I know there was a way to setup an environment variable or a text file which told the CUDA driver to profile the code, but I can’t seem to remember how that worked. If anyone could point me in the rignt direction, I would be grateful. I know that the visual profiler does this automatically, but I’ve had problems using the visual profiler before when running cuda code on multiple cards, so I would like to do this manually. I’m running Fedora linux right now. Thanks in advance.
Read the documentation in $CUDA_INSTALL_DIR/doc/CUDA_Profiler_2.0.txt
Ah, thanks. That is the file I was looking for. :)
Related topics
| Profiling with the Visual Profiler? | 2 | 4979 | June 18, 2009 | |
| CUDA Profiler 0.9 How to enable Profiler tool? | 11 | 46064 | June 2, 2009 | |
| Using CUDA Visual Profiler through a console | 2 | 1642 | August 13, 2009 | |
| How to Use Cuda Visual Profiler I want to Run a simple program using Cuda Visual Profiler | 2 | 29584 | December 15, 2009 | |
| CUDA Profiler output on command line? | 5 | 13586 | April 9, 2011 | |
| Running CUDA Visual Profiler | 8 | 5134 | October 29, 2010 | |
| CUDA profiling without GUI and then interpreting results with visual profiler | 1 | 1095 | July 31, 2011 | |
| CUDA Visual Profile. Started of CUDA Visual Profile. | 1 | 2355 | February 16, 2009 | |
| Set environment variables? | 2 | 4900 | May 9, 2009 | |
| CUDA visual profiler | 1 | 2829 | August 15, 2008 |
