I’m trying to install CUDA 11.7 (the latest) on Debian sid using the NVIDIA-recommended method, but am running into the following errors:
$ uname -a
Linux foo 5.17.0-1-amd64 #1 SMP PREEMPT Debian 5.17.3-1 (2022-04-18) x86_64 GNU/Linux
$ sudo apt install cuda
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xserver-xorg-video-nvidia : Depends: xorg-video-abi-24 but it is not installable or
xorg-video-abi-23 but it is not installable or
xorg-video-abi-20 but it is not installable or
xorg-video-abi-19 but it is not installable or
xorg-video-abi-18 but it is not installable or
xorg-video-abi-15 but it is not installable or
xorg-video-abi-14 but it is not installable or
xorg-video-abi-13 but it is not installable or
xorg-video-abi-12 but it is not installable or
xorg-video-abi-11 but it is not installable or
xorg-video-abi-10 but it is not installable or
xorg-video-abi-8 but it is not installable or
xorg-video-abi-6.0 but it is not installable
Depends: xserver-xorg-core (< 2:1.20.99) but 2:21.1.3-2+b1 is to be installed
E: Unable to correct problems, you have held broken packages.
I believe that the older xorg
/ xserver
packages are no longer eligible installation candidates because apt
installed a new package xcvt
the last time I did sudo apt dist-upgrade
. Aside from that, there are no weird broken dependencies on my system; everything is up-to-date.
What is the best way to get CUDA installed at this point? Is there a way to get it installed without downgrading a bunch of packages? (Installing xcvt
also resulted in a lot of x* packages being upgraded, so I’m not even sure of everything I’d have to revert or what else that might break.)
Does something need to be fixed with the NVIDIA packages so they are compatible with xcvt and/or the latest xserver-xorg-core version?
Thanks in advance for any help!
