I’m sorry, I have posted this in the wrong section. Could an admin please move this to CUDA Programming and Development?
Hi everyone, I am having some difficulty getting a struct array to pass from to the kernal call. I am able to pass the struct to and from the .cu file in the main function called by my c++ program, but once I send it to CUDA the values seem to be lost.
The following is the code which pertains to this problem (I apologize for any errata, I did my best to strip out what was unnecessary and keep the important parts but I may have missed a variable definition or five External Image ):
Here are the struct declarations:
typedef struct D3DXVECTOR3 {
FLOAT x;
FLOAT y;
FLOAT z;
} D3DXVECTOR3, *LPD3DXVECTOR3;
typedef struct D3DXVECTOR4 {
FLOAT x;
FLOAT y;
FLOAT z;
FLOAT w;
} D3DXVECTOR4, *LPD3DXVECTOR4;
using namespace std;
struct vertexStruct
D3DXVECTOR3 Pos;
D3DXVECTOR4 Color;
This is so I it can read in the directX struct types. This part seems to work for the regular function call.
Then, I call the function which looks like this (grid and block are set to 1 for debugging purposes):
void fillvertices( vertexStruct vertices [], const int WIDTH, const int HEIGHT, float TriScale)
D3DXVECTOR4 color;
D3DXVECTOR4 color2;
color.x = 0.0f;
color.y = 0.0f;
color.z = 1.0f;
color.w = 0.0f;
color2.x = 0.0f;
color2.y = 0.0f;
color2.z = 1.0f;
color2.w = 0.0f;
std::ifstream f_DataFile;
f_DataFile.open("height.bmp", std::ios::binary);
int div = 3;
if (f_DataFile.is_open())
int grid = 1;
int block = 1;
kernelRun<<<grid,block>>>(vertices, WIDTH, HEIGHT, TriScale, div, color, color2);
else{
MessageBox(NULL,"HeighData file not found!","FillVertices()",MB_OK);
f_DataFile.close();
Then the global kernel call is this:
__global__ void kernelRun(vertexStruct input [], const int WIDTH, const int HEIGHT, float TriScale, int div, D3DXVECTOR4 color, D3DXVECTOR4 color2)
int y = 1;//1 for debugging
int x = 1;//1 for debugging
//first triangle
int tot = y + x*WIDTH;
int divx = x/div;
int divy = y/div;
tot = 0;
divy = 0;
divx = 0;
//1
input[tot].Pos.x = divy*TriScale;
input[tot].Pos.y = divx*TriScale;
input[tot].Pos.z = 0;
input[y + x*WIDTH].Color = color;
//2
input[tot+1].Pos.x = divy;
input[tot+1].Pos.y = (divx+1)*TriScale;
input[tot+1].Pos.z = 0;
input[tot+1].Color = color;
//3
input[tot+2].Pos.x = (divy+1)*TriScale;
input[tot+2].Pos.y = (divx)*TriScale;
input[tot+2].Pos.z = 0;
input[tot+2].Color = color;
WIDTH and HEIGHT are set to 1024 each, div is 3, TriScale is 5, , and all values worked previously sequentially. It is basically a 1024x1024 grid of coordinates which I am trying to pass back to directX. If I can get this to work, I should be able to instance a very nice Parallax Occlusion effect and make a realistic, fast vegetation engine.
Thank you in advance and I’ll keep everyone updated on my progress!
EDIT:
Also, the problem is that it runs, but variables seem not to be transferred from the kernel version of the struct as I only see the backdrop and no triangle.
