I’m having issues with installation of cuda on my system, trying to install it using the apt package manager was giving the error below error so i tried searching for a solution for it and found a bit similar issue so I tried following the answer given at nvidia forum link but it didn’t help.
xserver-xorg-video-nvidia : Depends: xserver-xorg-core (< 2:1.20.99) but 2:21.1.4-2 is to be installed
$ uname -a
Linux kali 5.18.0-kali7-amd64 #1 SMP PREEMPT_DYNAMIC Debian 5.18.16-1kali1 (2022-08-31) x86_64 GNU/Linux
$ sudo sh cuda_11.8.0_520.61.05_linux.run
[sudo] password for secovfshanks:
Installation failed. See log at /var/log/cuda-installer.log for details.
$ cat /var/log/cuda-installer.log
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 12.2.0 (Debian 12.2.0-3)
[INFO]: Initializing menu
[INFO]: nvidia-fs.setKOVersion(2.13.5)
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 520.61.05
[INFO]: Executing NVIDIA-Linux-x86_64-520.61.05.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed. Consult the driver log at /var/log/nvidia-installer.log for more details.
[ERROR]: Install of 520.61.05 failed, quitting
