULL;
int
nvv4l2_decoder_get_frame(AVCodecContext *avctx, nvv4l2_ctx_t *ctx,
int *buf_index, NvFrame *frame)
struct timespec timeout;
struct timeval now;
int _buf_index;
int ret = 0;
/* In low latency mode, block until a decoded frame is ready. */
while (atomic_load(&ctx->export_pool->capacity) == 0 &&
!ctx->eos && !ctx->in_error && ret != ETIMEDOUT) {
/* 500ms timeout */
gettimeofday(&now, NULL);
timeout.tv_nsec = (now.tv_usec + 500000L) * 1000L;
timeout.tv_sec = now.tv_sec + timeout.tv_nsec / 1000000000L;
timeout.tv_nsec = timeout.tv_nsec % 1000000000L;
ret = pthread_cond_timedwait(&ctx->frame_cond,
&ctx->frame_lock, &timeout);
if (ctx->export_pool->capacity == 0)
return 1;
_buf_index = nvv4l2_pool_pop(ctx, ctx->export_pool);
frame->width = ctx->codec_width;
frame->height = ctx->codec_height;
frame->pts = ctx->frame_pts[_buf_index];
frame->user_pts = ctx->frame_user_pts[_buf_index];
*buf_index = _buf_index;
return 0;
int
nvv4l2_decoder_put_packet(AVCodecContext *avctx, nvv4l2_ctx_t *ctx,
NvPacket *packet)
int ret;
/* Read the encoded data and Enqueue the output
** plane buffers. Exit loop in case file read is complete.
struct v4l2_buffer v4l2_buf_op;
struct v4l2_plane queue_op_planes[NV_MAX_PLANES];
NvBuffer *buffer;
memset(&v4l2_buf_op, 0, sizeof(v4l2_buf_op));
memset(queue_op_planes, 0, sizeof(queue_op_planes));
v4l2_buf_op.m.planes = queue_op_planes;
if (ctx->num_active_op_buffers < ctx->op_num_buffers) {
/* Get an unused buffer to add to the queue. */
buffer = ctx->op_buffers[ctx->num_active_op_buffers];
v4l2_buf_op.index = ctx->num_active_op_buffers;
} else {
/* Dequeue a finished buffer and reuse it. */
ret = nvv4l2_dq_buffer(ctx, &v4l2_buf_op, &buffer,
ctx->op_buf_type, ctx->op_mem_type, -1);
if (ret) {
"Error DQing buffer at output plane!\n");
return -1;
/* Copy packet data. */
memcpy(buffer->planes[0].data, packet->payload, packet->payload_size);
buffer->planes[0].bytesused = packet->payload_size;
v4l2_buf_op.m.planes[0].bytesused = buffer->planes[0].bytesused;
/* Set timestamp based on packet flags. */
v4l2_buf_op.flags |= V4L2_BUF_FLAG_TIMESTAMP_COPY;
if (packet->pts != AV_NOPTS_VALUE) {
/* Packet pts is valid */
v4l2_buf_op.timestamp.tv_sec = packet->pts / AV_TIME_BASE;
v4l2_buf_op.timestamp.tv_usec = packet->pts % AV_TIME_BASE;
} else if (packet->user_pts != AV_NOPTS_VALUE) {
/* User pts is valid */
v4l2_buf_op.timestamp.tv_sec = packet->user_pts / AV_TIME_BASE;
v4l2_buf_op.timestamp.tv_usec = packet->user_pts % AV_TIME_BASE;
v4l2_buf_op.timestamp.tv_sec |= NV_V4L2_REORDERED_OPAQUE_FLAG;
} else {
/* No valid pts or user pts */
v4l2_buf_op.timestamp.tv_sec = NV_V4L2_NOPTS_VALUE;
v4l2_buf_op.timestamp.tv_usec = 0;
/* Queue packet on output plane. */
ret = nvv4l2_q_buffer(ctx, &v4l2_buf_op, buffer,
ctx->op_buf_type, ctx->op_mem_type, ctx->op_num_planes);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Error Qing buffer at output plane!\n");
return -1;
ctx->num_active_op_buffers++;
if (v4l2_buf_op.m.planes[0].bytesused == 0) {
ctx->eos = true;
av_log(avctx, AV_LOG_VERBOSE, "Input file read complete\n");
return 0;
nvv4l2_ctx_t *nvv4l2_create_decoder(AVCodecContext *avctx,
NvCodingType nv_codec_type,
int pix_fmt)
nvv4l2_ctx_t *ctx = (nvv4l2_ctx_t *)NVCALLOC(1, sizeof(nvv4l2_ctx_t));
int ret = 0;
int flags = 0;
ctx->avctx = avctx;
/* The call creates a new V4L2 Video Decoder object
** on the device node "/dev/nvhost-nvdec"
** Additional flags can also be given with which the device
** should be opened.
** This opens the device in Blocking mode.
ctx->fd = v4l2_open(DECODER_DEV, flags | O_RDWR);
if (ctx->fd == -1) {
av_log(avctx, AV_LOG_ERROR, "Could not open device!\n");
return ctx;
/* Initialization. */
ctx->cp_pixfmt = pix_fmt;
ctx->op_pixfmt = nvv4l2_map_nvcodec_type(nv_codec_type);
/* Get NvBuffer pixel format list version */
ctx->pixfmt_list_ver = nvv4l2_get_pixfmt_list_version(ctx);
/* Get a NvBuffer session for interprocess transforms */
ctx->buf_session = NvBufferSessionCreate();
/* Decoder code assumes that the following do not change.
** If another memory type is wanted, relevant changes should be done
** to the rest of the code.
ctx->op_mem_type = V4L2_MEMORY_USERPTR;
ctx->cp_mem_type = V4L2_MEMORY_DMABUF;
ctx->op_buf_type = V4L2_BUF_TYPE_VIDEO_OUTPUT_MPLANE;
ctx->cp_buf_type = V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE;
/* Allocate packet pool. */
ctx->export_pool = (NvQueues *)NVCALLOC(1, sizeof(NvQueues));
/* Initialize mutexes */
pthread_mutex_init(&ctx->queue_lock, NULL);
pthread_mutex_init(&ctx->frame_lock, NULL);
pthread_cond_init(&ctx->queue_cond, NULL);
pthread_cond_init(&ctx->frame_cond, NULL);
/* Subscribe to Resolution change event.
** This is required to catch whenever resolution change event
** is triggered to set the format on capture plane.
ret = nvv4l2_subscribe_event(ctx->fd,
V4L2_EVENT_RESOLUTION_CHANGE,
0, 0);
if (ret) {
"Failed to subscribe for resolution change!\n");
/* Set format on output plane.
** The format of the encoded bitstream is set.
ret = set_output_plane_format(ctx, ctx->op_pixfmt, OP_PLANE_REQ_SIZEIMAGE);
if (ret) {
"Error in setting output plane format!\n");
/* Set appropriate controls.
** V4L2_CID_MPEG_VIDEO_DISABLE_COMPLETE_FRAME_INPUT control is
** set to false as the application always sends NALUs.
** Also, mandatory when V4L2_BUF_FLAG_TIMESTAMP_COPY is used.
ret =
V4L2_CID_MPEG_VIDEO_DISABLE_COMPLETE_FRAME_INPUT,
0, 0);
if (ret) {
"Failed to set control enable complete frame!\n");
/* Request buffers on output plane to fill
** the input bitstream.
ret = nvv4l2_req_buffers_on_output_plane(ctx,
ctx->op_buf_type,
ctx->op_mem_type, 10);
if (ret) {
"Error in requesting buffers on output plane!\n");
for (uint32_t i = 0; i < ctx->op_num_buffers; i++) {
if (nvv4l2_allocate_memory(ctx, ctx->op_buffers[i])) {
"Buffer mapping error on output plane!\n");
/* Start stream processing on output plane
** by setting the streaming status ON.
ret = v4l2_ioctl(ctx->fd, VIDIOC_STREAMON, &ctx->op_buf_type);
if (ret != 0) {
av_log(avctx, AV_LOG_ERROR, "Streaming error on output plane!\n");
ctx->op_streamon = true;
/* Create and start capture loop thread. */
pthread_create(&ctx->capture_thread, NULL, dec_capture_thread, ctx);
return ctx;
int nvv4l2_decoder_close(AVCodecContext *avctx, nvv4l2_ctx_t *ctx)
if (!ctx)
return 0;
ctx->eos = true;
if (ctx->fd != -1) {
/* Stop streaming on both planes. */
ret = v4l2_ioctl(ctx->fd, VIDIOC_STREAMOFF, &ctx->op_buf_type);
ctx->op_streamon = false;
ctx->cp_streamon = false;
/* Wait for capture thread to exit. */
if (ctx->capture_thread) {
pthread_join(ctx->capture_thread, NULL);
/* Request 0 buffers on both planes. */
ctx->op_buf_type,
ctx->op_mem_type, 0);
ctx->cp_buf_type,
/* All allocated DMA buffers must be destroyed. */
if (ret < 0) {
"Failed to destroy dma buffer!\n");
if (ret < 0) {
/* Destroy NvBuffer session. */
if (ctx->buf_session)
NvBufferSessionDestroy(ctx->buf_session);
NVFREE(ctx->export_pool);
/* Close the opened V4L2 device. */
ret = v4l2_close(ctx->fd);
if (ret) {
av_log(avctx, AV_LOG_ERROR, "Unable to close the device!\n");
/* Free mutexes */
pthread_mutex_destroy(&ctx->queue_lock);
pthread_mutex_destroy(&ctx->frame_lock);
pthread_cond_destroy(&ctx->queue_cond);
pthread_cond_destroy(&ctx->frame_cond);
/* Report application run status on exit. */
if (ctx->in_error) {
av_log(avctx, AV_LOG_VERBOSE, "Decoder Run failed\n");
} else {
av_log(avctx, AV_LOG_VERBOSE, "Decoder Run was successful\n");
NVFREE(ctx);
return ret;
static NvCodingType map_avcodec_id(enum AVCodecID id)
switch (id) {
case AV_CODEC_ID_H264:
return NvVideoCodec_H264;
case AV_CODEC_ID_HEVC:
return NvVideoCodec_HEVC;
case AV_CODEC_ID_MPEG2VIDEO:
return NvVideoCodec_MPEG2;
case AV_CODEC_ID_MPEG4:
return NvVideoCodec_MPEG4;
case AV_CODEC_ID_VP8:
return NvVideoCodec_VP8;
case AV_CODEC_ID_VP9:
return NvVideoCodec_VP9;
return NvVideoCodec_UNDEFINED;
static int nvv4l2dec_init(AVCodecContext *avctx)
if (initialize_LoadedNvBuf(1)) {
return AVERROR(ENOSYS);
nvv4l2DecodeContext *nvv4l2_ctx = avctx->priv_data;
NvCodingType nv_codec_type = map_avcodec_id(avctx->codec_id);
int pix_fmt;
if (nv_codec_type == NvVideoCodec_UNDEFINED) {
av_log(avctx, AV_LOG_ERROR, "Unsupported codec ID %d!\n",
avctx->codec_id);
return AVERROR_BUG;
switch (avctx->pix_fmt) {
case AV_PIX_FMT_NONE:
avctx->pix_fmt = AV_PIX_FMT_YUV420P;
case AV_PIX_FMT_YUV420P:
pix_fmt = V4L2_PIX_FMT_YUV420M;
break;
case AV_PIX_FMT_NV12:
pix_fmt = V4L2_PIX_FMT_NV12M;
break;
default:
av_log(avctx, AV_LOG_ERROR, "Unsupported pixel format %d!\n",
avctx->pix_fmt);
return AVERROR_BUG;
nvv4l2_ctx->ctx = nvv4l2_create_decoder(avctx, nv_codec_type, pix_fmt);
if (!nvv4l2_ctx->ctx || nvv4l2_ctx->ctx->in_error) {
av_log(avctx, AV_LOG_ERROR, "Failed to create nvv4l2 decoder!\n");
if (nvv4l2_ctx->ctx && nvv4l2_ctx->ctx->in_error) {
nvv4l2_decoder_close(avctx, nvv4l2_ctx->ctx);
return AVERROR_UNKNOWN;
** Check if low latency is needed.
** Depends on whole frames received instead of slices.
** Otherwise the decoder only starts streaming after a
** required amount of packets received.
nvv4l2_ctx->ctx->low_latency =
(avctx->flags & AV_CODEC_FLAG_LOW_DELAY) ? true : false;
return 0;
static void nvv4l2dec_flush(AVCodecContext *avctx)
nvv4l2_ctx_t *ctx = nvv4l2_ctx->ctx;
int ret = 0;
/* Flush all queued buffers from output and capture plane. */
if (ctx->op_streamon && ctx->cp_streamon &&
(ctx->num_queued_op_buffers || ctx->num_active_op_buffers)) {
/* Turn on output plane streaming. */
if (ret != 0) {
} else {
ctx->draining_event = true;
ctx->num_active_op_buffers = 0;
ctx->num_queued_op_buffers = 0;
ctx->num_queued_cp_buffers = 0;
/* Turn on capture plane streaming. */
if (ret != 0) {
} else {
/* Re-enqueue all now empty buffers on capture plane. */
v4l2_buf.index = i;
/* Set DMA plane handle */
if (ret) {
"Qing empty failed on capture plane!\n");
/* Flush all decoded frames from frame pool */
while (ctx->export_pool->capacity != 0) {
ctx->export_pool->front = 0;
ctx->export_pool->back = 0;
static int nvv4l2dec_close(AVCodecContext *avctx)
return nvv4l2_decoder_close(avctx, nvv4l2_ctx->ctx);
static int
nvv4l2dec_decode(AVCodecContext *avctx, void *data, int *got_frame,
AVPacket *avpkt)
AVFrame *avframe = (AVFrame *)data;
NvFrame _nvframe = { 0 };
int processed_size = 0;
int buf_index = -1;
if (avpkt->size) {
NvPacket packet;
packet.payload_size = avpkt->size;
packet.payload = avpkt->data;
packet.pts = avpkt->pts;
packet.user_pts = avctx->reordered_opaque;
if (!nvv4l2_decoder_put_packet(avctx, ctx, &packet)) {
processed_size = avpkt->size;
} else {
/* Get a decoded frame if any. */
if (nvv4l2_decoder_get_frame(avctx, ctx, &buf_index, &_nvframe))
return processed_size;
/* Set coded width to aligned size to fit the transformation.
** It gets restored after transformation by default.
avctx->coded_width = ctx->plane_width_aligned;
/* Get frame data buffers. */
if (ff_get_buffer(avctx, avframe, 0) < 0)
return AVERROR(ENOMEM);
/* Export decoded frame data. */
if (buf_index >= 0 && avframe->data[0]) {
NvBuffer2Raw(ctx->plane_dma_fd[buf_index], 0,
ctx->plane_width[0], ctx->plane_height[0],
avframe->data[0]);
NvBuffer2Raw(ctx->plane_dma_fd[buf_index], 1,
ctx->plane_width[1], ctx->plane_height[1],
avframe->data[1]);
NvBuffer2Raw(ctx->plane_dma_fd[buf_index], 2,
ctx->plane_width[2], ctx->plane_height[2],
avframe->data[2]);
avframe->width = _nvframe.width;
avframe->height = _nvframe.height;
avframe->format = avctx->pix_fmt;
avframe->pkt_dts = AV_NOPTS_VALUE;
/* Decide which timestamps to set. */
if (_nvframe.pts != AV_NOPTS_VALUE) {
avframe->pts = _nvframe.pts;
} else {
avframe->reordered_opaque = _nvframe.user_pts;
avframe->key_frame = 0;
avctx->coded_width = _nvframe.width;
avctx->coded_height = _nvframe.height;
avctx->width = _nvframe.width;
avctx->height = _nvframe.height;
*got_frame = 1;
#define NVV4L2_DEC_CLASS(NAME) \
static const AVClass nvv4l2_##NAME##_dec_class = { \
.class_name = "nvv4l2_" #NAME "_dec", \
.version = LIBAVUTIL_VERSION_INT, \
#define NVV4L2_DEC(NAME, ID, BSFS) \
const FFCodec ff_##NAME##_nvv4l2_decoder = { \
.p.name = #NAME "_nvv4l2", \
.p.long_name = NULL_IF_CONFIG_SMALL(#NAME " NVV4L2 HW decoder for Tegra"), \
.p.type = AVMEDIA_TYPE_VIDEO, \
.p.id = ID, \
.priv_data_size = sizeof(nvv4l2DecodeContext), \
.init = nvv4l2dec_init, \
.close = nvv4l2dec_close, \
FF_CODEC_DECODE_CB(nvv4l2dec_decode), \
.flush = nvv4l2dec_flush, \
.p.priv_class = &nvv4l2_##NAME##_dec_class, \
.p.capabilities = AV_CODEC_CAP_DELAY | AV_CODEC_CAP_HARDWARE | \
AV_CODEC_CAP_AVOID_PROBING, \
.bsfs = BSFS, \
.p.wrapper_name = "nvv4l2", \
.p.pix_fmts =(const enum AVPixelFormat[]){ AV_PIX_FMT_YUV420P, \
AV_PIX_FMT_NV12, \
AV_PIX_FMT_NONE }, \
NVV4L2_DEC(h264, AV_CODEC_ID_H264, "h264_mp4toannexb");
NVV4L2_DEC(hevc, AV_CODEC_ID_HEVC, "hevc_mp4toannexb");
NVV4L2_DEC(mpeg2, AV_CODEC_ID_MPEG2VIDEO, NULL);
NVV4L2_DEC(mpeg4, AV_CODEC_ID_MPEG4, NULL);
NVV4L2_DEC(vp9, AV_CODEC_ID_VP9, NULL);
NVV4L2_DEC(vp8, AV_CODEC_ID_VP8, NULL);
