Hi is here anyone who knows if the hardware watchpoint in cuda-gdb can actually work or not? I tried to use it to watch a shared mem variable, but it never stops even if I find the value of that variable has changed. Thanks!
Related topics
| cuda-gdb hardware watchpoints for global memory debugging in Linux | 2 | 10703 | September 11, 2010 | |
| Creating a watchpoint in debugger (gdb, totalview) will crash TX1 system | 2 | 714 | October 18, 2021 | |
| Still cannot properly watch variables in CUDA kernels | 27 | 4246 | February 23, 2021 | |
| Cuda-gdb: Breakpoint at a particular block | 1 | 3625 | July 13, 2011 | |
| Question about print variable value in cuda-gdb | 0 | 6350 | April 19, 2010 | |
| Ocelot PTX Debugger | 5 | 8101 | July 23, 2010 | |
| cuda-gdb don't stop the program | 1 | 1583 | January 24, 2020 | |
| Cuda-gdb doesn't print correct value that a pointer point to within the kernel | 5 | 1633 | March 15, 2022 | |
| cuda-gdb can't examine device memory? | 2 | 2514 | November 25, 2010 | |
| About the CUDA-GDB category | 1 | 1947 | February 29, 2024 |
