I am trying to compile a program, but it gives the error message below when I try to increase an arrays size in the code. Below a certain value, compiling works.
Could you help me?
Thanks,
/usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function __hpf_myprocnum': initpar.c:(.text+0x2): relocation truncated to fit: R_X86_64_PC32 against symbol
__hpf_lcpu’ defined in COMMON section in /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function __hpf_ncpus': initpar.c:(.text+0x12): relocation truncated to fit: R_X86_64_PC32 against symbol
__hpf_tcpus’ defined in COMMON section in /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function __hpf_getioproc': initpar.c:(.text+0x22): relocation truncated to fit: R_X86_64_PC32 against symbol
__hpf_ioproc’ defined in COMMON section in /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function __hpf_is_ioproc': initpar.c:(.text+0x32): relocation truncated to fit: R_X86_64_PC32 against symbol
initpar.c:(.text+0x38): relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu' defined in COMMON section in /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function
__hpf_abort’:
initpar.c:(.text+0x5f): relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu' defined in COMMON section in /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function
__hpf_abortp’:
initpar.c:(.text+0xf0): relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu' defined in COMMON section in /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.2/lib/libpgf90.a(initpar.o): In function
__hpf_initarg’:
initpar.c:(.text+0x147): relocation truncated to fit: R_X86_64_PC32 against .bss' initpar.c:(.text+0x171): relocation truncated to fit: R_X86_64_PC32 against
.bss’
initpar.c:(.text+0x19b): relocation truncated to fit: R_X86_64_PC32 against `.bss’
initpar.c:(.text+0x1ab): additional relocation overflows omitted from the output
