xavier
Tegra_Multimedia_API_R32.1.0_aarch64.tbz2
tx2
Tegra_Multimedia_API_R28.2.1_aarch64.tbz2
# /home/nvidia/jetson_clocks.sh
# nvpmodel -m 0
# nvpmodel -q –-verbose
NV Power Mode: MAXN
0
encode
I Modify the sample code,
code like this:
static int64_t av_gettime(void)
struct timeval tv;
gettimeofday(&tv, NULL);
return (int64_t)tv.tv_sec * 1000000 + tv.tv_usec;
// in function encoder_capture_plane_dq_callback()
static int64_t frame1_ts = 0;
static int64_t frame101_ts = 0;
if(num_encoded_frames == 101) {
frame1_ts = av_gettime();
printf("[%d] encode out time=[%lldus]\n", num_encoded_frames, frame1_ts);
if(num_encoded_frames == 201) {
frame101_ts = av_gettime();
int64_t diff = frame101_ts-frame1_ts;
printf("[%d] encode out time=[%lldus]\n", num_encoded_frames, frame101_ts);
printf("100 frames diff=[%lldus] = [%lld]ms, one frame=[%lld]ms, fps=[%lld]\n", diff, diff/1000, diff/100000, 100000*1000/diff);
// write_encoder_output_frame(ctx->out_file, buffer);
num_encoded_frames++;
I record 100 out frames times which from 101 frame to 201, then calculate the Average FPS
test case 1: h264 high slow
tx2
./video_encode /run/1_10s.yuv 1920 1080 H264 /dev/null -p high -hpt 4
Failed to query video capabilities: Inappropriate ioctl for device
NvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
===== MSENC blits (mode: 1) into tiled surfaces =====
[101] encode out time=[1563953079644380us]
[201] encode out time=[1563953080113849us]
100 frames diff=[469469us] = [469]ms, one frame=[4]ms, fps=[213]
xavier
Creating Encoder in blocking mode
Opening in BLOCKING MODE
===== NVMEDIA: NVENC =====
875967048
842091865
H264: Profile = 100, Level = 51
encoder_proc_blocking
[101] encode out time=[1563548857378434us]
[201] encode out time=[1563548857982769us]
100 frames diff=[604335us] = [604]ms, one frame=[6]ms, fps=[165]
test case 2: h265 main slow
tx2
./video_encode /run/1_10s.yuv 1920 1080 H265 /dev/null -p main -hpt 4
NvMMLiteOpen : Block : BlockType = 8
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
892744264
842091865
===== NVENC blits (mode: 1) into block linear surfaces =====
[101] encode out time=[1563953596532325us]
[201] encode out time=[1563953597289380us]
100 frames diff=[757055us] = [757]ms, one frame=[7]ms, fps=[132]
xavier
892744264
842091865
NVMEDIA: H265 : Profile : 1
[101] encode out time=[1563548959778863us]
[201] encode out time=[1563548960694426us]
100 frames diff=[915563us] = [915]ms, one frame=[9]ms, fps=[109]
test case 3: h264 baseline ultrafast
tx2
./video_encode /run/1_10s.yuv 1920 1080 H264 /dev/null -p baseline -hpt 1
===== MSENC =====
875967048
842091865
[101] encode out time=[1563953729986357us]
[201] encode out time=[1563953730266781us]
100 frames diff=[280424us] = [280]ms, one frame=[2]ms, fps=[356]
xavier
875967048
842091865
H264: Profile = 66, Level = 51
[101] encode out time=[1563549100991580us]
[201] encode out time=[1563549101227567us]
100 frames diff=[235987us] = [235]ms, one frame=[2]ms, fps=[423]
so result:
Average FPS:
h264 high slow: tx2: 213, xavier: 165
h265 main slow: tx2: 132, xavier: 109
h264 baseline ultrafast: tx2: 356, xavier: 423
these results do not match that in this link http://connecttech.com/xavier-tx2-comparison/
test video: 1_10s.h264 1920x1080@25fps high
decode:
xavier
./video_decode H264 --disable-rendering --stats -o /dev/null /run/1_10s.h264
Set governor to performance before enabling profiler
Creating decoder in blocking mode
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
Setting frame input mode to 1
Starting decoder capture loop thread
Input file read complete
Video Resolution: 1920x1080
supported colorspace details not available, use default
Decoder colorspace ITU-R BT.601 with standard range luma (16-235)
Query and set capture successful
----------- Element = dec0 -----------
Total Profiling time = 0.402865
Average FPS = 620.555
Total units processed = 251
Total Profiling Time = 0 sec
Exiting decoder capture loop thread
App run was successful
tx2:
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
TVMR: NvMMLiteTVMRDecDoWork: 6531: NVMMLITE_TVMR: EOS detected
TVMR: cbBeginSequence: 1179: BeginSequence 1920x1088, bVPR = 0
TVMR: LowCorner Frequency = 0
TVMR: cbBeginSequence: 1529: DecodeBuffers = 5, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1600: Display Resolution : (1920x1080)
TVMR: cbBeginSequence: 1601: Display Aspect Ratio : (1920x1080)
TVMR: cbBeginSequence: 1669: ColorFormat : 5
TVMR: cbBeginSequence:1683 ColorSpace = NvColorSpace_YCbCr601
TVMR: cbBeginSequence: 1809: SurfaceLayout = 3
TVMR: cbBeginSequence: 1902: NumOfSurfaces = 12, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 1904: BeginSequence ColorPrimaries = 2, TransferCharacteristics = 2, MatrixCoefficients = 2
TVMR: TVMRBufferProcessing: 5486: Processing of EOS
TVMR: TVMRBufferProcessing: 5563: Processing of EOS Done
Total Profiling time = 0.396803
Average FPS = 630.036
TVMR: TVMRFrameStatusReporting: 6132: Closing TVMR Frame Status Thread -------------
TVMR: TVMRVPRFloorSizeSettingThread: 5942: Closing TVMRVPRFloorSizeSettingThread -------------
TVMR: TVMRFrameDelivery: 5982: Closing TVMR Frame Delivery Thread -------------
TVMR: NvMMLiteTVMRDecBlockClose: 7815: Done
so result:
Average FPS, xavier is 620.555 , tx2 is 630.036. this result do not match that in this link http://connecttech.com/xavier-tx2-comparison/
