Xzz
May 16, 2023, 2:07am
1
Hardware: Jetson Orin NX 8GB SOM + customized carried board
Software: JetPack 5.1.1 L4T 35.3.1
I download source and flash it :
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml \
-p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--showlogs \
--network usb0 \
p3509-a02+p3767-0000 nvme0n1p1
Everything is looks ok, and the HDMI display ok.
But after I update kernel ,my HDMI can’t display anymore.
I just replace the /boot/Image in the device and reboot.
This is the log in the debug serial port:
HDMI不显示调试串口日志.log (180.4 KB)
I run xrandr and found “Can’t open display”
root@tegra-ubuntu:~# xrandr
Can't open display
Xzz
May 16, 2023, 2:18am
2
And I use above command to flash all image again ,but HDMI is not diplay.
What’s more, I disconnect the external NVME and power on the board, HDMI display UEFI fine, so hardware is ok.
This is my build kernel procedure
OUTPATH=$PWD/source/public/kernel_out
cd source/public/kernel/kernel-5.10/
make ARCH=arm64 O=$OUTPATH tegra_defconfig
make ARCH=arm64 O=$OUTPATH -j8
cd Linux_for_Tegra
cp source/public/kernel_out/arch/arm64/boot/dts/nvidia/* kernel/dtb -rf
cp source/public/kernel_out/arch/arm64/boot/Image kernel/
After that, I copy Linux_for_Tegra/kernel/Image to the board /boot/Image
Could you please take a look at my steps to see if there are any issues? Thank you!
There is a bug in Orin NX 8GB + p3509 flash config file. Sku 0001 needs this patch to use correct dtb file.
Hi shinichiro.adachi,
Please refer to the BOARDSKU difference between Orin NX 16GB and 8GB.
Jetson Orin NX 16GB (P3767-0000)
Jetson Orin NX 8GB (P3767-0001)
Do you distinguish them in your board config (dx-u2200+3767-0000.conf)?
You could refer to the following line in p3768-0000+p3767-0000.conf.
if [ "${board_sku}" = "0000" ] || [ "${board_sku}" = "0002" ]; then
# use default DTB and CFG files except for TS1 & EB1 revisions
if [ "${board_FAB}" = "TS…
Xzz
May 16, 2023, 3:16am
5
Thank you for reply.
I have fix this bug, and dts is correct, but HDMI still can not display.
diff --git a/p3509-a02+p3767-0000.conf b/p3509-a02+p3767-0000.conf
index 78fd01c..e4928d0 100644
--- a/p3509-a02+p3767-0000.conf
+++ b/p3509-a02+p3767-0000.conf
@@ -55,7 +55,7 @@ update_flash_args_common()
BPFDTB_FILE="tegra234-bpmp-3767-0000-a00-3509-a02.dtb";
fi
elif [ "${board_sku}" = "0001" ]; then
- DTB_FILE="tegra234-p3767-0000-p3509-a02.dtb";
+ DTB_FILE="tegra234-p3767-0001-p3509-a02.dtb";
BPFDTB_FILE="tegra234-bpmp-3767-0001-3509-a02.dtb";
elif [ "${board_sku}" = "0003" ] || [ "${board_sku}" = "0005" ]; then
DTB_FILE="tegra234-p3767-0003-p3509-a02.dtb";
Please share the result of your lsmod.
Xzz
May 16, 2023, 3:35am
7
This is my lsmod result.
lsmod.txt (2.3 KB)
The display drivers are gone. Please also build them.
There is separate code tarball in the public source. Please check it.
Xzz
May 16, 2023, 3:42am
9
Thank you! I will try it,
Can you give me some reference?
Download the public source. Check the display driver tarball.
Xzz
May 16, 2023, 7:44am
11
I found this tarball and build success:
Here are some ko file in the directory
this is my command
ROOT=$PWD
TOOLCHAIN_DIR=$ROOT/l4t-gcc
export CROSS_COMPILE_AARCH64_PATH=$TOOLCHAIN_DIR
export CROSS_COMPILE_AARCH64=$TOOLCHAIN_DIR/bin/aarch64-buildroot-linux-gnu-
cd source/public/NVIDIA-kernel-module-source-TempVersion/
export LOCALVERSION="-tegra"
export IGNORE_PREEMPT_RT_PRESENCE=1
make \
modules -j4 \
SYSSRC=$ROOT/source/public/kernel/kernel-5.10 \
SYSOUT=$ROOT/source/public/kernel_out \
CC=${CROSS_COMPILE_AARCH64}gcc \
LD=${CROSS_COMPILE_AARCH64}ld.bfd \
AR=${CROSS_COMPILE_AARCH64}ar \
CXX=${CROSS_COMPILE_AARCH64}g++ \
OBJCOPY=${CROSS_COMPILE_AARCH64}objcopy \
TARGET_ARCH=aarch64 \
ARCH=arm64
#in source/public/NVIDIA-kernel-module-source-TempVersion/kernel-open/
And what should I do next?
Put your new ko files to the directory as the old files’ location…
Xzz
May 16, 2023, 8:18am
13
Hi,WayneWWW,
I cannnot find same name file in the path :
Is there an error in my path?
你這個path就已經不是原本的狀態. 你要不要看一下原本預設bsp的內容?
Linux_for_Tegra/rootfs/lib/modules/5.10.104-tegra$ find -iname “nvidia*”
./kernel/drivers/nv-p2p/nvidia-p2p.ko
./extra/opensrc-disp/nvidia-modeset.ko
./extra/opensrc-disp/nvidia.ko
./extra/opensrc-disp/nvidia-drm.ko
Xzz
May 18, 2023, 1:32am
15
Thank you for your help. After my careful inspection, I found that there was an exception in my SDK. Now I have downloaded and updated the SDK again, and everything is back to normal. Thank you for your support!
system
Closed
June 7, 2023, 12:53am
17
