I have installed Ubuntu 18.04 desktop on HP laptop with Graphics card GM107GLM [Quadro M2000M]:
$ sudo lshw -C display
*-display
description: VGA compatible controller
product: GM107GLM [Quadro M2000M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:133 memory:e4000000-e4ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:3000(size=128) memory:e5080000-e50fffff
*-display
product: HD Graphics 530
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:131 memory:e3000000-e3ffffff memory:40000000-4fffffff ioport:6000(size=64) memory:c0000-dffff
I have installed nvidia-driver-460:
$ nvidia-smi
Sat May 22 16:03:23 2021
| NVIDIA-SMI 460.73.01 Driver Version: 460.73.01 CUDA Version: 11.2 |
| | | MIG M. |
| 0 Quadro M2000M Off | 00000000:01:00.0 Off | N/A |
| N/A 33C P8 N/A / N/A | 716MiB / 4043MiB | 5% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2145 G /usr/lib/xorg/Xorg 551MiB |
| 0 N/A N/A 2332 G /usr/bin/gnome-shell 33MiB |
| 0 N/A N/A 2939 G ...AAAAAAAA== --shared-files 6MiB |
| 0 N/A N/A 3456 G ...AAAAAAAAA= --shared-files 12MiB |
| 0 N/A N/A 9540 G ...AAAAAAAAA= --shared-files 49MiB |
| 0 N/A N/A 9843 G ...oken=17184766749938794993 8MiB |
| 0 N/A N/A 9957 G /opt/zoom/zoom 5MiB |
| 0 N/A N/A 10072 G ...AAAAAAAAA= --shared-files 34MiB |
I have been trying to installed CUDA Toolkit 11.3, by following the the instructions in the link:
[https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&Distribution=Ubuntu&target_version=18.04&target_type=deb_local](https://CUDA 11.3 installation)
$ wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pin
$ sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
$ wget https://developer.download.nvidia.com/compute/cuda/11.3.1/local_installers/cuda-repo-ubuntu1804-11-3-local_11.3.1-465.19.01-1_amd64.deb
$ sudo dpkg -i cuda-repo-ubuntu1804-11-3-local_11.3.1-465.19.01-1_amd64.deb
$ sudo apt-key add /var/cuda-repo-ubuntu1804-11-3-local/7fa2af80.pub
$ sudo apt-get update
$ sudo apt-get -y install cuda
But the last command failed as mentioned as follows:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
cuda : Depends: cuda-11-3 (>= 11.3.1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Could some body tell me why it is failing and how I can fix this? Is the problem with Graphics Card? Driver version? Or CUDA version? I need to fix this as soon as possible.
Amin
