Hi - struggling to install CUDA 11.x (really any version >= 11) on amd64 Ubuntu 18.04, though I’ve tried most often with CUDA 11.3. Previously had CUDA 10.2 installed, but purged it via the following (followed by a system reboot):
sudo apt clean
sudo apt update
sudo apt purge nvidia-*
sudo apt autoremove
Then, after googling extensively, I tried these commands (link) to install freeglut3-dev, which appears to be a dependency for CUDA that is not called out in the CUDA installation documentation.
sudo add-apt-repository universe
sudo apt-get update
sudo apt-get install freeglut3 freeglut3-dev libxi-dev libxmu-dev
Then I attempt to install CUDA 11.3 via the instructions on this link.
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
wget https://developer.download.nvidia.com/compute/cuda/11.3.1/local_installers/cuda-repo-ubuntu1804-11-3-local_11.3.1-465.19.01-1_amd64.deb
sudo dpkg -i cuda-repo-ubuntu1804-11-3-local_11.3.1-465.19.01-1_amd64.deb
sudo apt-key add /var/cuda-repo-ubuntu1804-11-3-local/7fa2af80.pub
sudo apt-get update
sudo apt-get -y install cuda
This does not work. I don’t know if the documentation is broken or if it’s a bad build of CUDA, but this is what I get when I follow those instructions:
ubuntu18user:~/Projects/deepstream$ sudo apt-get -y install cuda
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda : Depends: cuda-11-3 (>= 11.3.1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
If I try to install cuda-11-3, I get this error:
ubuntu18user:~/Projects/deepstream$ sudo apt-get -y install cuda-11-3
cuda-11-3 : Depends: cuda-runtime-11-3 (>= 11.3.1) but it is not going to be installed
Depends: cuda-demo-suite-11-3 (>= 11.3.58) but it is not going to be installed
If I try to install cuda-runtime-11-3, I get this error:
ubuntu18user:~/Projects/deepstream$ sudo apt-get -y install cuda-runtime-11-3
cuda-runtime-11-3 : Depends: cuda-drivers (>= 465.19.01) but it is not going to be installed
If I try to install cuda-drivers, I get this error:
ubuntu18user:~/Projects/deepstream$ sudo apt-get -y install cuda-drivers
cuda-drivers : Depends: cuda-drivers-465 (= 465.19.01-1) but it is not going to be installed
If I try to install cuda-drivers-465, I get this error:
ubuntu18user:~/Projects/deepstream$ sudo apt-get -y install cuda-drivers-465
cuda-drivers-465 : Depends: (>= 465.19.01) but it is not going to be installed
Depends: libnvidia-decode-465 (>= 465.19.01) but it is not going to be installed
Depends: libnvidia-encode-465 (>= 465.19.01) but it is not going to be installed
Depends: nvidia-compute-utils-465 (>= 465.19.01) but it is not going to be installed
Depends: nvidia-driver-465 (>= 465.19.01) but it is not going to be installed
Depends: nvidia-utils-465 (>= 465.19.01) but it is not going to be installed
Depends: nvidia-modprobe (>= 465.19.01)
Depends: nvidia-settings (>= 465.19.01) but 460.84-0lambda1 is to be installed
Installing these dependencies seems to work:
sudo apt-get -y install libnvidia-compute-465 libnvidia-decode-465 libnvidia-encode-465 nvidia-compute-utils-465 nvidia-driver-465 nvidia-utils-465 nvidia-modprobe nvidia-settings
But as soon as I try to work my way back up to installing cuda, I get another cascade of failures:
cuda-drivers-465 : Depends: nvidia-modprobe (>= 465.19.01)
From this point, it’s just rinse & repeat - no matter what I try, I always end up around this same place. For example, I can run this, and it seems to work:
sudo apt-get -y install nvidia-settings>=465.19.01 nvidia-settings>=465.19.01
But as soon as I try to install cuda-drivers-465 again, it’s back to failing:
I’m not sure how to install CUDA 11.x on amd64 Ubuntu 18.04 - this feels like a vicious cycle, and I’m not able to make any significant forward progress at this point. Any ideas?
