Hi Guys,
My device is Jetson NX, and deepstream 5.0;
I‘m trying to dump the h264 decoded data from nvv4l2decoder element。
I add a probe to the src of nvv4l2decoder,my code is like this:
After run the code, i got the output:
batch:1 numfilled:1 memtype:4 surfacearrary:4
size is : 3538944 w:1920 h:1080 pitch:1920 format:6 nv12is:6 layout:1
numer plans:2
plan: h: 1080 w:1920 bytes:1 pitch:1920 offset: 0 psize:2228224
plan: h: 540 w:960 bytes:2 pitch:1920 offset: 2228224 psize:1310720
The width, height, pitch is right, the memtype is surfacearrary, frame_format is NV12,but the image i saved is wrong, i don’t know why. And I have already set “enable-full-frame” true.
Please give me some help, thanks.
int detect_num = 0;
GstPadProbeReturn nvdecode_probe_callback(GstPad *pad, GstPadProbeInfo *pProbeInfo, gpointer u_data)
int *sub_dev_id = (int *)u_data;
GstBuffer *buf = (GstBuffer *)pProbeInfo->data;
GstMapInfo map_info;
if (buf == NULL || !gst_buffer_map(buf, &map_info, GST_MAP_READ))
printf("gst_buffer_map() error!");
return GST_PAD_PROBE_OK;
if (detect_num == 0)
detect_num++;
NvBufSurface *surface = (NvBufSurface *)map_info.data;
printf("batch:%d numfilled:%d memtype:%d surfacearrary:%d \n", surface->batchSize, surface->numFilled, surface->memType, NVBUF_MEM_SURFACE_ARRAY);
int index = 0;
int size = surface->surfaceList[index].dataSize;
gint frame_width = (gint)surface->surfaceList[index].width;
gint frame_height = (gint)surface->surfaceList[index].height;
gint frame_step = (gint)surface->surfaceList[index].pitch;
gint frame_format = (gint)surface->surfaceList[index].colorFormat;
gint frame_layout = (gint)surface->surfaceList[index].layout;
printf("size is : %d w:%d h:%d pitch:%d format:%d nv12is:%d layout:%d \n", size, frame_width, frame_height, frame_step, frame_format, NVBUF_COLOR_FORMAT_NV12, frame_layout);
NvBufSurfacePlaneParams *pParams = &surface->surfaceList[index].planeParams;
printf("numer plans:%d \n", pParams->num_planes);
for (int i = 0; i < pParams->num_planes; i++)
printf("plan: h: %d w:%d bytes:%d pitch:%d offset: %d psize:%d \n", pParams->height[i], pParams->width[i], pParams->bytesPerPix[i], pParams->pitch[i],
pParams->offset[i], pParams->psize[i]);
NvBufSurfaceMap(surface, -1, -1, NVBUF_MAP_READ);
char *src_data = (char *)malloc(surface->surfaceList[0].dataSize);
unsigned int offset = 0;
for (unsigned int num_planes = 0; num_planes < pParams->num_planes; num_planes++)
if (num_planes > 0){
offset += pParams->height[num_planes - 1] * (pParams->bytesPerPix[num_planes - 1] * pParams->width[num_planes - 1]);
for (unsigned int h = 0; h < pParams->height[num_planes]; h++)
memcpy((void *)(src_data + offset + h * pParams->bytesPerPix[num_planes] * pParams->width[num_planes]),
(void *)((char *)surface->surfaceList[index].mappedAddr.addr[num_planes] + h * pParams->pitch[num_planes]),
pParams->bytesPerPix[num_planes] * pParams->width[num_planes]);
NvBufSurfaceUnMap (surface, -1, -1);
cv::Mat frame = cv::Mat(1080 * 1.5, 1920, CV_8UC1, src_data, 1920);
cv::Mat out_mat = cv::Mat(cv::Size(1920, 1080), CV_8UC3);
cv::cvtColor(frame, out_mat, CV_YUV2BGR_NV12);
cv::imwrite("test.jpg", out_mat);
free(src_data);
gst_buffer_unmap(buf, &map_info);
