Hi. I’ve got 3 C1060s sitting inside a machine with 24GB of RAM, configured 64 bit. I have set the OMP_STACKSIZE to a decent number (5GB). I have a 2.35GB array set as SHARED in an openMP PARALLEL DO loop, with all private arrays much smaller than this for the three openMP threads I’m using to manage my 3 GPUs. I am really struggling to handle arrays much larger than this. If I am not getting bus errors and segmentation faults, I’m getting this at compile time - can anyone explain what all this output means?
Thanks,
Rob.
[cuda001 LOCUST-GPU_2.4]$ pgfortran -fast -o test.out prec_mod.cuf ddreac_mod.cuf neutrons.cuf -mp
prec_mod.cuf:
ddreac_mod.cuf:
neutrons.cuf:
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_myprocnum':
initpar.c:(.text+0x2): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_ncpus':
initpar.c:(.text+0x12): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_tcpus' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_getioproc':
initpar.c:(.text+0x22): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_ioproc' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_is_ioproc':
initpar.c:(.text+0x32): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_ioproc' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
initpar.c:(.text+0x38): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_abort':
initpar.c:(.text+0x5f): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_abortp':
initpar.c:(.text+0xeb): relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_lcpu' defined in COMMON section in /opt/local/lib/libpgf90.a(initpar.o)
/opt/local/lib/libpgf90.a(initpar.o): In function `__hpf_initarg':
initpar.c:(.text+0x127): relocation truncated to fit: R_X86_64_PC32 against `.bss'
initpar.c:(.text+0x151): relocation truncated to fit: R_X86_64_PC32 against `.bss'
initpar.c:(.text+0x17b): relocation truncated to fit: R_X86_64_PC32 against `.bss'
initpar.c:(.text+0x18b): additional relocation overflows omitted from the output
