I am having trouble compiling some code that uses large address space for an Opteron cluster. I am using -tp k8-64 -mcmodel=medium and with or without -Mlarge_arrays I get errors from the linker that look like the section below. Does anybody have an idea of what is going wrong here?
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x2): In function __hpf_myprocnum': initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu’ defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x9): In function __hpf_ncpus': initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_tcpus’ defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x10): In function __hpf_getioproc': initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_ioproc’ defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x17): In function __hpf_is_ioproc': initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu’ defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x1d):initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_ioproc' defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x41): In function __hpf_abort’:
initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu' defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0xa5): In function __hpf_abortp’:
initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_lcpu' defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x5c0): In function __hpf_istat’:
initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_quiet' defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o) /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x5e6):initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol __hpf_quiet’ defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x60c):initpar.c: relocation truncated to fit: R_X86_64_PC32 against symbol `__hpf_quiet’ defined in COMMON section in /usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)
/usr/local/pgi/linux86-64/6.0/lib/libpgf90.a(initpar.o)(.text+0x632):initpar.c: additional relocation overflows omitted from the output
gmake: *** [flash2] Error 2
Thanks,
Sebastian
